BIRT NullPointerException [message #549886] |
Wed, 28 July 2010 07:29  |
My Report has a table connected to MySQL DB. The report is displayed correctly in preview mode of eclipse ide.
When i run the report and save it to html format using java code, it throws errors.
If my report has no dataset, it works fine from the below java code.
please help me.
Code Snippet:
public class TestBirt {
* @param args
IReportEngine engine = null;
EngineConfig config = null;
try {
config = new EngineConfig();
config.setEngineHome("C:/Documents and Settings/pras/Desktop/birt-runtime-2_6_0/birt-runtime-2_6_0/ ReportEngine ");
config.setLogConfig(null, Level.ALL);
Platform.startup(config);
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject(IReportEngineFactory.EXTENSION_REPORT_E NGINE_FACTORY);
engine = factory.createReportEngine(config);
engine.changeLogLevel(Level.ALL);
IReportRunnable design = null;
design = engine.openReportDesign("Department_Report.rptdesign");
IRunAndRenderTask task = engine.createRunAndRenderTask(design);
task.getAppContext().put(EngineConstants.APPCONTEXT_CLASSLOA DER_KEY, TestBirt.class.getClassLoader());
HTMLRenderOption options = new HTMLRenderOption();
options.setOutputFileName("C:/Documents and Settings/pras/Desktop/output.html");
options.setOutputFormat("html");
task.setRenderOption(options);
task.run();
task.close();
engine.shutdown();
Platform.shutdown();
System.out.println("Finished");
} catch (Exception ex) {
ex.printStackTrace();
Below are the logs:
Jul 28, 2010 4:09:25 PM org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager loadDriverExtensions
INFO: Found JDBC driverinfo extension: driverClass=org.apache.derby.jdbc.EmbeddedDriver, connectionFactory=null
INFO: Found JDBC driverinfo extension: driverClass=org.eclipse.birt.report.data.oda.sampledb.Driver , connectionFactory=org.eclipse.birt.report.data.oda.sampledb. SampleDBJDBCConnectionFactory
Jul 28, 2010 4:09:25 PM org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager loadAndRegisterDriver
INFO: Loading JDBC driver class: com.mysql.jdbc.Driver
Jul 28, 2010 4:09:25 PM org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager findDriver
INFO: Driver class not in class path: com.mysql.jdbc.Driver. Trying to locate driver in drivers directory
Jul 28, 2010 4:09:25 PM org.eclipse.birt.report.data.oda.jdbc.JDBCDriverManager$Driv erClassLoader addNewURL
INFO: JDBCDriverManager: found JAR file drivers/mysql-connector-java-3.1.13-bin.jar. URL= bundleentry://41.fwk15655788/drivers/mysql-connector-java-3. 1.13-bin.jar
Jul 28, 2010 4:09:26 PM org.eclipse.birt.report.engine.api.impl.RunAndRenderTask doRun
SEVERE: An error happened while running the report. Cause:
at org.eclipse.birt.report.engine.emitter.html.util.HTMLEmitter Util.buildOverflowStyle(HTMLEmitterUtil.java:289)
at org.eclipse.birt.report.engine.emitter.html.HTMLVisionOptimi ze.buildCellStyle(HTMLVisionOptimize.java:362)
at org.eclipse.birt.report.engine.emitter.html.HTMLReportEmitte r.startCell(HTMLReportEmitter.java:2135)
at org.eclipse.birt.report.engine.emitter.CompositeContentEmitt er.startCell(CompositeContentEmitter.java:233)
at org.eclipse.birt.report.engine.layout.html.HTMLTableLayoutEm itter.startCell(HTMLTableLayoutEmitter.java:701)
at org.eclipse.birt.report.engine.emitter.ContentEmitterUtil.st artContent(ContentEmitterUtil.java:59)
at org.eclipse.birt.report.engine.layout.html.buffer.DummyPageB uffer.startContainer(DummyPageBuffer.java:106)
at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.st art(HTMLStackingLM.java:50)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.la yout(HTMLAbstractLM.java:139)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin gLM.resumeLayout(HTMLInlineStackingLM.java:111)
at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin gLM.layoutNodes(HTMLInlineStackingLM.java:160)
at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.la youtChildren(HTMLStackingLM.java:26)
at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.la yout(HTMLAbstractLM.java:140)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:70)
at org.eclipse.birt.report.engine.layout.html.HTMLTableBandLM.l ayoutChildren(HTMLTableBandLM.java:67)
at org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layou tChildren(HTMLTableLM.java:132)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:90)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:99)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:172)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:75)
at com.foursoft.TestBirt.main(TestBirt.java:43)
org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:188)
... 2 more
Re: BIRT NullPointerException [message #549974 is a reply to message #549886] |
Wed, 28 July 2010 11:32   |
This appears to be a bug. I will log it. To work around it add:
options.setEnableAgentStyleEngine(true);
to your html options.
On a side note change this:
from the task to the config.
ie config.getAppContext()......
Jason
> throws errors.
> please help me.
> Code Snippet:
> * @param args
> public static void main(String[] args) {
> try {
> ReportEngine ");
> NGINE_FACTORY);
> task.run();
> task.close();
> engine.shutdown();
> System.out.println("Finished"); } catch (Exception ex) {
> Below are the logs:
> running the report
> ... 2 more
Re: BIRT NullPointerException [message #549982 is a reply to message #549974] |
Wed, 28 July 2010 11:49   |
The bug is logged at:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=321144
> Jason
>> throws errors.
>> please help me.
>> Code Snippet:
>> * @param args
>> try {
>> ReportEngine ");
>> NGINE_FACTORY);
>> task.run();
>> task.close();
>> engine.shutdown();
>> Below are the logs:
>> running the report
>> ... 2 more
FUDForum. Page generated in 0.03393 seconds
