Home » Archived » BIRT » Nested table dataset cache
Nested table dataset cache [message #644949] Tue, 14 December 2010 17:48 Go to next message
Is there any way to have a nested table filter based on a secondary
dataset - without having to query the database one time for each row in
the parent table?
I am trying to use a filter on the nested table instead of a dataset
parameter:
row['customer_id'] == row._outer['customer_id']
Even though the dataset query for the nested table doesn't change, the
query is still going to the database for each row. Can this data be
cached and reused somehow?
Re: Nested table dataset cache [message #644958 is a reply to message #644949] Tue, 14 December 2010 19:27 Go to previous messageGo to next message
Pinny,
I just tried this with 2.6.1 and the dataset only opened once. Take a
look at the attached example.
Does the inner table use a different dataset? If it does you may want
to try adding the dataset to a table before your nested tables set its
visibility to hide it, name it and then bind the inner table to the
report item instead of a dataset.
Jason
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.22"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.6.1.v20100902 Build &lt;2.6.1.v20100915-1750></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="7">
<list-property name="privateDriverProperties">
<ex-property>
<name>contentBidiFormatStr</name>
<value>ILYNN</value>
</ex-property>
<ex-property>
<name>metadataBidiFormatStr</name>
</ex-property>
</list-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="8">
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<text-property
name="displayName">ORDERNUMBER</text-property>
<text-property
name="heading">ORDERNUMBER</text-property>
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<text-property
name="displayName">PRODUCTCODE</text-property>
<text-property
name="heading">PRODUCTCODE</text-property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<text-property
name="displayName">QUANTITYORDERED</text-property>
<text-property
name="heading">QUANTITYORDERED</text-property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<text-property
name="displayName">PRICEEACH</text-property>
<text-property name="heading">PRICEEACH</text-property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<text-property
name="displayName">ORDERLINENUMBER</text-property>
<text-property
name="heading">ORDERLINENUMBER</text-property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<method name="beforeOpen"><![CDATA[importPackage(
Packages.java.io );
out = new PrintWriter( new FileWriter( "c:/test/cachenestedevents.txt",
true ) );
out.println( "beforeOpen Event");
out.close();
]]></method>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<xml-property name="queryText"><![CDATA[select *
from orderdetails]]></xml-property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>QUANTITYORDERED</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>PRICEEACH</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:uiHints>
<design:displayName>ORDERLINENUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
</design:resultSetColumns>
<design:criteria/>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>
]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table name="outer" id="9">
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<text-property
<expression name="expression"
type="javascript">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["QUANTITYORDERED"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["PRICEEACH"]</expression>
</structure>
<structure>
<text-property
type="javascript">dataSetRow["ORDERLINENUMBER"]</expression >
</structure>
</list-property>
<column id="38"/>
<column id="46"/>
<header>
<row id="10">
<cell id="11">
<label id="12">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="43"/>
</row>
</header>
<detail>
<row id="21">
<cell id="22">
<data id="23">
<property name="whiteSpace">nowrap</property>
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="44">
<table name="inner" id="47">
<structure>
<property
<text-property
<property
</structure>
<structure>
<property
<text-property
<property
</structure>
<structure>
<property
<text-property
<property
</structure>
<structure>
<property
<text-property
<property
</structure>
<structure>
<property
<text-property
<property
</structure>
</list-property>
<list-property name="filter">
<structure>
<property name="operator">eq</property>
<expression name="expr"
type="javascript">row["ORDERNUMBER"]</expression>
<simple-property-list name="value1">
<value>row._outer["ORDERNUMBER"]</value>
</simple-property-list>
</structure>
</list-property>
<column id="76"/>
<column id="77"/>
<column id="78"/>
<column id="79"/>
<column id="80"/>
<header>
<row id="48">
<cell id="49">
<label id="50">
<text-property
</label>
</cell>
<cell id="51">
<label id="52">
<text-property
name="text">PRODUCTCODE</text-property>
</label>
</cell>
<cell id="53">
<label id="54">
<text-property
name="text">QUANTITYORDERED</text-property>
</label>
</cell>
<cell id="55">
<label id="56">
<text-property
name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="57">
<label id="58">
<text-property
name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="59">
<cell id="60">
<data id="61">
<property
<property
</data>
</cell>
<cell id="62">
<data id="63">
<property
<property
name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="64">
<data id="65">
<property
<property
name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="66">
<data id="67">
<property
<property
name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
<cell id="68">
<data id="69">
<property
<property
name="resultSetColumn">ORDERLINENUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="70">
<cell id="71"/>
<cell id="72"/>
<cell id="73"/>
<cell id="74"/>
<cell id="75"/>
</row>
</footer>
</table>
</cell>
</row>
</detail>
<footer>
<row id="32">
<cell id="33"/>
<cell id="45"/>
</row>
</footer>
</table>
</body>
</report>
> the parent table?
> parameter:
Re: Nested table dataset cache [message #644960 is a reply to message #644958] Tue, 14 December 2010 19:44 Go to previous messageGo to next message
Pinny
Dont bother with the report item binding. You will not be able to put a
filter on it. One method I tried was to take the dataset used in the
inner query and bind it to a table and delete everything in the table
but the footer row. Then drag your nested tables into this footer. It
looks like it may work. Probably faster to do a join in the dataset but
it may work for you. Take a look at the attached example.
Jason
id="1">
<data-sources>
<oda-data-source
id="7">
<ex-property>
</ex-property>
<ex-property>
</ex-property>
</list-property>
<property
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set
<structure>
<text-property
<text-property
</structure>
<structure>
<text-property
<text-property
</structure>
<structure>
<text-property
<text-property
</structure>
<structure>
<text-property
</structure>
<structure>
<text-property
<text-property
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
Packages.java.io );
true ) );
out.close();
]]></method>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<model:DesignValues
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:criteria/>
]]></xml-property>
</oda-data-set>
<oda-data-set
name="orders" id="149">
<structure>
<text-property
<text-property
</structure>
<structure>
<property name="columnName">ORDERDATE</property>
<text-property
name="displayName">ORDERDATE</text-property>
<text-property name="heading">ORDERDATE</text-property>
</structure>
<structure>
<property name="columnName">REQUIREDDATE</property>
<text-property
name="displayName">REQUIREDDATE</text-property>
<text-property
name="heading">REQUIREDDATE</text-property>
</structure>
<structure>
<property name="columnName">SHIPPEDDATE</property>
<text-property
name="displayName">SHIPPEDDATE</text-property>
<text-property
name="heading">SHIPPEDDATE</text-property>
</structure>
<structure>
<property name="columnName">STATUS</property>
<text-property
name="displayName">STATUS</text-property>
<text-property name="heading">STATUS</text-property>
</structure>
<structure>
<property name="columnName">COMMENTS</property>
<text-property
name="displayName">COMMENTS</text-property>
<text-property name="heading">COMMENTS</text-property>
</structure>
<structure>
<property name="columnName">CUSTOMERNUMBER</property>
<text-property
name="displayName">CUSTOMERNUMBER</text-property>
<text-property
name="heading">CUSTOMERNUMBER</text-property>
</structure>
</list-property>
<structure>
</structure>
<structure>
<property name="name">ORDERDATE</property>
<property name="dataType">date</property>
</structure>
<structure>
<property name="name">REQUIREDDATE</property>
</structure>
<structure>
<property name="name">SHIPPEDDATE</property>
</structure>
<structure>
<property name="name">STATUS</property>
</structure>
<structure>
<property name="position">6</property>
<property name="name">COMMENTS</property>
</structure>
<structure>
<property name="position">7</property>
<property name="name">CUSTOMERNUMBER</property>
</structure>
</list-property>
</structure>
Packages.java.io );
out = new PrintWriter( new FileWriter( "c:/test/2cachenestedevents.txt",
true ) );
out.close();]]></method>
<structure>
</structure>
<structure>
<property name="nativeName">ORDERDATE</property>
<property name="nativeDataType">91</property>
</structure>
<structure>
<property name="nativeName">REQUIREDDATE</property>
</structure>
<structure>
<property name="nativeName">SHIPPEDDATE</property>
</structure>
<structure>
<property name="nativeName">STATUS</property>
</structure>
<structure>
<property name="nativeName">COMMENTS</property>
</structure>
<structure>
<property name="nativeName">CUSTOMERNUMBER</property>
</structure>
</list-property>
from orders]]></xml-property>
<model:DesignValues
<design:attributes>
<design:uiHints>
</design:uiHints>
<design:usageHints>
<design:attributes>
<design:name>ORDERDATE</design:name>
<design:nativeDataTypeCode>91</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>ORDERDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERDATE</design:label>
<design:displaySize>10</design:displaySize>
<design:attributes>
<design:name>REQUIREDDATE</design:name>
<design:uiHints>
<design:displayName>REQUIREDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>REQUIREDDATE</design:label>
<design:attributes>
<design:name>SHIPPEDDATE</design:name>
<design:uiHints>
<design:displayName>SHIPPEDDATE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>SHIPPEDDATE</design:label>
<design:attributes>
<design:name>STATUS</design:name>
<design:uiHints>
<design:displayName>STATUS</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>STATUS</design:label>
<design:attributes>
<design:name>COMMENTS</design:name>
<design:position>6</design:position>
<design:precision>32700</design:precision>
<design:uiHints>
<design:displayName>COMMENTS</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>COMMENTS</design:label>
<design:displaySize>32700</design:displaySize>
<design:attributes>
<design:name>CUSTOMERNUMBER</design:name>
<design:position>7</design:position>
<design:uiHints>
<design:displayName>CUSTOMERNUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>CUSTOMERNUMBER</design:label>
<design:criteria/>
]]></xml-property>
</oda-data-set>
</data-sets>
<styles>
</style>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property
</text>
</page-footer>
</page-setup>
<body>
<table id="280">
<property name="dataSet">orders</property>
<structure>
<text-property
</structure>
<structure>
<text-property
type="javascript">dataSetRow["ORDERDATE"]</expression>
</structure>
<structure>
<text-property
type="javascript">dataSetRow["REQUIREDDATE"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["SHIPPEDDATE"]</expression >
</structure>
<structure>
<text-property
type="javascript">dataSetRow["STATUS"]</expression>
</structure>
<structure>
<text-property
type="javascript">dataSetRow["COMMENTS"]</expression>
</structure>
<structure>
<text-property
type="javascript">dataSetRow["CUSTOMERNUMBER"]</expression >
</structure>
</list-property>
<column id="319"/>
<footer>
<row id="311">
<cell id="312">
<table name="myouter" id="150">
<structure>
<property
<text-property
<property
</structure>
<structure>
<property
<text-property
<property
</structure>
<structure>
<property
<text-property
<property
</structure>
<structure>
<property
<text-property
<property
</structure>
<structure>
<property
<text-property
<property
</structure>
</list-property>
<column id="179"/>
<column id="187"/>
<header>
<row id="151">
<cell id="152">
<label id="153">
<text-property
</label>
</cell>
<cell id="184"/>
</row>
</header>
<detail>
<row id="162">
<cell id="163">
<data id="164">
<property
<property
</data>
</cell>
<cell id="185">
<table name="myinner" id="188">
<property
<list-property
<structure>
<property
<text-property
<expression
name="expression" type="javascript">dataSetRow["ORDERNUMBER"]</expression >
<property
</structure>
<structure>
<property
<text-property
<expression
name="expression" type="javascript">dataSetRow["ORDERDATE"]</expression>
<property
</structure>
<structure>
<property
<text-property
<expression
name="expression" type="javascript">dataSetRow["REQUIREDDATE"]</expression >
<property
</structure>
<structure>
<property
<text-property
<expression
name="expression" type="javascript">dataSetRow["SHIPPEDDATE"]</expression >
<property
</structure>
<structure>
<property
<text-property
<expression
name="expression" type="javascript">dataSetRow["STATUS"]</expression>
<property
</structure>
<structure>
<property
<text-property
<expression
name="expression" type="javascript">dataSetRow["COMMENTS"]</expression>
<property
</structure>
<structure>
<property
<text-property
<expression
name="expression"
<property
</structure>
</list-property>
<structure>
<property
<expression
name="expr" type="javascript">row["ORDERNUMBER"]</expression>
</structure>
</list-property>
<column id="227"/>
<column id="228"/>
<column id="233"/>
<header>
<row id="189">
<cell id="190">
<label id="191">
<text-property name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="192">
<label id="193">
<text-property name="text">ORDERDATE</text-property>
</label>
</cell>
<cell id="202">
<label id="203">
<text-property name="text">CUSTOMERNUMBER</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="204">
<property
name="backgroundColor">#FF8080</property>
<cell id="205">
<data id="206">
<property
<property
</data>
</cell>
<cell id="207">
<data id="208">
<property
<property
name="resultSetColumn">ORDERDATE</property>
</data>
</cell>
<cell id="217">
<data id="218">
<property
<property
name="resultSetColumn">CUSTOMERNUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="219">
<cell id="220"/>
<cell id="221"/>
<cell id="226"/>
</row>
</footer>
</table>
</cell>
</row>
</detail>
<footer>
<row id="173">
<cell id="174"/>
<cell id="186"/>
</row>
</footer>
</table>
</cell>
</row>
</footer>
</table>
</body>
</report>
On 12/14/2010 7:27 PM, Jason Weathersby wrote:
> Pinny,
> Does the inner table use a different dataset? If it does you may want to
> Jason
> Jason
> id="1">
> <property name="createdBy">Eclipse BIRT Designer Version 2.6.1.v20100902
> <data-sources>
> <oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc"
> name="Data Source" id="7">
> <ex-property>
> </ex-property>
> <ex-property>
> </ex-property>
> </list-property>
> <property
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> <text-property name="displayName">O
Re: Nested table dataset cache [message #645115 is a reply to message #644960] Wed, 15 December 2010 10:39 Go to previous messageGo to next message
Jason
Thanks for responding. Yes, I am using a separate dataset for the
nested table, and using the solution you proposed I am still seeing the
database being queried for each row in the parent table.
A join on the datasets isn't practical since each set holds quite a bit
of detailed data that the other does not. I was actually nesting the
second dataset within a group footer of the parent table because of this.
Do you know of any other approach that might work? Also, is there a
reason that BIRT doesn't allow filtering on bound report items? Thanks!
On 12/14/2010 7:44 PM, Jason Weathersby wrote:
> One method I tried was to take the dataset used in the inner query and
> bind it to a table and delete everything in the table but the footer row
Re: Nested table dataset cache [message #645132 is a reply to message #645115] Wed, 15 December 2010 11:20 Go to previous messageGo to next message
Pinny,
The last report I posted did not call the query every time. The outer
most table was bound to the same dataset as the innermost table. The
only difference was that is was not filtered.
Jason
On 12/15/2010 10:39 AM, Pinny Markowitz wrote:
> Jason
> Thanks for responding. Yes, I am using a separate dataset for the nested
Re: Nested table dataset cache [message #645145 is a reply to message #645132] Wed, 15 December 2010 12:03 Go to previous messageGo to next message
I recreated the scenario you provided and it worked as you said. Adding
filters or nesting within group rows worked as well. For some reason
I'm not seeing this behavior in my own report, which is significantly
more complex. I'll do some more research to see if I can determine
where it is coming from.
Thanks!
On 12/15/2010 11:20 AM, Jason Weathersby wrote:
> Pinny,
> Jason
>> Jason
Re: Nested table dataset cache [message #645175 is a reply to message #645145] Wed, 15 December 2010 14:14 Go to previous messageGo to next message
I was able to recreate the problem with a simple query. If the outer
table (using same dataset as inner) returns 0 rows using the query, it
will run over and over for each row in the middle table. This is
probably happening because the cache appears to be empty. I was able to
fix it in my case by adding a dummy row that always returns and will be
filtered out. Is this considered a bug?
Thanks for you help!
> filters or nesting within group rows worked as well. For some reason I'm
> not seeing this behavior in my own report, which is significantly more
> complex. I'll do some more research to see if I can determine where it
> is coming from.
> Thanks!
>> Pinny,
>> Jason
>>> Jason
>>> this.
>>>> row
Re: Nested table dataset cache [message #645176 is a reply to message #645175] Wed, 15 December 2010 14:18 Go to previous messageGo to next message
Not sure if its a bug, but log it anyways and we may be able to pick it
up as an enhancement.
Jason
>> is coming from.
>> Thanks!
>>> Pinny,
>>> Jason
>>>> Jason
>>>> nested
>>>> this.
>>>>> row
Re: Nested table dataset cache [message #645185 is a reply to message #645176] Wed, 15 December 2010 14:54 Go to previous messageGo to next message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=332678
Thanks again!
> Jason
>>> is coming from.
>>> Thanks!
>>>> Pinny,
>>>> Jason
>>>>> Jason
>>>>> nested
>>>>> bit
>>>>> this.
>>>>> Thanks!
>>>>>> and
>>>>>> row
Re: Nested table dataset cache [message #645196 is a reply to message #645185] Wed, 15 December 2010 16:24 Go to previous message
Thanks for logging
> Thanks again!
>> Jason
>>>> I'm
>>>> is coming from.
>>>> Thanks!
>>>>> Pinny,
>>>>> Jason
>>>>>> Jason
>>>>>> nested
>>>>>> bit
>>>>>> this.
>>>>>> Thanks!
>>>>>>> and
>>>>>>> row
Previous Topic:Iportal
Next Topic:Server Side Paging
Current Time: Tue Jul 22 22:23:12 EDT 2025
Powered by FUDForum. Page generated in 0.27279 seconds
