Home » Archived » BIRT » Total.count per group
Total.count per group [message #644050] Thu, 09 December 2010 04:29 Go to next message
Hi, My name is Sergey. I'm from Ukrainian. In work, I using Birt for building report. So I group rows, wen I need create a total per report I have some problem, because I need show total at the bottom of the report, but Birt write total after each group.What I must do lest have total in the bottom in the report per each group. Thanks!
Re: Total.count per group [message #644087 is a reply to message #644050] Thu, 09 December 2010 07:37 Go to previous messageGo to next message
It sounds like you're putting your total element into the group footer where you want to have it in the table footer. However, since you've mentioned Total.count I think that means you're using an older version of BIRT. Which version are you using? I work with BIRT 2.3 and 2.5, so I use the Aggregation palette element.
Re: Total.count per group [message #644112 is a reply to message #644087] Thu, 09 December 2010 09:59 Go to previous messageGo to next message
In the footer I need write name of the group and count element of this group. Can I do it with using Aggregation?
Re: Total.count per group [message #644167 is a reply to message #644112] Thu, 09 December 2010 13:03 Go to previous messageGo to next message
You can - but I'm confused. Are you trying to put just the total for the final group in the report footer?
Re: Total.count per group [message #644254 is a reply to message #644167] Fri, 10 December 2010 04:21 Go to previous message
Yes. But I have total count. Today I find new way ho to create total per each group, if interesting, write, I try describe. P. S. My English is poor. Sad
Previous Topic:IF-Else formula
Next Topic:Table of Contents minus groups
Current Time: Fri Jul 25 21:17:04 EDT 2025
Powered by FUDForum. Page generated in 0.03525 seconds
