Home » Modeling » BPEL Designer » Error while creating the HelloWorld Tutorial
Error while creating the HelloWorld Tutorial [message #645065] Wed, 15 December 2010 08:34 Go to next message
I get the following error while working in the BPEL designer.
Grateful for any help to resolve the error.
!SESSION 2010-12-15 17:09:18.046 -----------------------------------------------
eclipse.buildId=M20100909-0800
java.version=1.6.0
Framework arguments: -product org.eclipse.platform.ide
Command-line arguments: -product org.eclipse.platform.ide -data e:\RuntimeWorkspace -dev file:E:/myworkspace/.metadata/.plugins/org.eclipse.pde.core/ BPELconfiguration/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.wst.server.core 4 0 2010-12-15 17:12:15.578
!MESSAGE Server Ode v1.x Server at localhost failed to start.
!ENTRY org.eclipse.wst.server.core 4 0 2010-12-15 17:12:50.093
!ENTRY org.eclipse.wst.server.core 4 0 2010-12-15 17:15:34.953
!ENTRY org.eclipse.jface 4 0 2010-12-15 17:19:48.218
!MESSAGE Unhandled event loop exception during blocked modal context.
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
at org.eclipse.swt.SWT.error(SWT.java:4083)
at org.eclipse.swt.SWT.error(SWT.java:3998)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:137)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:4041)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3660)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. block(ModalContext.java:173)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:388)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 1008)
at org.eclipse.wst.server.ui.internal.wizard.TaskWizard.perform Finish(TaskWizard.java:221)
at org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:811)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:430)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:234)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.wst.server.ui.internal.actions.LaunchWizardActio n.run(LaunchWizardAction.java:57)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
at org.eclipse.wst.server.ui.internal.wizard.TaskWizardPage.set Message(TaskWizardPage.java:104)
at org.eclipse.jst.server.generic.ui.internal.ServerTypeDefinit ionServerDecorator.validate(ServerTypeDefinitionServerDecora tor.java:41)
at org.eclipse.jst.server.generic.ui.internal.GenericServerWiza rdFragment.enter(GenericServerWizardFragment.java:109)
at org.eclipse.wst.server.ui.internal.wizard.TaskWizard$2$1.run (TaskWizard.java:175)
at org.eclipse.ui.internal.UILockListener.doPendingWork(UILockL istener.java:164)
at org.eclipse.ui.internal.UISynchronizer$3.run(UISynchronizer. java:158)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:134)
... 46 more
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:32:32.000
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:32:33.046
!SESSION 2010-12-15 17:40:46.031 -----------------------------------------------
java.version=1.6.0
!ENTRY org.eclipse.core.resources 2 10035 2010-12-15 17:40:50.093
!MESSAGE The workspace exited with unsaved changes in the previous session; refreshing workspace to recover changes.
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:48:29.296
!STACK 0
java.lang.OutOfMemoryError: PermGen space
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:188)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:580)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:550)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:481)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass_LockClassLoader(ClasspathManager.java:469)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:449)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:393)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:469)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:107)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
at org.eclipse.ui.dialogs.ContainerSelectionDialog.createDialog Area(ContainerSelectionDialog.java:134)
at org.eclipse.jface.dialogs.Dialog.createContents(Dialog.java: 760)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
at org.eclipse.jface.window.Window.open(Window.java:790)
at org.eclipse.bpel.apache.ode.deploy.ui.wizards.ODEDeployWizar dPage.handleBrowse(ODEDeployWizardPage.java:125)
at org.eclipse.bpel.apache.ode.deploy.ui.wizards.ODEDeployWizar dPage.access$1(ODEDeployWizardPage.java:121)
at org.eclipse.bpel.apache.ode.deploy.ui.wizards.ODEDeployWizar dPage$2.widgetSelected(ODEDeployWizardPage.java:75)
at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHa ndler(WizardHandler.java:254)
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:48:36.187
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:48:44.500
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:48:52.171
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:48:57.656
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:49:04.250
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:49:15.968
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:49:19.375
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:49:22.937
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:49:48.328
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:49:53.125
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:50:00.875
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:50:04.171
!STACK 0
!ENTRY org.eclipse.ui 4 0 2010-12-15 17:50:13.687
!STACK 0
!SESSION Wed Dec 15 17:51:55 PST 2010 ------------------------------------------
!ENTRY org.eclipse.equinox.launcher 4 0 2010-12-15 17:51:55.671
!MESSAGE Exception launching the Eclipse Platform:
!STACK
Re: Error while creating the HelloWorld Tutorial [message #645149 is a reply to message #645065] Wed, 15 December 2010 12:29 Go to previous messageGo to next message
Hi Bala,
Well, from the looks of the stack trace it looks like your VM has run out of PermGen space Wink
Have a look at this page:
http://help.eclipse.org/helios/index.jsp?topic=/org.eclipse. platform.doc.user/tasks/running_eclipse.htm
which explains how to allocate more memory to eclipse on start up.
Cheers!
Bob
Re: Error while creating the HelloWorld Tutorial [message #674834 is a reply to message #645149] Sat, 28 May 2011 15:43 Go to previous message
These applications are hungry hippos with significant memory footprints.
Is there any way to determine what's happening during builds (PHP website) that causes the memory to spike from ~100M to 800M for a brief period?
I'm curious so maybe, if it's something which doesn't need to be rebuilt all the time, if I can do something like a "precompiled header" equivalent.
[Updated on: Sat, 28 May 2011 15:54] by Moderator
Previous Topic:Unable to start BEPL Designer on Helious, fresh install
Next Topic:BPEL process client
Current Time: Wed Jul 02 20:38:03 EDT 2025
Powered by FUDForum. Page generated in 0.06708 seconds
