Home » Modeling » EMF » Debug Variables view and EObject Logical Structure
Debug Variables view and EObject Logical Structure [message #644100] Thu, 09 December 2010 08:50 Go to next message
I'm using dynamic EObjects a lot and when debugging it is very difficult
to see the the feature values. Eclipse provides so-called Logical
Structures for providing custom tree views of objects. I wonder if
anyone has tried to provide such for EObjects? I have tried myself, but
haven't been able to create a working snippet. The following gives the
error that the package org.eclipse.emf.js4emf cannot be found:
org.eclipse.emf.common.util.EList<org.eclipse.emf.eco re.EStructuralFeature>
features = this.eClass().getEAllStructuralFeatures();
java.util.Map.Entry[] entries = new java.util.Map.Entry[features.size()];
for (int i = 0; i < features.size(); i++) {
org.eclipse.emf.ecore.EStructuralFeature feature = features.get(i);
entries[i] = new
org.eclipse.emf.js4emf.ui.MapEntryImpl(feature.getName(),
this.eGet(feature));
return entries;
Hallvard
Re: Debug Variables view and EObject Logical Structure [message #644163 is a reply to message #644100] Thu, 09 December 2010 12:30 Go to previous messageGo to next message
Hallvard,
Comments below.
Hallvard Trætteberg wrote:
> difficult to see the the feature values. Eclipse provides so-called
> Logical Structures for providing custom tree views of objects. I
> wonder if anyone has tried to provide such for EObjects?
Yes, I know that IBM did such a thing internally.
> I have tried myself, but haven't been able to create a working
> snippet. The following gives the error that the package
> entries[i] = new
What's giving that error. Are you missing a dependency in the
MANIFEST.MF for this? Do you really need a special implementation of
the map entry? I.e., why not just use a linked hash map?
> return entries;
> Hallvard
Re: Debug Variables view and EObject Logical Structure [message #644287 is a reply to message #644163] Fri, 10 December 2010 07:07 Go to previous messageGo to next message
> MANIFEST.MF for this? Do you really need a special implementation of the
I also thought the problem was a missing dependency, but the package is
exported and in the same plugin as the extension point. The strange
thing is that the MapEntryImpl is in org.eclipse.emf.js4emf.ui, not
org.eclipse.emf.js4emf. I don't know exactly in what context the code
snippet is evaluated in, so it's difficult to interpret to message.
The snippet should return the logical contents of the EObject, so I
though it needed to return an array of entries, rather than a Map. But
you're right, it works with a map, as follows:
org.eclipse.emf.common.util.ELis<org.eclipse.emf.ecore.EStructuralFeature >
java.util.Map map = new java.util.HashMap();
map.put(feature.getName(), this.eGet(feature));
return map;
You get the look & feel of an array of key/value pairs, though, not a
list of fields like in the native case.
I guess registering this snippet for
org.eclipse.emf.ecore.impl.DynamicEObjectImpl is best, although it may
also be used for subclasses with dynamic features.
Hallvard
Re: Debug Variables view and EObject Logical Structure [message #644301 is a reply to message #644287] Fri, 10 December 2010 08:09 Go to previous messageGo to next message
Hallvard,
Comments below.
> is exported and in the same plugin as the extension point. The strange
You can't run it under debug control to set breakpoints?
> return map;
A LinkedHashMap is likely to give you a more predictable/determinstic
feature order.
Yes, it's nice to hide lots of the implementation details. One might
test for things like being a proxy and show things like the eContainer
or eDirectResource; stuff that's lurking in the properties holder or the
array of slots in MinimalEObjectImpl...
Not sure how the registration works (you can't register it against an
interface like InternalEObject?) but it's expected that all
implementations of EObject ultimately extend BasicEObjectImpl.
> Hallvard
Re: Debug Variables view and EObject Logical Structure [message #644560 is a reply to message #644301] Mon, 13 December 2010 04:41 Go to previous message
I don't see a way of setting breakpoints in the snippet, since the
snippet is not technically part of the code that is debugged. From the
code, I get the impression that the snippet is executed "internally"
within the debug machinery on "the other side".
> feature order.
OK.
The registration is for a class/interface (name). The key is to enable
it for implementations that are *not* generated, since these will
normally have a nice tree view with easily identifyable features.
Hallvard
Previous Topic:[GWT] How to transfer EMF models without Google App Engine
Next Topic:Securing the save process in EMF
Current Time: Thu Jul 17 23:50:54 EDT 2025
Powered by FUDForum. Page generated in 0.07656 seconds
