Home » Language IDEs » Java Development Tools (JDT) » Linke to folder in teh file system - problem(to link a folder fails if the group dir already exists)
Linke to folder in teh file system - problem [message #642420] Wed, 01 December 2010 04:31 Go to next message
I have two projects using the same package structure, means the high qualifier is the same (in my case "rnd"). I need to use classes from one project in the other (but not via jar, as they are still "work in progress") - so I wanted to create a "link to folder in the file system" - unfortunately it fails.
In the project I create the link into are packages like "rnd.rap" and "rnd.views", the linked classes are in package "rnd.sockets".
It seems the link-process tries to create the directory "rnd", but it already exists, so the link-creation fails, instead of simply reusing the existing dir.
My work-around is to create the link in the OS (which is no problem in Linux, but would be one on Windows) - nevertheless I feel this is a bug and should work - but being an Eclipse beginner I want to check first, maybe I didn't understand some concept yet.
Any ideas, comments or suggestions?
Richard
Re: Linke to folder in teh file system - problem [message #642524 is a reply to message #642420] Wed, 01 December 2010 11:26 Go to previous messageGo to next message
On 12/1/2010 3:01 PM, dbrich wrote:
> - unfortunately it fails. In the project I create the link into are
> the existing dir.
> Thanks
> Richard
Why don't you just add one project to the build path of the other ?
Re: Linke to folder in teh file system - problem [message #642526 is a reply to message #642524] Wed, 01 December 2010 11:44 Go to previous messageGo to next message
Well, I forgot to mention that I am working on a RAP project - RAP runs against a target platform and doesn't care about build path - therefore adding a second project is not working in this case.
Richard
Re: Linke to folder in teh file system - problem [message #642621 is a reply to message #642526] Wed, 01 December 2010 21:56 Go to previous messageGo to next message
Are you sure ? Target platform comes into picture when you are
developing plug-ins, if you are developing plug-ins it is better to add
a plug-in dependency from one plug-in project to another. If you have
plain Java Projects then you should configure the build path. (In
Package Explorer Right click on project and from the context menu Build
Path > Configure Build path > Projects tab)
(Note that build path is used by both plain Java projects and plug-in
projects)
> Richard
Re: Linke to folder in teh file system - problem [message #642705 is a reply to message #642621] Thu, 02 December 2010 08:00 Go to previous messageGo to next message
Please, bear with me as I am new to these technologies.
Yes, I am developing a plug-in for a RAP (and RCP) target. But I also have some packages I need in this plug-in which I developed in plain Java (sockets and other utilities). I do not want to add them to the target, as that has to be done in a jar and is therefore not very flexible - the project is in start and I do make still changes to these classes on the go if I need it for the plug-in.
The source for these classes is actually in a SVN repository - my first idea was to create two additional projects and add them into the build path. That didn't work - I am actually getting syntax errors, as Eclipse does not find the classes even during coding.
Second idea was to add them as a external link - which also didn't work.
Is there maybe other way to do it? I do not need the classes in a separate project in this workspace, but I didn't find any way to add a package from SVN (I do not want to add the classes, because there are too many to do it one by one).
Re: Linke to folder in teh file system - problem [message #642774 is a reply to message #642705] Thu, 02 December 2010 11:26 Go to previous messageGo to next message
Right, the target contains already existing plug-ins.
> two additional projects and add them into the build path.That didn't
What were the errors? This should have worked... maybe the classes were
not public? (Note that you could convert your plain java
projects/classes into a plug-in, just to use the plug-in dependency
mechanism.)
Re: Link to folder in the file system - problem [message #643594 is a reply to message #642774] Tue, 07 December 2010 10:39 Go to previous messageGo to next message
Well, I am not able to recreate the syntax error - looks like you are right that adding the project into dependencies cures that problem.
I still cannot run the plug-in though - it does not find the classes from these projects.
I suppose I can make plug-in from my "plain" classes, but would that not mean to export them into a jar then?
If not that could be my solution - to create a "utilities" plug-in and put all these classes into it, could be even useful during deployment.
But should not be possible to create a link to other file even if the high-level directory already exists?
Re: Link to folder in the file system - problem [message #643729 is a reply to message #643594] Tue, 07 December 2010 21:56 Go to previous message
A plugin is usually a jar :)
Exactly!
Maybe, I did not look into this. The support for links was added to
Eclipse Platform recently and mostly for people doing C,C++ dev. In the
Java world I have not really seen a good use for links.
Previous Topic:IDL compiler plugin for Eclipse
Next Topic:Failed to connect to remote JVM, connection timed out
Current Time: Sun Jul 27 12:59:55 EDT 2025
Powered by FUDForum. Page generated in 0.05068 seconds
