Home » Modeling » Epsilon » [EugEnia] using phantom nodes and custom figures
[EugEnia] using phantom nodes and custom figures [message #645177] |
Wed, 15 December 2010 14:20  |
I've read the articles http:// www.eclipse.org/gmt/epsilon/doc/articles/eugenia-phantom-nod es/ and http:// www.eclipse.org/gmt/epsilon/doc/articles/eugenia-nodes-with- images/.
Both phantom Nodes and images on the diagram are working fine individually, but if i try to combine both techniques I get some errors in my diagram-code:
Description Resource Path Location Type
Can only iterate over an array or an instance of java.lang.Iterable FeatureModelDiagramUpdater.java /de.tgt.featureModel.represantation.diagram/src/featureModel/diagram/part line 66 Java Problem
The method getNode_2003SemanticChildren(View) is undefined for the type FeatureModelDiagramUpdater NodeCanonicalEditPolicy.java /de.tgt.featureModel.represantation.diagram/src/featureModel/diagram/edit/policies line 64 Java Problem
The method getRootAsset_2001SemanticChildren(View) is undefined for the type FeatureModelDiagramUpdater RootAssetCanonicalEditPolicy.java /de.tgt.featureModel.represantation.diagram/src/featureModel/diagram/edit/policies line 64 Java Problem
Here is my .emf I create my GMF-diagram from:
@namespace(uri="http://featureModel/1.0", prefix="featureModel")
@gmf(foo="bar")
package featureModel;
@gmf.diagram(foo="bar")
class FeatureModel {
val RootAsset[1] root;
@gmf.node(figure="figures.RootAssetImage", label.icon="false", label="name")
class RootAsset {
attr String[1] name;
@gmf.link(target.decoration="arrow", style="dash", tool.name="Connection")
val Node[*] node;
@gmf.node(figure="figures.NodeImage",label.icon="false",label="name",phantom="true")
class Node {
So my questions are:
-Is there anything I do wrong in it?
-Has anyone ever combined phantom nodes and images and/or could give me a sample .emf?
Thanks in advance
With best regards
David
Re: [EugEnia] using phantom nodes and custom figures [message #645212 is a reply to message #645177] |
Wed, 15 December 2010 17:53   |
Hi David,
Interestingly enough, this appears to be working fine with the version
of GMF that ships with Eclipse 3.5.1 but not with the version that ships
with 3.6... I suspect it's a regression in GMF. Could you please attach
the .ecore, .genmodel and .gmf* files generated by EuGENia to a bug
report for GMF in the bugzilla and also post the link to the GMF
newsgroup so that the developers there can investigate?
Dimitris
> @gmf(foo="bar")
> label="name")
> class RootAsset {
> val Node[*] node;
> @gmf.node(figure="figures.NodeImage",label.icon="false",label= "name",phantom="true")
> class Node {
Re: [EugEnia] using phantom nodes and custom figures [message #645676 is a reply to message #645177] |
Sun, 19 December 2010 14:00  |
Hey David,
This is definitely a problem with the new GMF templates. I've had a similar problem, which I was able to fix by following the advice in this thread from the GMF forum: http://www.google.com/url?sa=t&source=web&cd=3&v ed=0CCoQFjAC&url=http%3A%2F%2Fwww.eclipse.org%2Fforums%2 Findex.php%3Ft%3Dmsg%26goto%3D559031%26S%3De1d2fd695324b1516 5c218166ddf15e5&ei=Y0MOTeKcMcL-8AbW39TYDQ&usg=AFQjCN EYlZQ3aNtCMDm1Vmqn9xC4lx984A&sig2=nvrzr-hSi51JvJiZK2CwFA
The latest (Helios) GMF release seems to have introduced a number of issues. Shortcuts are badly broken as well. I'm currently trying to figure out how to work around that, but so far with very mixed results. On the bright side, the troubles seem to be with the templates, rather than the runtime. I think these problems haven't been more widely reported because most GMF power-users seem to have highly customized templates, presumably based on earlier versions.
As a work-around, I'm going to try using the old templates with the new runtime, by setting gmfgen to use dynamic templates. In Helios, there's a plugin named org.eclipse.gmf.templates.legacy. Hopefully, that's the place to start. I'll report back here if I have any luck.
GMF is so complex, it makes me feel like a member of a cargo cult. Have you tried swinging a dead chicken over it?
Mark
Current Time: Sat Jul 26 01:15:13 EDT 2025
Powered by FUDForum. Page generated in 0.05930 seconds
