Home » Modeling » GMF (Graphical Modeling Framework) » Showing the property while programmatically selecting a node
Showing the property while programmatically selecting a node [message #644021] Thu, 09 December 2010 01:26 Go to next message
Hi All,
I have added a new view to my RCP based GMF editor.I have provided a tree view with a filter attached to it.So when I select a node from tree,the corresponding node is getting selected.But the property of that node is not visible in the property view.
For selecting the node i have used,
shapeNodeEditPart.getViewer().setSelection(
new StructuredSelection(shapeNodeEditPart));
Please help me in achieving it.
Re: Showing the property while programmatically selecting a node [message #644096 is a reply to message #644021] Thu, 09 December 2010 08:33 Go to previous messageGo to next message
You can try this:
DiagramEditDomain domain = (DiagramEditDomain)shapeEditPart.getViewer().getEditDomain();
domain.getDiagramEditorPart().getSite().getSelectionProvider().setSelection(
Michael
Re: Showing the property while programmatically selecting a node [message #644257 is a reply to message #644021] Fri, 10 December 2010 04:32 Go to previous messageGo to next message
Thanks Michael for your response...
I tried the same,but its not working for me.
Do we have to use the tree viewer for it?I am using SWT Tree to form the tree.
[Updated on: Fri, 10 December 2010 04:32] by Moderator
Re: Showing the property while programmatically selecting a node [message #644665 is a reply to message #644257] Mon, 13 December 2010 12:06 Go to previous message
I don't see how it may be related, because no matter what is your tree implementation, the code above relies on the GMF editor sending the selection change notification which should be handled by the property sheet.
Are you sure that you really tried the code above, because your original sample IS slightly different and should NOT work.
Michael
[Updated on: Mon, 13 December 2010 12:08] by Moderator
Previous Topic:Diagram partitioning, keep editor
Next Topic:GMF model ported to web browser?
Current Time: Fri Jul 18 02:04:37 EDT 2025
Powered by FUDForum. Page generated in 0.07580 seconds
