Home » Eclipse Projects » Eclipse 4 » e4xmi tooling and Linux(Problems with Workbenchmodel Editor and Visual Design Editor)
e4xmi tooling and Linux [message #644450] Sat, 11 December 2010 10:23 Go to next message
Hi all,
I just started playing around a bit with e4 (0.11 Stream Integration Build, build id: I20101210-1840). While trying to work through some tutorials I noticed that there seem to be some poblems in my Linux installation.
If I open an e4xmi file with the "Workbenchmodel Editor", it shows only the content frame with one single entry. There is no palette or any other tooling visible.
The Visual Design Editor (I guess this one has been installed with XWT) can't open it, too.
Has anybody seen similar problems? Is this related to the Linux version (not really looking forward to trying Windows)? Is there any difference to be expected when using M3 instead of the latest integration build?
Thanks for your help!
Greetings from Germany
Axel
Re: e4xmi tooling and Linux [message #644456 is a reply to message #644450] Sat, 11 December 2010 11:39 Go to previous messageGo to next message
You are seeing https://bugs.eclipse.org/bugs/show_bug.cgi?id=332362
which is found out today and fixed in CVS.
M3 should be ok but naturally there are many internal changes the only
change users might be affected in is the one the e4xmi-Tooling has
problems with.
Tom
Am 11.12.10 16:23, schrieb Axel Guckelsberger:
> Hi all,
> installation.
> can't open it, too.
> Axel
Re: e4xmi tooling and Linux [message #644570 is a reply to message #644450] Mon, 13 December 2010 05:18 Go to previous message
Hi Tom, thank you for clarification.
Will try out the next integration build and look if things changed there.
Axel
Previous Topic:XWT log and exception handling
Next Topic:Toolbar and View Menu in a part
Current Time: Fri Jul 18 20:55:26 EDT 2025
Powered by FUDForum. Page generated in 0.05548 seconds
