Home » Eclipse Projects » Remote Application Platform (RAP) » Tomcat Manager
Tomcat Manager [message #643831] Wed, 08 December 2010 08:04 Go to next message
Hi ppl,
i created a new RAP with a view and some radio buttons,when i select the deployed Project in the manager i get this message:
HTTP Status 404 - ProxyServlet: /View2
type Status report
message ProxyServlet: /View2
description The requested resource (ProxyServlet: /View2) is not available.
but when i add /rap?start=myapp it works
how can i set it to open after i press View2 in the Tomcat Manager
thx for every help
[Updated on: Wed, 08 December 2010 08:58] by Moderator
Re: Tomcat Manager [message #644037 is a reply to message #643831] Thu, 09 December 2010 03:09 Go to previous messageGo to next message
Hi Hussein,
did you try to use org.eclipse.rap.ui.branding extension and to specify
your servlet name and default entry point?
Best,
Ivan
On 08.12.2010 3:04 PM, Hussein Kobeisi wrote:
> Hi ppl,
> type Status report
> available.
> thx for every help
Re: Tomcat Manager [message #644141 is a reply to message #643831] Thu, 09 December 2010 11:37 Go to previous messageGo to next message
The problem is that there is nothing within your WAR that is listening on the root path (i.e. http://host/warname/). The default entry point only allows you to leave off the query string (so you can do http://host/warname/servletname instead of .../servletname?startup=entrypoint). What you need is a servlet registered as "/" which will redirect to your RAP servlet. You can do this either within the WAR by modifying the web.xml and including the servlet class in the WEB-INF/classes directory, or you can register within your RAP application by using the org.eclipse.equinox.http.registry.servlets extension point or using the OSGi HttpService programatically.
Hope that helps,
Cole
Re: Tomcat Manager [message #644440 is a reply to message #644141] Sat, 11 December 2010 04:37 Go to previous messageGo to next message
Hi Hussein,
there's an example how to do it in the RAP FAQ:
http://wiki.eclipse.org/RAP/
FAQ#How_to_access_a_RAP_application_without_specifying_a_ser vlet_name.3F
Regards, Ralf
Ralf Sternberg
Twitter: http://twitter.com/ralfstx
Blog: http://www.eclipsesource.com/blogs/
Professional support for RAP and RCP?
http://www.eclipsesource.com/support/
Re: Tomcat Manager [message #644540 is a reply to message #643831] Mon, 13 December 2010 02:50 Go to previous message
thx for all the answers,
iam gonna check them out..
Regards, Hussein
Previous Topic:interactiondesign API in single sourcing?
Next Topic:menu arrows not shown behind gateway
Current Time: Thu Jul 17 21:59:51 EDT 2025
Powered by FUDForum. Page generated in 0.11529 seconds
