| Eclipse keeps freezing [message #546800] |
Wed, 14 July 2010 05:21  |
I have run into some problems with eclipse and hope that someone here can help me.
After installing a JDK (Java 6 Update 21) eclipse freezes when I try to open an java editor.
I've tried the 64bit version of Helios in combination with Java 6
Update 21 (64bit), as well as the 32bits version of Helios in
combination with the 32bit version of the JDK (after uninstalling the
64bit versions), both on the same 64bit Windows 7 computer.
When I force eclipse to close I get the error message:
Java was started but returned exit code= -805306369
C:\Windows\system32\javaw.exe
-Dosgi.requiredJavaVersion=1.5
-Xms40m
-Xmx512m
-jar D:\Program
Files\eclipse\plugins/org.eclipse/equinox.launcher_1.1.0.v20 100507.jar
-os win32
-ws win32
-arch x86_64
-showsplash
-launcher D:\Program Files\eclipse\eclipse.exe
-name Eclipse
--launcher.library D:\Program
org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.0.v2010
0503\eclipse_1307.dll
-startup D:\Program
Files\eclipse\plugins/org.eclipse.equinox.launcher_1.1.0.v20 100507.jar
-exitdata 7c0_58
-product org.eclipse.epp.package.jee.product
-vm C:\Windows\system32\javaw.exe
-vmargs
-Xms40m
-Xmx512m
-jar D:\Program
| Re: Eclipse keeps freezing [message #645525 is a reply to message #645130] |
Fri, 17 December 2010 10:21   |
On 12/15/10 11:36 AM, Nicholas Cross wrote:
> Hi, I have had a similar problem (Java was started but returned error
> code=-805306369) and I have been trying several of the suggested
> solutions but to no avail. I tried adding the -vmargs lines to my
> eclipse.ini and that seemed to work for a week or so, and then the
> problems returned. I then went back to update 20 of jdk1.6.0, but that
> didn't seem to work. I have since updated to update 22, hoping that the
> problems had been solved there, but no joy. I have done more searches
> for a solution. My laptop uses 64bit Windows with Helios 3.61 and there
> were some suggestions that this was a TexLipse spell check error, and
> that I should reset it to the defaults, but this made no impact either.
> There are no errors in the general error log, just warnings.
Did you specify the JVM in your eclipse.ini file, as described in
http://wiki.eclipse.org/Eclipse.ini
Eric
| Re: Eclipse keeps freezing [message #1404520 is a reply to message #1015233] |
Sat, 02 August 2014 16:58  |
Hi, I'm also having almost the same problem, but when ever I turn my Eclipse on, sometimes it would freeze up on me. This problem started at lest 2 and half month ago, when it freezes I would usually just push the rest button when that doesn't work I would let it die then recharge it again and this method usually workered. But on 8/1/14 it froze and I reset it and it didn't work so I let the eclipse die, but now it freezes up also when charging. It wont charge and resting it doesn't work and have been trying to rest then charge again over and over again for the past two day. What do I do? Someone PLEASE help!!!!
FUDForum. Page generated in 0.26476 seconds
