Home » Eclipse Projects » Remote Application Platform (RAP) » Server session timed out for two RAP instance in same browser
Server session timed out for two RAP instance in same browser [message #644376] Fri, 10 December 2010 12:46 Go to next message
I am running two RAP applications (they each run on their own JVM) and
I'm trying to access them using two tabs on the same browser. However,
when I do that, accessing one application will give the message "The
server session timed out". Accessing both application from different
browser works fine though. Is that an expected behavior? Is there a way
to avoid this problem?
Thanks a lot,
Jean
Re: Server session timed out for two RAP instance in same browser [message #644394 is a reply to message #644376] Fri, 10 December 2010 15:49 Go to previous messageGo to next message
Hi Jean,
see this bug:
285398: Enable tabbed browsing
https://bugs.eclipse.org/bugs/show_bug.cgi?id=285398
and this FAQ entry:
http://wiki.eclipse.org/RAP/FAQ#How_to_run_a_RAP_application _in_multiple_browser_tabs.2Fwindows.3F
HTH,
Ivan
On 10.12.2010 7:46 PM, Jean Bovet wrote:
> way to avoid this problem?
> Thanks a lot,
> Jean
Re: Server session timed out for two RAP instance in same browser [message #644399 is a reply to message #644394] Fri, 10 December 2010 17:01 Go to previous messageGo to next message
Hi Ivan,
Yes, I've seen these entries but they concern a single application
access in a multi-tabbed browser or multi-browser. I am getting an
issue when accessing two separate instances of the same application
within one browser (each application in its own tab). Each application
is listening on its own port.
Jean
On 2010-12-10 12:49:20 -0800, Ivan Furnadjiev said:
> Hi Jean,
> see this bug:
> and this FAQ entry:
HTH,
Ivan
On
>> Hi,
>> Thanks a lot,
>> Jean
Re: Server session timed out for two RAP instance in same browser [message #644403 is a reply to message #644399] Fri, 10 December 2010 17:57 Go to previous messageGo to next message
Jean,
Are your two applications on the same server and/or domain? I think this is related to session cookies. Each application is giving you its own session id which is getting put into a cookie (typically something like JSESSIONID). The problem is that browsers are designed to send cookies based on the domain so that something like http://store.com/cart and http://store.com/item will get the same cookies and be able to determine the proper session to use. What happens with RAP is that the cookie from the second server you connect to will overwrite the first. Then when you send a new request to the first (e.g., click a button), it will send the cookie from the second server. The first server will not have a record of that session and will send you the error.
The solution to this problem should be the same as the solution for multiple tabs on a single application: pass the session id on the URL instead of as a cookie. The FAQ entry Ivan referenced should explain how to set this up.
Cole
Re: Server session timed out for two RAP instance in same browser [message #644424 is a reply to message #644403] Fri, 10 December 2010 23:32 Go to previous messageGo to next message
Thanks for the explanation, that is clear now. Thanks Ivan too. I will
try that this week-end and will let you know how that works.
Jean
On 2010-12-10 14:57:15 -0800, Cole Markham said:
> Jean,
> how to set this up.
> Cole
Re: Server session timed out for two RAP instance in same browser [message #644446 is a reply to message #644424] Sat, 11 December 2010 08:29 Go to previous messageGo to next message
Originally posted by: sroeck.heiler.com
Hi Jean,
another option could be to assign two different domain names to your two
applications. In this case, cookies should not be shared. I just learned
from [1] that this does not apply for ports.
Stefan.
[1]
http://stackoverflow.com/questions/1612177/are-http-cookies- port-specific
Re: Server session timed out for two RAP instance in same browser [message #644525 is a reply to message #644424] Sun, 12 December 2010 20:06 Go to previous message
Works great, thanks for your help! I must say that I really love RAP :-)
Jean
On 2010-12-10 20:32:21 -0800, Jean Bovet said:
> Regards,
> Jean
>> Jean,
>> how to set this up.
>> Cole
Previous Topic:SessionSingletonBase reset each time the page is refreshed
Next Topic:CSS for Toolbar Separator
Current Time: Sat Jul 26 16:09:46 EDT 2025
Powered by FUDForum. Page generated in 0.06587 seconds
