Home » Modeling » EMF » Customization of XML serialization
Customization of XML serialization [message #645037] Wed, 15 December 2010 05:19 Go to next message
Hi all,
now I am investigating possibilities of customization of XML serialization. I have found the possibility to change name of an element or persist an XML attribute as a nested element. Now I am curious if I can save an element as an attribute. For example, my model contains two classes - Phase and ExInteger (I need to manage this integer as a class, since its definition is common string, which can be interpreted as an integer). My ecore specification looks like:
  <eClassifiers xsi:type="ecore:EClass" name="Phase">
    <eStructuralFeatures xsi:type="ecore:EReference" name="number" eType="#//ExInteger"
        containment="true" resolveProxies="false">
      <eAnnotations source="http:///org/eclipse/emf/ecore/util/ExtendedMetaData"> //this is useless attempt to achieve the desired behaviour
        <details key="kind" value="attribute"/>
      </eAnnotations>
    </eStructuralFeatures>
  </eClassifiers>
And the ExInteger class contains only one single string attribute (plus few custom operations). So the default XML looks like this:
<phase>
  <number stringValue="123"/>
</phase>
The desired XML would be:
<phase number="123">
</phase>
Do I have a chance to achieve this behaviour?
Thank a lot for any suggestion, Martin.
Re: Customization of XML serialization [message #645152 is a reply to message #645037] Wed, 15 December 2010 12:01 Go to previous messageGo to next message
Martin,
Comments below.
Martin Zatopek wrote:
> Hi all,
It sounds more likely that it should be a specialized data type.
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> <phase>
> </phase>
> </phase>
I don't see any strong reason why you'd model ExInteger as an EClass.
Can you give any?
If there is a good reason, you could make the EReference transient and
derived, define an EDataType that wraps the generated interface for
ExInteger, and define an EAttribute that isn't transient for storing the
actual value... You could suppress the accessors for it from the API.
Re: Customization of XML serialization [message #645422 is a reply to message #645152] Fri, 17 December 2010 04:00 Go to previous messageGo to next message
Thank a lot, Ed. I really appreciate your answer. And that was great support from your side!
I would like to have the ExInteger object part of emf model, since the value resolution (ExInteger -> Integer) is based on data somewhere in the model. The context where the ExInteger is placed in the model hierarchy (for example eContainer reference) would be really appreciated.
Thanks for your suggestion how to work around and achieve desired behaviour, but for now I would like to avoid the change of the model in order to have just a nice XML.
Thanks again, Martin.
Re: Customization of XML serialization [message #645437 is a reply to message #645037] Fri, 17 December 2010 04:24 Go to previous messageGo to next message
I have another question. It is still concerned in 'Customization of XML serialization' I decided to use this thread again.
I would like to use non-default XML elements naming convention. I found that is possible to do by ecore annotations. I tied to simplify the issue as more as possible. Consider following simple ecore file (two classes Root and Child, Root class has one reference called children to Child class and Child class has one simple string attribute 'value'):
<ecore:EPackage xmi:version="2.0"
    xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="model"
    nsURI="clover" nsPrefix="clover">
  <eClassifiers xsi:type="ecore:EClass" name="Root">
    <eStructuralFeatures xsi:type="ecore:EReference" name="children" upperBound="-1"
        eType="#//Child" containment="true" resolveProxies="false">
        <details key="name" value="child"/>
      </eAnnotations>
  </eClassifiers>
  <eClassifiers xsi:type="ecore:EClass" name="Child">
    <eStructuralFeatures xsi:type="ecore:EAttribute" name="value" eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EString"/>
  </eClassifiers>
</ecore:EPackage>
Take a note of annotation. Children reference should be persisted in XML element called 'child'.
Here is the code which use generated model. First creates root class with single child and saves it into a file.
public class Test {
	private static void save() throws IOException {
		ResourceSet resourceSet = new ResourceSetImpl();
		resourceSet.getResourceFactoryRegistry().getExtensionToFactoryMap().put("*", new XMLResourceFactoryImpl());
		ModelPackageImpl.eINSTANCE.eClass();
		Resource graphResource = resourceSet.createResource(URI.createFileURI("c:/Kokon/work/temp/junk/simple.xml"));
		ModelFactory modelFactory = ModelFactory.eINSTANCE;
		//create model
		Root root = modelFactory.createRoot();
		Child child = modelFactory.createChild();
		child.setValue("kokon");
		root.getChildrens().add(child);
		graphResource.getContents().add(root);
		Map options = new HashMap();
		options.put(XMLResource.OPTION_EXTENDED_META_DATA, Boolean.TRUE);
		graphResource.save(options);
	private static void load() throws IOException {
		graphResource.load(options);
		System.out.println(graphResource.getContents().get(0));
	public static void main(String[] args) throws IOException {
		save();
		load();
The resulted XML file looks perfect ('child' element instead of 'children'):
<?xml version="1.0" encoding="ASCII"?>
<clover:Root xmlns:clover="clover">
  <child value="kokon"/>
</clover:Root>
But when I try to load the XML file again I got the following exception:
Exception in thread "main" org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Feature 'child' not found. (file:/c:/Kokon/work/temp/junk/simple.xml, 3, 25)
	at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.handleErrors(XMLLoadImpl.java:83)
	at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:191)
	at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:180)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1494)
	at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1282)
	at Test.load(Test.java:55)
	at Test.main(Test.java:62)
Caused by: org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'child' not found. (file:/c:/Kokon/work/temp/junk/simple.xml, 3, 25)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.reportUnknownFeature(XMLHandler.java:1991)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleUnknownFeature(XMLHandler.java:1955)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleFeature(XMLHandler.java:1899)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1023)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:1001)
	at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:712)
	at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(AbstractSAXParser.java:501)
	at com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocumentParser.emptyElement(AbstractXMLDocumentParser.java:179)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.java:1339)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(XMLDocumentFragmentScannerImpl.java:2747)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(XMLDocumentScannerImpl.java:648)
	at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java:510)
	at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:807)
	at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(XML11Configuration.java:737)
	at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(XMLParser.java:107)
	at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(AbstractSAXParser.java:1205)
	at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(SAXParserImpl.java:522)
	at javax.xml.parsers.SAXParser.parse(SAXParser.java:395)
	at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:181)
	... 5 more
What is wrong in my Test class?
Thanks again for your time! Martin
Re: Customization of XML serialization [message #645440 is a reply to message #645037] Fri, 17 December 2010 04:27 Go to previous messageGo to next message
BTW I was able to customize XMLSaveImpl so that ExInteger class is saved as attribute. And I am going to try to do the same thing with XMLLoadImpl, but I run into another issue described above.
Re: Customization of XML serialization [message #645486 is a reply to message #645437] Fri, 17 December 2010 07:42 Go to previous messageGo to next message
I found the solution Smile After few hours of debugging I add one more annotation into my ecore file:
        [B]<details key="kind" value="element"/>[/B]
      </eAnnotations>
  </eClassifiers>
  </eClassifiers>
</ecore:EPackage>
Thanks anyway and I'm sorry for these useless posts.
Martin
PS: are the annotations described somewhere in detail?
Re: Customization of XML serialization [message #645566 is a reply to message #645422] Fri, 17 December 2010 20:39 Go to previous messageGo to next message
Martin,
Comments below.
I wonder though the relationship when you deserialize.
You could make all the changes invisible in the API...
Re: Customization of XML serialization [message #645567 is a reply to message #645486] Fri, 17 December 2010 20:41 Go to previous message
Martin,
The book describes all the annotations produce for XML Schema...
> I found the solution :) After few hours of debugging I add one more
> upperBound="-1"
> <eAnnotations
> </eAnnotations>
> </eClassifiers>
> </eClassifiers>
> </ecore:EPackage>
> Martin
Previous Topic:[EMF compare] An Extensible Framework
Next Topic:knowing the get/set method names of an attribute
Current Time: Sat Jul 19 00:55:31 EDT 2025
Powered by FUDForum. Page generated in 0.03636 seconds
