Home » Modeling » GMF (Graphical Modeling Framework) » Validation, Dangling Edges and EMF-View
| Validation, Dangling Edges and EMF-View [message #60587] |
Mon, 09 October 2006 07:02  |
Originally posted by: tobk.gmx.de
I have some more questions and I'd be happy if anyone could help me.
1.: Is there an advantage in using OCL for describing validaition
constraints instead of java making it the default option? I can't imagine
it being faster, since it has to be parsed and interpreted first, and
everybody using Eclipse hould know Java, but not everybody knows OCL (like
me). Further, the Java constraints can be modified in Debug mode while the
OCl constraint might require several generation runs for debigging. I'd
just like to know if there's any big plus for OCL that I'm missing.
2.: What method do I have to tweak so that all of a node's edges are deleted
with the node? Right now, only the node is deleted. The connections are
removed from the diagram, but not from the model (if the node contains the
connection, the connection is deleted too, but the references on the
connection, e.g. from the target remain). I searched the web, but did not
find an answer yet. Could you tell me what to do or give me a reference?
3.: I posted a similar question some time ago. Is three a way to integrate
the generated EMF-Editor as an extra view or - even better - as additional
pages for the main view (like "Diagram | Selection | Parent | List | ..."?
Tobias
| Re: Validation, Dangling Edges and EMF-View [message #62170 is a reply to message #60625] |
Fri, 13 October 2006 09:10   |
>> deleted with the node? Right now, only the node is deleted. The
>> connections are removed from the diagram, but not from the model (if the
>> node contains the connection, the connection is deleted too, but the
>> references on the connection, e.g. from the target remain). I searched
>> the web, but did not find an answer yet. Could you tell me what to do or
> public abstract class EndEditHelper extends AbstractEditHelper {
Thank you for the reply, but somehow I don't get this to work. The method is
not even called when I delete the node (yes, I put it in the right edit
helper. that was my first thought, but I checked it ten times now ;-) ).
And even more strange: The method is called in the AbstractEditHelper
class, but neither in the actual NodeEditHelper nor in the BaseEditHelper
classes, both extending the abstractedithelper.
I also tried putting the method in another EditHelper that's already used
with another getCommand method (getReorientConnectionCommand), but even
there the overriding method is not called, but only the one in the abstract
edit helper. I copied the method signatures, so I can exclude a spelling
mistake, too.
tobias
| Re: Validation, Dangling Edges and EMF-View [message #62265 is a reply to message #62170] |
Fri, 13 October 2006 11:39   |
Originally posted by: vcciubot.uwaterloo.ca
If I remember correctly, the generated edit helpers have a base class that
overrides getInsteadCommand() that does the actual routing of a Request to
the the corresponding method call.
Please check that to see if that's what's breaking things.
vlad
> mistake, too.
> tobias
| Re: Validation, Dangling Edges and EMF-View [message #62383 is a reply to message #62265] |
Sat, 14 October 2006 06:43   |
That's right, but this method only collects the corresponding commands from
the edit policy and the edit helper (invoking the super method) and returns
them (only one, if the other is null or via a compound command).
Meanwhile I really think that the actual EditHelper is not associated
correctly with the EditPart: I placed an overriding getInsteadCommand in
the EditHelper, returning the required command and else the super method's
results, but debugging says that it is not used, but only the
baseEditHelper's! Instead, it is used when selecting a connection next to
that node, and the connections getInsteadCommand is not entered, but when I
try to reorient the Connection. How can this be? Is this normal behavior?
In case this was a little bit confusing:
- I have some Nodes and Connections
- both EditHelpers override getInsteadCommand, with a breakpoint inside and
calling the super method, just to see when it's called
- when I select or delete the node, the BaseEditHelper's getinsteadCommand
is called, but not the actual node's EditHelper's.
- when I select or delete a *connection* connected to the node, the *node*'s
EditHelper's getInsteadCommand is called (with a destroy request)
- when I try to reorient the connection, the connection's helper's
tobias
| Re: Validation, Dangling Edges and EMF-View [message #62800 is a reply to message #62383] |
Sun, 15 October 2006 13:28   |
Hi Tobias,
Export those plugins to a zip file and send them to me.
cheers
vlad
> tobias
| Re: Validation, Dangling Edges and EMF-View [message #64156 is a reply to message #62800] |
Tue, 17 October 2006 09:56   |
> Hi Tobias,
> cheers
> vlad
Thanks for the offer, but the problem seems to be solved in the GMF 2.0
Stream Stable Build. The getXXXCommand method now is entered in the correct
edit helper. However, there's still another problem:
All the incoming and outgoing connections are added to the Set of
connections to be deleted, but those connections, that are a child of the
node are not deleted.
In my model all the connections are contained in their source node. Reason
for this is that I have many levels of elements, and other than saving all
the connections in the canvas element or something like that this prevents
this nasty duplicate connections bug from happening.
Should I modify the getdeleteDependentCommand method in some way it
correctly deletes the children [1] or is there any workaround for the
duplicate connections bug? Or will this bug be fixed in the final GMF 2.0?
[1] the connections are deleted (since they are children of the node), but
not in a clean way. all references pointing on the connections persist. By
the way this applies for all kind of child references: when I delete some
model element with children being references outside of that element, these
references persist when I delete the element. Is there a reason why this is
not handled automatically?
tobias
| Re: Validation, Dangling Edges and EMF-View [message #64432 is a reply to message #64156] |
Tue, 17 October 2006 12:15   |
getdeleteDependentCommand could delete various referenced eobjects, those
contained in the current object are automatically deleted.
This command operates solely on the model.
Delete commands are returned by the component edit policy. If your
container of the object is canonical this policy performs a semantic
delete and delegates to the canonical policy to remove the view.
There's a very simple work around for this bug: Override in
GraphicalNodeEditPolicy this command:
protected Command getConnectionAndRelationshipCompleteCommand()
Basically, copy & paste from super and comment out this line:
//cc.compose( new CommandProxy(viewCommand) );
This way the command produces only the semantic update and allows the
canonical policy to resynchronize.
> Should I modify the method in some way it
See above.
Delete them explicitly from the edit helper.
| Re: Validation, Dangling Edges and EMF-View [message #65852 is a reply to message #65574] |
Thu, 19 October 2006 14:04  |
> 1.: for DetroyElementRequests the getInsteadCommand returns only the edit
> helper's command, ignoring the edit policy's
That's basically what I have too. I've totally removed the customized
semantic policy, running with the vanilla one installed in
GraphicalEditPart. The default behaviour in that policy is to delegate
everything to the edit helper.
> 2.: getDestroyCommand returns super
same here
> 3.: getDestroyDependantsCommand returns super, if the list of dependants is
> empty
same here
Current Time: Tue Dec 02 03:04:46 EST 2025
Powered by FUDForum. Page generated in 0.05671 seconds
