Re: Help required for MDT/OCL bucky build. [message #645853 is a reply to message #645359] |
Mon, 20 December 2010 14:30  |
To clarify:
The original problem (https://bugs.eclipse.org/bugs/show_bug.cgi?id=332546) was not including lpg.runtime.java bundle into the distributed zips.
Now, the bundle is included in the distributed zips. Besides I'm also distributing the lpg.runtime.java.source bundle in each zip which is supposed to include said source bundle. However, the mdt-ocl-Update.zip which corresponds to MDT/OCL p2 repository, doesn't include this lpg.runtime.java.source bundle.
I believe that it's problem of my buckminster-based build, because the athena's based one managed to include it (for instance the MDT/OCL Indigo's M2 included the lpg.runtime.java.source bundle -> http://www.eclipse.org/downloads/download.php?file=/modeling /mdt/ocl/downloads/drops/3.1.0/S201009291415/mdt-ocl-Update- 3.1.0M2a.zip).
The WORST problem around this issue is that our Modeling EPP distribution doesn't contain the lpg.runtime.java.source bundle, which it's very bad (for instance the Modeling EPP M4 -> http://www.eclipse.org/downloads/packages/node/449 )
I've been trying to figure out which is the reason of this problem, so that I tryed to at least make the aforementioned source bundle be available in the MDT/OCL p2 repo without any luck (for instance our last N-build p2 repository zip http://www.eclipse.org/downloads/download.php?file=/modeling /mdt/ocl/downloads/drops/3.1.0/N201012200300/mdt-ocl-Update- N201012200300.zip). So my questions are:
- Do you have any idea about how to make this happen ?
- Do you think that after fixing this issue, the lpg.runtime.java.source bundle will finally be available in our Modeling distribution ?
P.S: Again, if you need any other information/clarification, please let me know it.
Best Regards,
Adolfo.
FUDForum. Page generated in 0.04406 seconds
