Home » Archived » BIRT » PermGen Space Error running BIRT reports
PermGen Space Error running BIRT reports [message #643801] Wed, 08 December 2010 05:39 Go to next message
Im running into the PermGen space issue when I attempt to run Birt reports from within my application when I am running Tomcat within Eclipse.
My ini file is as follows:
-Xms512m
-Xmx512m
-XX:MaxPermSize=256m
However, Ive tried most ever configuration of heap Xms, Xmx and XX:MaxPermSize.
Eclipse Version: Helios Service Release 1
Build id: 20100917-0705
Birt: 2.6.1
java -version gives:
java version "1.6.0_22"
Java(TM) SE Runtime Environment (build 1.6.0_22-b04)
Java HotSpot(TM) Client VM (build 17.1-b03, mixed mode, sharing)
As soon as I starting running Birt reports I get the following error (or similar):
SEVERE: Error processing request
java.lang.OutOfMemoryError: PermGen space
Re: PermGen Space Error running BIRT reports [message #643906 is a reply to message #643801] Wed, 08 December 2010 11:25 Go to previous messageGo to next message
Is this starting another jvm to run tomcat on? You can add the jvm
setting to the catalina.bat file.
Jason
> -Xms512m
> -Xmx512m
> XX:MaxPermSize.
> Birt: 2.6.1
> similar):
Re: PermGen Space Error running BIRT reports [message #643930 is a reply to message #643906] Wed, 08 December 2010 12:49 Go to previous messageGo to next message
Hi, thanks for getting back to me.
I'm running Tomcat from within Eclipse which, I believe, means that it doesn't use the Catalina.bat file.
I'm starting my server from within Eclipse. Within Eclipse's Tomcat configuration I have the following VM arguments:
-Dcatalina.base=" C:\workspace_svn\.metadata\.plugins\org.eclipse.wst.server.c ore\tmp1 " -Dcatalina.home="C:\tomcat" -Dwtp.deploy=" C:\workspace_svn\.metadata\.plugins\org.eclipse.wst.server.c ore\tmp1\wtpwebapps " -Djava.endorsed.dirs="C:\tomcat\endorsed" -Xmx1024m
The classpath tab the bootstrap entry is set to have the jdk1.6.0_22 for the JRE system library. Do you think it's also possible to reference the jvm in these Java options?
Re: PermGen Space Error running BIRT reports [message #643962 is a reply to message #643930] Wed, 08 December 2010 15:11 Go to previous messageGo to next message
Can you add this to the line
-XX:MaxPermSize=256M
Jason
> -Dcatalina.base="
Re: PermGen Space Error running BIRT reports [message #643966 is a reply to message #643962] Wed, 08 December 2010 15:34 Go to previous message
That seems to have solved it! I've been running Birt reports for the last 10 minutes and no PermGen issues when previously I was getting them almost instantly.
Thanks so much Jason.
Previous Topic:Scripted DataSet classpath question
Next Topic:Unable to access selected values of a ListBox type parameter
Current Time: Fri Jul 25 20:33:04 EDT 2025
Powered by FUDForum. Page generated in 0.04747 seconds
