Home » Archived » BIRT » BIRT + javabridge... HELP!!!!!!!
BIRT + javabridge... HELP!!!!!!! [message #644132] Thu, 09 December 2010 10:57 Go to next message
Hi all,
I'm currently designing reports using BIRT but all of my frontend interface is in PHP. Since those reports are all accessible via the Web through an HTTPS connection, using the solution presented here is not an option:
http://www.eclipse.org/birt/phoenix/deploy/usingPHP.php
"http:localhost:8080" does not work over the internet and even if it did, I'd end up losing my secured connection anyway since control would then jump to Tomcat which is unsecured.
This is why I ended up using phpjavabridge which calls the reports from PHP and consequently my Apache server which IS secured. There's no other way to put it but that it was a nightmare to setup until I've stumbled upon this thread:
http://www.eclipse.org/forums/index.php?t=msg&goto=49139 4&
That successfully solved my problem... until recently where BIRT decided to upgrade their report engine and all of the new reports decided to stop working with the error:
[[o:Exception]:"java.lang.Exception: Invoke failed: [[o:RunAndRenderTask]]->run. Cause: org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report. VM: 1.6.0_22@http://java.sun.com/" at: #-29 org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAndRenderTask.java:199) #-28 org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRenderTask.java:75) #-27 sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) #-26 sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) #-25 sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) #-24 java.lang.reflect.Method.invoke(Unknown Source) #-23 php.java.bridge.JavaBridge.Invoke(JavaBridge.java:990) #-22 php.java.bridge.Request.handleRequest(Request.java:415) #-21 php.java.bridge.Request.handleRequests(Request.java:491) #-20 php.java.servlet.PhpJavaServlet.handleHttpConnection(PhpJavaServlet.java:170) #-19 php.java.servlet.PhpJavaServlet.handlePut(PhpJavaServlet.java:186) #-18 php.java.servlet.PhpJavaServlet.doPut(PhpJavaServlet.java:195) #-17 javax.servlet.http.HttpServlet.service(HttpServlet.java:640) #-16 javax.servlet.http.HttpServlet.service(HttpServlet.java:717) #-15 org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290) #-14 org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) #-13 php.java.servlet.PhpCGIFilter.doFilter(PhpCGIFilter.java:126) #-12 org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235) #-11 org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206) #-10 org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233) #-9 org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191) #-8 org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:127) #-7 org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102) #-6 org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109) #-5 org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:298) #-4 org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:857) #-3 org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:588) #-2 org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:489) #-1 java.lang.Thread.run(Unknown Source) #0 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(230): java_ThrowExceptionProxyFactory->getProxy(14, '@V', 'T', true) #1 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(356): java_Arg->getResult(true) #2 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(362): java_Client->getWrappedResult(true) #3 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(554): java_Client->getResult() #4 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(1711): java_Client->invokeMethod(7, 'run', Array) #5 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(1810): java_JavaProxy->__call('run', Array) #6 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(1958): java_AbstractJava->__call('run', Array) #7 [internal function]: Java->__call('run', Array) #8 C:\Program Files\EasyPHP-5.3.2i\www\timesheets\rapportsall.php(339): java_InternalJava->run() #9 {main}]
Which essentially means nothing and everything at once. So, I tried upgrading the engine following the same steps I followed initially (replacing all of the jar in the lib directory except a select few)... and nothing. Same problem.
A new version of javabridge conveniently shows up, I decided to try this one... same mistake. Upgrade the BIRT enging... same mistake.
I've tried the three versions of Tomcat available... same result. I just don't know what to do anymore. All I want is for my reports to be accessible via the web through a secure connection with a PHP frontend. Is it really THAT complicated to accomplish?
Anyway, thanks in advance for any suggestion you people might have.
Osu
Re: BIRT + javabridge... HELP!!!!!!! [message #644157 is a reply to message #644132] Thu, 09 December 2010 12:44 Go to previous messageGo to next message
What version of the Designer are you using? What version of BIRT
runtime did you update to? Can you list the jars that are in the
WEB-INF/lib
Jason
On 12/9/2010 10:57 AM, osuwariboy wrote:
> Hi all,
> option:
> upon this thread:
> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:199)
> #-28
> org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:75)
> php.java.servlet.PhpJavaServlet.handleHttpConnection(PhpJava Servlet.java:170)
> #-19 php.java.servlet.PhpJavaServlet.handlePut(PhpJavaServlet.jav a:186)
> #-18 php.java.servlet.PhpJavaServlet.doPut(PhpJavaServlet.java:19 5) #-17
> org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:290)
> #-14
> org.apache.catalina.core.ApplicationFilterChain.doFilter(App licationFilterChain.java:206)
> #-13 php.java.servlet.PhpCGIFilter.doFilter(PhpCGIFilter.java:126 ) #-12
> org.apache.catalina.core.ApplicationFilterChain.internalDoFi lter(ApplicationFilterChain.java:235)
> #-11
> #-10
> org.apache.catalina.core.StandardWrapperValve.invoke(Standar dWrapperValve.java:233)
> #-9
> org.apache.catalina.core.StandardContextValve.invoke(Standar dContextValve.java:191)
> #-8
> org.apache.catalina.core.StandardHostValve.invoke(StandardHo stValve.java:127)
> #-7
> org.apache.catalina.valves.ErrorReportValve.invoke(ErrorRepo rtValve.java:102)
> #-6
> org.apache.catalina.core.StandardEngineValve.invoke(Standard EngineValve.java:109)
> #-5
> org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAd apter.java:298)
> #-4
> org.apache.coyote.http11.Http11Processor.process(Http11Proce ssor.java:857)
> #-3
> org.apache.coyote.http11.Http11Protocol$Http11ConnectionHand ler.process(Http11Protocol.java:588)
> #-2
> org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoin t.java:489)
> Osu
Re: BIRT + javabridge... HELP!!!!!!! [message #644173 is a reply to message #644157] Thu, 09 December 2010 13:27 Go to previous messageGo to next message
The designer is Eclipse:
Version: Helios Service Release 1
Build id: 20100917-0705
BIRT runtime from 2.6.0 to 2.6.1
Tomcat 6.0 (though every version gives me the same answer)
javabridge from 5.?.? (sorry lost version number) to 6.2.1
Jar files:
birtEngine.jar
chartengineapi.jar
chartexamplescoreapi.jar
chartitemapi.jar
com.ibm.icu_4.2.1.v20100412.jar
commons-cli-1.0.jar
coreapi.jar
crosstabcoreapi.jar
dataadapterapi.jar
dataaggregationapi.jar
dataextraction.jar
documentBeanClient.jar
dteapi.jar
emitterconfig.jar
engineapi.jar
flute.jar
itext.jar
JavaBridge.jar
js.jar
lucene.jar
modelapi.jar
modelodaapi.jar
numberGuess.jar
odadesignapi.jar
org.apache.commons.codec_1.3.0.v20100518-1140.jar
org.eclipse.emf.common_2.6.0.v20100607-0756.jar
org.eclipse.emf.ecore.xmi_2.5.0.v20100521-1846.jar
org.eclipse.emf.ecore_2.6.0.v20100607-0756.jar
org.w3c.css.sac_1.3.0.v200805290154.jar
php-script.jar
php-servlet.jar
poi.jar
scriptapi.jar
script-api.jar
Those are all the default files given with JavaBridge. I noticed that jaxrpc.jar is missing, but adding it from my old installation doesn't do anything.
As I said, any sort of help would be greatly appreciated since I've been at this for almost a week now and I'm getting understandably irritated.
Anyway, thanks in advance Smile.
Osu
[Updated on: Thu, 09 December 2010 13:33] by Moderator
Re: BIRT + javabridge... HELP!!!!!!! [message #644181 is a reply to message #644173] Thu, 09 December 2010 13:54 Go to previous messageGo to next message
Can you look at this directory
webapps\JavaBridge\WEB-INF\platform\plugins
And post the version of the org.eclipse.birt.core plugin?
Also can you run the url
http://localhost:8080/JavaBridge/BirtIndex.jsp?
If so try running one of the reports.
Jason
On 12/9/2010 1:28 PM, osuwariboy wrote:
> The designer is:
> Jar files:
> birtEngine.jar
> chartengineapi.jar
> chartitemapi.jar
> commons-cli-1.0.jar
> coreapi.jar
> crosstabcoreapi.jar
> dataadapterapi.jar
> dataextraction.jar
> dteapi.jar
> emitterconfig.jar
> engineapi.jar
> flute.jar
> itext.jar
> JavaBridge.jar
> js.jar
> lucene.jar
> modelapi.jar
> modelodaapi.jar
> numberGuess.jar
> odadesignapi.jar
> php-script.jar
> php-servlet.jar
> poi.jar
> scriptapi.jar
> script-api.jar
> anything.
> Anyway, thanks in advance :).
> Osu
Re: BIRT + javabridge... HELP!!!!!!! [message #644183 is a reply to message #644181] Thu, 09 December 2010 14:21 Go to previous messageGo to next message
I've tried running all of the reports available at:
All of them open successfully, though I checked the files themselves and the engine version listed in the .rptdesign file is 3.2.21 while the latest engine I'm trying to use is 3.2.22
Also, here's the version of the core:
org.eclipse.birt.core_2.6.0.v20100526.jar
If I check the corresponding folder inside the BIRT runtime package, I notice most of the jar files are more recent than those listed in the javabridge folder. Example:
org.eclipse.birt.core_2.6.1.v20100819.jar
Should I try and upgrade this folder too? And if so, what files should I modify?
Thanks again
Osu
Re: BIRT + javabridge... HELP!!!!!!! [message #644189 is a reply to message #644183] Thu, 09 December 2010 14:32 Go to previous messageGo to next message
Sounds like you did not update the plugins folder. Remove all the
plugins from the plugins folder and replace them with the runtime
download reportengine/plugins. Also delete everything in the
configuration directory but the config.ini.
Jason
> modify?
> Thanks again
> Osu
Re: BIRT + javabridge... HELP!!!!!!! [message #644190 is a reply to message #644189] Thu, 09 December 2010 14:49 Go to previous messageGo to next message
I've done as instructed, but I get this error this time around:
[[o:Exception]:"java.lang.Exception: Invoke failed: [[o:ReportEngine]]->openReportDesign((o:String)[o:String]). Cause: java.lang.NullPointerException VM: 1.6.0_22@http://java.sun.com/" at: #-16 org.eclipse.birt.report.model.api.DesignEngine.newSessionHandle(DesignEngine.java:108) #-15 org.eclipse.birt.report.engine.parser.ReportParser.getDesignHandle(ReportParser.java:143) #-14 org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.getReportDesignHandle(ReportEngineHelper.java:255) #-13 org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:274) #-12 org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:196) #-11 org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.openReportDesign(ReportEngineHelper.java:130) #-10 org.eclipse.birt.report.engine.api.impl.ReportEngine.openReportDesign(ReportEngine.java:295) #-9 sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) #-8 sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) #-7 sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) #-6 java.lang.reflect.Method.invoke(Unknown Source) #-5 php.java.bridge.JavaBridge.Invoke(JavaBridge.java:1044) #-4 php.java.bridge.Request.handleRequest(Request.java:417) #-3 php.java.bridge.Request.handleRequests(Request.java:500) #-2 php.java.bridge.http.ContextRunner.run(ContextRunner.java:145) #-1 php.java.bridge.ThreadPool$Delegate.run(ThreadPool.java:60) #0 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(232): java_ThrowExceptionProxyFactory->getProxy(6, '@V', 'T', true) #1 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(360): java_Arg->getResult(true) #2 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(366): java_Client->getWrappedResult(true) #3 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(560): java_Client->getResult() #4 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(1752): java_Client->invokeMethod(4, 'openReportDesig...', Array) #5 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(1851): java_JavaProxy->__call('openReportDesig...', Array) #6 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\java\Java.inc(1999): java_AbstractJava->__call('openReportDesig...', Array) #7 [internal function]: Java->__call('openReportDesig...', Array) #8 C:\Program Files\Apache Software Foundation\Tomcat 6.0\webapps\JavaBridge\PhpRunAndRenderHTML.php(24): java_InternalJava->openReportDesign('C:\Program File...') #9 {main}]
It's almost like Javabridge cannot cope with the filenames having changed from one version to the other.
Is there a place where one can upgrade these references?
Re: BIRT + javabridge... HELP!!!!!!! [message #644204 is a reply to message #644190] Thu, 09 December 2010 16:50 Go to previous messageGo to next message
Does the jsp page work?
Jason
> #-16
> org.eclipse.birt.report.model.api.DesignEngine.newSessionHan dle(DesignEngine.java:108)
> #-15
> org.eclipse.birt.report.engine.parser.ReportParser.getDesign Handle(ReportParser.java:143)
> #-14
> org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.g etReportDesignHandle(ReportEngineHelper.java:255)
> #-13
> org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:274)
> #-12
> org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:196)
> #-11
> org.eclipse.birt.report.engine.api.impl.ReportEngineHelper.o penReportDesign(ReportEngineHelper.java:130)
> #-10
> org.eclipse.birt.report.engine.api.impl.ReportEngine.openRep ortDesign(ReportEngine.java:295)
> php.java.bridge.http.ContextRunner.run(ContextRunner.java:14 5) #-1
Re: BIRT + javabridge... HELP!!!!!!! [message #644205 is a reply to message #644204] Thu, 09 December 2010 16:58 Go to previous messageGo to next message
Also verify that you did not leave the javabridge.war in the webapps
directory of tomcat.
Jason
> Jason
>> #-16
>> #-15
>> #-14
>> #-13
>> #-12
>> #-11
>> #-10
Re: BIRT + javabridge... HELP!!!!!!! [message #644333 is a reply to message #644205] Fri, 10 December 2010 10:17 Go to previous messageGo to next message
Jason Weathersby... you are my savior!!!!!!! For people who will read this in the future, here is exactly what I did (assuming you already have the necessary BIRT runtime downloaded, that is):
1) Stop Tomcat
2) Flush any JavaBridge already in place (actually moving the JavaBridge folder into another dummy directory is recommended here)
3) Put the new JavaBridge.war file in the webapps directory of Tomcat
4) Restart Tomcat and let it decompress the .war file, it should create a new directory
5) Stop Tomcat
6) Move the JavaBridge.war file away from the webapps directory to prevent any future interference
7) Locate the JavaBridge/WEB-INF/lib directory of your JavaBridge (normally, the first file inside should be BirtEngine.jar) and rename it however you please (in my case, I merely renamed it lib_old)
8 ) Next, decompress your BIRT runtime into a folder and locate the ReportEngine/lib directory inside. Then, copy it at the location found in step 7 (normally, you should have lib and lib_old along with a few other folders if you follow my naming convention)
9)Next, from your lib_old folder, copy the following files in the new lib folder:
birtEngine.jar
JavaBridge.jar
jaxrpc.jar (this one was actually removed from the JavaBridge 6.2.1, but I haven't encountered any problems even if it isn't there... bottom line, if you have it, take it, if you don't then just ignore it)
lucene.jar
php-script.jar
php-servlet.jar
script-api.jar
10) Next go to the JavaBridge/WEB-INF/platform and you should see a "plugins" directory. Rename that "plugins_old"
11) From your BIRT runtime decompressed folder, grab the ReportEngine/plugins folder and copy it in the location found at step 10
12) Now, enter your new plugins folder and locate a folder that should be named something like:
org.eclipse.birt.report.data.oda.jdbc_version (where "version" is something that will change, for me it was 2.6.1.v20100909)
13) Inside, you should find a "driver" folder that should only contain a readme.txt file. What you need to do here is download a jdbc connector jar file and put it there. I myself used the same one that I used with my version of Eclipse.
What I did personally was go to my folder:
eclipse\plugins\org.eclipse.birt.report.data.oda.jdbc_2.6.1. v20100909\drivers
and copy the "mysql-connector-java-5.1.12-bin.jar" I found there into the folder mentioned at step 12
Once I did that and subsequently restarted Tomcat... everything was fine and dandy. Keep in mind of course that the version of your connector might change, but I don't think it really matters.
I really have to thank Jason again for his invaluable help in setting everything up. I never would have done it without his help.
Good luck with JavaBridge everyone and thanks Jason
Osu
Re: BIRT + javabridge... HELP!!!!!!! [message #644352 is a reply to message #644333] Fri, 10 December 2010 11:26 Go to previous messageGo to next message
Thanks For posting your howto description.
Jason
> 1) Stop Tomcat
> a new directory
> 5) Stop Tomcat
> lib folder:
> birtEngine.jar
> JavaBridge.jar
> lucene.jar
> php-script.jar
> php-servlet.jar
> script-api.jar
> v20100909\drivers
> Osu
Re: BIRT + javabridge... HELP!!!!!!! [message #644386 is a reply to message #644352] Fri, 10 December 2010 13:56 Go to previous message
No sweat Jason,
My dream through all of this ordeal was to actually HAVE a step by step procedure to upgrade JavaBridge BIRT engine. Thanks in good part to you, I now have exactly what I wanted Smile.
What's more, if my experience can benefit others then it's even better since I'm pretty sure I'm not the only one who's had this problem... and to be honest, the solution, while really simple when you actually know what to do, is definitely not trivial.
Thank you again for all your help.
Osu
Previous Topic:Export Birt report in Excel
Next Topic:Unable to build a dataset
Current Time: Wed Jul 23 12:40:51 EDT 2025
Powered by FUDForum. Page generated in 2.55220 seconds
