Unexpected bundle installation behaviour [message #643946] |
Wed, 08 December 2010 14:10  |
After successfully installing Greenpages, I wanted to create my own app and created some new bundles that borrowed heavily from the Greenpages layout (a parent pom project, web and app bundles and a par). The only real difference between my app (called 'star') and greenpages is that instead of using Directory and Listing, this app uses my own objects. I have not yet added a JPA or db bundle..
When I try to deploy I get the following output. I used the (inappropriate) 2.3.0.RELEASE version tag for my bundles, so I don't understand why star.web' version '0.0.0' shows up on the second line...
[2010-12-08 11:47:16.026] TCP Connection(50)-127.0.0.1 <DE0000I> Installing par 'star' version '2.3.0.RELEASE'.
[2010-12-08 11:47:16.026] TCP Connection(50)-127.0.0.1 <DE0000I> Installing bundle 'star.web' version '0.0.0'.
[2010-12-08 11:47:16.135] TCP Connection(50)-127.0.0.1 <DE0002E> Installation of par 'star' version '2.3.0.RELEASE' failed. org.eclipse.virgo.kernel.deployer.core.DeploymentException: Unsatisfied dependency detected when expanding imports for [bundle 'star.web' version '0.0.0' in scope 'null', bundle 'star-2.3.0.RELEASE-synthetic.context' version '2.3.0.RELEASE' in scope 'star-2.3.0.RELEASE']
at org.eclipse.virgo.kernel.deployer.core.internal.ImportExpand ingTransformer.expandImports(ImportExpandingTransformer.java :116)
at org.eclipse.virgo.kernel.deployer.core.internal.ImportExpand ingTransformer.expandImportsOfBundlesInScopedPlan(ImportExpa ndingTransformer.java:89)
at org.eclipse.virgo.kernel.deployer.core.internal.ImportExpand ingTransformer$ImportExpandingTreeVisitor.visit(ImportExpand ingTransformer.java:76)
at org.eclipse.virgo.util.common.ThreadSafeArrayListTree.visit( ThreadSafeArrayListTree.java:165)
at org.eclipse.virgo.kernel.deployer.core.internal.ImportExpand ingTransformer.transform(ImportExpandingTransformer.java:58)
at org.eclipse.virgo.kernel.install.pipeline.stage.transform.in ternal.TransformationStage.doProcessTree(TransformationStage .java:55)
at org.eclipse.virgo.kernel.install.pipeline.stage.AbstractPipe lineStage.process(AbstractPipelineStage.java:41)
at org.eclipse.virgo.kernel.install.pipeline.internal.StandardP ipeline.doProcessTree(StandardPipeline.java:62)
at org.eclipse.virgo.kernel.install.pipeline.internal.Compensat ingPipeline.doProcessTree(CompensatingPipeline.java:72)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApp licationDeployer.driveInstallPipeline(PipelinedApplicationDe ployer.java:271)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApp licationDeployer.doInstall(PipelinedApplicationDeployer.java :151)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApp licationDeployer.install(PipelinedApplicationDeployer.java:1 23)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApp licationDeployer.deploy(PipelinedApplicationDeployer.java:19 0)
at org.eclipse.virgo.kernel.deployer.management.StandardDeploye r.deploy(StandardDeployer.java:52)
at sun.reflect.GeneratedMethodAccessor72.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at com.sun.jmx.mbeanserver.ConvertingMethod.invokeWithOpenRetur n(ConvertingMethod.java:167)
at com.sun.jmx.mbeanserver.MXBeanIntrospector.invokeM2(MXBeanIn trospector.java:96)
at com.sun.jmx.mbeanserver.MXBeanIntrospector.invokeM2(MXBeanIn trospector.java:33)
at com.sun.jmx.mbeanserver.MBeanIntrospector.invokeM(MBeanIntro spector.java:208)
at com.sun.jmx.mbeanserver.PerInterface.invoke(PerInterface.jav a:120)
at com.sun.jmx.mbeanserver.MBeanSupport.invoke(MBeanSupport.jav a:262)
at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.invoke (DefaultMBeanServerInterceptor.java:836)
at com.sun.jmx.mbeanserver.JmxMBeanServer.invoke(JmxMBeanServer .java:761)
at javax.management.remote.rmi.RMIConnectionImpl.doOperation(RM IConnectionImpl.java:1427)
at javax.management.remote.rmi.RMIConnectionImpl.access$200(RMI ConnectionImpl.java:72)
at javax.management.remote.rmi.RMIConnectionImpl$PrivilegedOper ation.run(RMIConnectionImpl.java:1265)
at javax.management.remote.rmi.RMIConnectionImpl.doPrivilegedOp eration(RMIConnectionImpl.java:1360)
at javax.management.remote.rmi.RMIConnectionImpl.invoke(RMIConn ectionImpl.java:788)
at sun.reflect.GeneratedMethodAccessor71.invoke(Unknown Source)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.ja va:305)
at sun.rmi.transport.Transport$1.run(Transport.java:159)
at sun.rmi.transport.Transport.serviceCall(Transport.java:155)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTranspo rt.java:535)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TC PTransport.java:790)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCP Transport.java:649)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Threa dPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoo lExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
Caused by: org.eclipse.virgo.kernel.osgi.framework.UnableToSatisfyBundl eDependenciesException: Unable to satisfy dependencies of bundle 'star-2.3.0.RELEASE-synthetic.context' at version '2.3.0.RELEASE': Import-Bundle with symbolic name 'star-2.3.0.RELEASE-star.web' in version range '[0.0.0, oo)' could not be satisfied
at org.eclipse.virgo.kernel.userregion.internal.importexpansion .ImportExpansionHandler.getBundlePackageImports(ImportExpans ionHandler.java:271)
at org.eclipse.virgo.kernel.userregion.internal.importexpansion .ImportExpansionHandler.getAdditionalPackageImports(ImportEx pansionHandler.java:236)
at org.eclipse.virgo.kernel.userregion.internal.importexpansion .ImportExpansionHandler.expandImports(ImportExpansionHandler .java:206)
at org.eclipse.virgo.kernel.userregion.internal.importexpansion .ImportExpansionHandler.expandImportsIfNecessary(ImportExpan sionHandler.java:174)
at org.eclipse.virgo.kernel.userregion.internal.importexpansion .ImportExpansionHandler.expandImports(ImportExpansionHandler .java:112)
at sun.reflect.GeneratedMethodAccessor68.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsin gReflection(AopUtils.java:307)
at org.springframework.osgi.service.importer.support.internal.a op.ServiceInvoker.doInvoke(ServiceInvoker.java:58)
at org.springframework.osgi.service.importer.support.internal.a op.ServiceInvoker.invoke(ServiceInvoker.java:62)
at org.springframework.aop.framework.ReflectiveMethodInvocation .proceed(ReflectiveMethodInvocation.java:172)
at org.springframework.aop.support.DelegatingIntroductionInterc eptor.doProceed(DelegatingIntroductionInterceptor.java:131)
at org.springframework.aop.support.DelegatingIntroductionInterc eptor.invoke(DelegatingIntroductionInterceptor.java:119)
at org.springframework.osgi.service.util.internal.aop.ServiceTC CLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java :56)
at org.springframework.osgi.service.util.internal.aop.ServiceTC CLInterceptor.invoke(ServiceTCCLInterceptor.java:39)
at org.springframework.osgi.service.importer.support.LocalBundl eContextAdvice.invoke(LocalBundleContextAdvice.java:59)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke( JdkDynamicAopProxy.java:202)
at $Proxy63.expandImports(Unknown Source)
at org.eclipse.virgo.kernel.deployer.core.internal.ImportExpand ingTransformer.expandImports(ImportExpandingTransformer.java :107)
... 45 common frames omitted
[2010-12-08 11:47:16.135] TCP Connection(50)-127.0.0.1 <DE0003E> Install failed for bundle 'star.web' version '0.0.0'.
[2010-12-08 11:47:16.151] TCP Connection(50)-127.0.0.1 <DE0003E> Install failed for par 'star' version '2.3.0.RELEASE'.
Re: Unexpected bundle installation behaviour [message #643953 is a reply to message #643949] |
Wed, 08 December 2010 14:45   |
Manifest-Version: 1.0
Import-Bundle: com.springsource.org.apache.taglibs.standard;version="[
1.1.2,1.3)"
Bundle-Version: 2.3.0.RELEASE
Tool: Bundlor 1.0.0.RELEASE
Bundle-Name: Star Web
Import-Library: org.springframework.spring;version="[3.0, 3.1)"
Bundle-ManifestVersion: 2
Bundle-SymbolicName: star.web
Web-ContextPath: star
Import-Package: org.springframework.beans.factory.annotation;version="
[3.0.0, 3.1.0)",org.springframework.stereotype;version="[3.0.0, 3.1.0
)",org.springframework.web.bind.annotation;version="[3.0.0, 3.1.0)",o
rg.springframework.web.servlet.mvc.annotation;version="[3.0.0, 3.1.0)
",org.springframework.web.servlet.view.freemarker;version="[3.0.0, 3.
1.0)",star;version="[2.3.0)"
Attachment: MANIFEST.MF
(Size: 0.71KB, Downloaded 248 times)
FUDForum. Page generated in 0.09945 seconds
