Missing serialized package: uml.ecore [message #644857] |
Tue, 14 December 2010 08:52  |
i used GMF to create a simple PackageDiagram editor on top of the Eclipse UML2 Metamodel. When i start the editor in a runtime workbench and try to create a new package diagram i get the following exceptions:
!MESSAGE An error occurred while automatically activating bundle de.ubt.ai1.packagediagram.diagram (174).
!STACK 0
org.osgi.framework.BundleException: Exception in de.ubt.ai1.packagediagram.part.UMLDiagramEditorPlugin.start() of bundle de.ubt.ai1.packagediagram.diagram.
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:806)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:755)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:370)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:284)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:417)
at org.eclipse.osgi.internal.loader.BundleLoader.setLazyTrigger(BundleLoader.java:265)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLazyStarter.java:106)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java:453)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoader.java:216)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass(BundleLoader.java:393)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:469)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:422)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(BundleLoader.java:338)
at org.eclipse.osgi.framework.internal.core.BundleHost.loadClass(BundleHost.java:232)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.loadClass(AbstractBundle.java:1197)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:174)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:904)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugin.java:267)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:263)
at org.eclipse.ui.internal.dialogs.WorkbenchWizardElement.createExecutableExtension(WorkbenchWizardElement.java:120)
at org.eclipse.ui.internal.dialogs.WorkbenchWizardElement.createWizard(WorkbenchWizardElement.java:264)
at org.eclipse.ui.internal.dialogs.NewWizardNewPage$5.createWizard(NewWizardNewPage.java:728)
at org.eclipse.ui.internal.dialogs.WorkbenchWizardNode$2.run(WorkbenchWizardNode.java:151)
at org.eclipse.ui.internal.dialogs.WorkbenchWizardNode$1.run(WorkbenchWizardNode.java:135)
at org.eclipse.ui.internal.dialogs.WorkbenchWizardNode.getWizard(WorkbenchWizardNode.java:132)
at org.eclipse.jface.wizard.WizardSelectionPage.getNextPage(WizardSelectionPage.java:104)
at org.eclipse.ui.internal.dialogs.WorkbenchWizardSelectionPage.getNextPage(WorkbenchWizardSelectionPage.java:100)
at org.eclipse.ui.internal.dialogs.NewWizardSelectionPage.advanceToNextPageOrFinish(NewWizardSelectionPage.java:71)
at org.eclipse.ui.internal.dialogs.NewWizardNewPage$1.doubleClick(NewWizardNewPage.java:354)
at org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredViewer.java:824)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(StructuredViewer.java:822)
at org.eclipse.jface.viewers.AbstractTreeViewer.handleDoubleSelect(AbstractTreeViewer.java:1421)
at org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSelected(StructuredViewer.java:1225)
at org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEvent(OpenStrategy.java:238)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.java:235)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:296)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.handlers.WizardHandler$New.executeHandler(WizardHandler.java:254)
at org.eclipse.ui.internal.handlers.WizardHandler.execute(WizardHandler.java:274)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
Caused by: java.lang.ExceptionInInitializerError
at org.eclipse.uml2.uml.util.UMLSwitch.<init>(UMLSwitch.java:300)
at org.eclipse.uml2.uml.util.UMLAdapterFactory$1.<init>(UMLAdapterFactory.java:327)
at org.eclipse.uml2.uml.util.UMLAdapterFactory.<init>(UMLAdapterFactory.java:327)
at org.eclipse.uml2.uml.edit.providers.UMLItemProviderAdapterFactory.<init>(UMLItemProviderAdapterFactory.java:104)
at de.ubt.ai1.packagediagram.part.UMLDiagramEditorPlugin.fillItemProviderFactories(UMLDiagramEditorPlugin.java:118)
at de.ubt.ai1.packagediagram.part.UMLDiagramEditorPlugin.createAdapterFactory(UMLDiagramEditorPlugin.java:110)
at de.ubt.ai1.packagediagram.part.UMLDiagramEditorPlugin.start(UMLDiagramEditorPlugin.java:83)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1.run(BundleContextImpl.java:783)
at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextImpl.java:774)
... 88 more
Caused by: java.lang.RuntimeException: Missing serialized package: uml.ecore
at org.eclipse.uml2.uml.internal.impl.UMLPackageImpl.loadPackage(UMLPackageImpl.java:16831)
at org.eclipse.uml2.uml.internal.impl.UMLPackageImpl.init(UMLPackageImpl.java:1965)
at org.eclipse.uml2.uml.UMLPackage.<clinit>(UMLPackage.java:83)
... 98 more
I checked out everything from the org.eclipse.uml2 project and all of these plugins are part of my runtime workbench. What could be the reason for this error?
Thanks in advance,
Thomas
FUDForum. Page generated in 0.07450 seconds
