Re: VE 1.5 release review [message #650232 is a reply to message #644688] |
Sun, 23 January 2011 09:03  |
Eclipse User wrote on Mon, 13 December 2010 14:01 | Originally posted by: richkulp.us.NOSPAM.ibm.com
By default on a java file the Java editor is the default editor. But
once you open as a different editor (such as VE), that editor then
becomes the default. It stores this in the workspace, not in a CVS/Team/etc.
When you created the class you probably used a VE wizard so that the
class was opened up with VE immediately, and so VE becomes the default
for that class instance.
So when you are on a new computer you are in a new workspace so it
switches to the default java editor. You can then do Open As -> and
select the VE instead.
Rich Kulp
thanks,Rich Kulp
FUDForum. Page generated in 0.24336 seconds
