Riena Security - Session is null at some calls [message #643497] |
Tue, 07 December 2010 01:54  |
Originally posted by: matthiasrodler.gmx.net
I'm using Riena Security and I'm currently facing the problem, that at
some calls I get a null value from the SessionHolder within the
SecurityCallHook.
The problem will occur at every service call within a
org.eclipse.core.runtime.jobs.Job class (in the run method) but I'm not
sure if this is the reason (but it seems so).
At any further calls - outside a job - the session is set again.
Matthias
Re: Riena Security - Session is null at some calls [message #644548 is a reply to message #644534] |
Mon, 13 December 2010 03:38   |
Hi Matthias,
That´s right. It is not a very save way for deciding whether we are on
the server or the client. But it is the fallback if the system property
"riena.container.type" is not set.
==> http://wiki.eclipse.org/Riena_System_Properties
Tschüß,
Stefan
Am 13.12.2010 07:36, schrieb Matthias Rodler:
> The reason for a null pointer is the usage of the help system from
> eclipse and with this your way how you decide between client and server
> mode.
> The help system needs several packages which start with
> "org.eclipse.equinox.http" for which you are looking for in the
> ContainerModel class. This leads to the usage of
> SimpleThreadedSessionHolder which will create a new SessionHolder if it
> is called within an eclipse job.
> I just have missed your "SERVER Mode" message and was not aware about
> the impact the mode decision has on the application.
> Maybe a "server" bundle could be used instead of looking at the bundle
> names.
> Matthias
> Am 09.12.2010 14:33, schrieb Christian Campo:
>> Hi Matthias,
>> the session in the SessionHolder is a singleton on the client. So no
>> matter what thread you are in, it should always be available once you
>> have logged in successfully.
>> Maybe it helps to set break points in SimpleSessionHolder class in
>> setHolder and getHolder to see whats going on in your environment. It
>> should certainly work.
>> christian
>> Am 07.12.10 07:54, schrieb Matthias Rodler:
>>> Hi,
>>> SecurityCallHook.
>>> Matthias
Re: Riena Security - Session is null at some calls [message #644580 is a reply to message #644548] |
Mon, 13 December 2010 05:52  |
I have added the use case of Security to the wiki page for the riena.container.type system property.....
christian
Am 13.12.10 09:38, schrieb Stefan Liebig:
> Hi Matthias,
> Tschüß,
> Stefan
>> mode.
>> names.
>> Matthias
>>> Hi Matthias,
>>> christian
>>>> Hi,
>>>> SecurityCallHook.
>>>> Matthias
FUDForum. Page generated in 0.26755 seconds
