Home » Eclipse Projects » Standard Widget Toolkit (SWT) » disposing widgets in a tableviewer(disposing widgets in a tableviewer)
disposing widgets in a tableviewer [message #643601] Tue, 07 December 2010 10:53 Go to next message
I have a tableviewer that can be refreshed and the structure (n. rows/columns) changes each time. The table contains only swt images generated using GC from a ModelProvider.
Even though I dispose the GC images in the ModelProvider, after a number of refreshes the table won't display more images (3 dots instead) and no error message is printed on the console.
What else should I dispose? (i am not getting any no more handles message)
Thanks!
Re: disposing widgets in a tableviewer [message #643678 is a reply to message #643601] Tue, 07 December 2010 14:59 Go to previous messageGo to next message
Actually I found that I was not disposing the images...looks like it works now.
Re: disposing widgets in a tableviewer [message #643757 is a reply to message #643601] Wed, 08 December 2010 02:49 Go to previous message
On 12/7/2010 16:53, fran81 wrote:
> Hello,
This is probably to much hand-waving, we need to see more code to help
here. Without any further information I assume that you forgot to
dispose the images after each new creation. It can also be a refresh
problem - Where does the drawing happen?
HTH & Greetings from Bremen,
Daniel Krügler
Previous Topic:Can I make a Wysiwyg editor based on printing result with SWT?
Next Topic:Drag n Drop on Views
Current Time: Fri Jul 18 12:57:40 EDT 2025
Powered by FUDForum. Page generated in 0.27952 seconds
