Home » Archived » BIRT » Nested table dataset cache
Nested table dataset cache [message #644949] |
Tue, 14 December 2010 17:48  |
Is there any way to have a nested table filter based on a secondary
dataset - without having to query the database one time for each row in
the parent table?
I am trying to use a filter on the nested table instead of a dataset
parameter:
row['customer_id'] == row._outer['customer_id']
Even though the dataset query for the nested table doesn't change, the
query is still going to the database for each row. Can this data be
cached and reused somehow?
Re: Nested table dataset cache [message #645175 is a reply to message #645145] |
Wed, 15 December 2010 14:14   |
I was able to recreate the problem with a simple query. If the outer
table (using same dataset as inner) returns 0 rows using the query, it
will run over and over for each row in the middle table. This is
probably happening because the cache appears to be empty. I was able to
fix it in my case by adding a dummy row that always returns and will be
filtered out. Is this considered a bug?
Thanks for you help!
On 12/15/2010 12:03 PM, Pinny Markowitz wrote:
> I recreated the scenario you provided and it worked as you said. Adding
> filters or nesting within group rows worked as well. For some reason I'm
> not seeing this behavior in my own report, which is significantly more
> complex. I'll do some more research to see if I can determine where it
> is coming from.
> Thanks!
> On 12/15/2010 11:20 AM, Jason Weathersby wrote:
>> Pinny,
>> The last report I posted did not call the query every time. The outer
>> most table was bound to the same dataset as the innermost table. The
>> only difference was that is was not filtered.
>> Jason
>> On 12/15/2010 10:39 AM, Pinny Markowitz wrote:
>>> Jason
>>> Thanks for responding. Yes, I am using a separate dataset for the nested
>>> table, and using the solution you proposed I am still seeing the
>>> database being queried for each row in the parent table.
>>> A join on the datasets isn't practical since each set holds quite a bit
>>> of detailed data that the other does not. I was actually nesting the
>>> second dataset within a group footer of the parent table because of
>>> this.
>>> Do you know of any other approach that might work? Also, is there a
>>> reason that BIRT doesn't allow filtering on bound report items? Thanks!
>>> On 12/14/2010 7:44 PM, Jason Weathersby wrote:
>>>> One method I tried was to take the dataset used in the inner query and
>>>> bind it to a table and delete everything in the table but the footer
>>>> row
Re: Nested table dataset cache [message #645176 is a reply to message #645175] |
Wed, 15 December 2010 14:18   |
Not sure if its a bug, but log it anyways and we may be able to pick it
up as an enhancement.
Jason
>> is coming from.
>> Thanks!
>>> Pinny,
>>> Jason
>>>> Jason
>>>> nested
>>>> this.
>>>>> row
Re: Nested table dataset cache [message #645185 is a reply to message #645176] |
Wed, 15 December 2010 14:54   |
https://bugs.eclipse.org/bugs/show_bug.cgi?id=332678
Thanks again!
> Jason
>>> is coming from.
>>> Thanks!
>>>> Pinny,
>>>> Jason
>>>>> Jason
>>>>> nested
>>>>> bit
>>>>> this.
>>>>> Thanks!
>>>>>> and
>>>>>> row
Re: Nested table dataset cache [message #645196 is a reply to message #645185] |
Wed, 15 December 2010 16:24  |
Thanks for logging
> Thanks again!
>> Jason
>>>> I'm
>>>> is coming from.
>>>> Thanks!
>>>>> Pinny,
>>>>> Jason
>>>>>> Jason
>>>>>> nested
>>>>>> bit
>>>>>> this.
>>>>>> Thanks!
>>>>>>> and
>>>>>>> row
Current Time: Sun Jul 27 01:56:33 EDT 2025
Powered by FUDForum. Page generated in 0.08856 seconds
