Home » Modeling » TMF (Xtext) » Vanishing whitespaces due to optional keyword
Vanishing whitespaces due to optional keyword [message #643586] Tue, 07 December 2010 10:05 Go to next message
Hi guys,
I'm currently facing a rather strange behaviour which I cannot explain.
Consider the following grammar:
grammar org.xtext.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.xtext.org/example/mydsl/MyDsl"
Module:
	"module" name=ID ":" body=ModuleBody "end" "module";
ModuleBody:
	name=ID ';'?
and this input:
module m1:
foo;
end module
Parsing works fine and as expected, but calling save on the resource results in the following
module m1:
fooend module
The semicolon is not there anymore as it is optional and the serializer cannot know if it was set before or not - so it's omitted. But why is there no whitespace between 'foo' and 'end'?
best regards
Re: Vanishing whitespaces due to optional keyword [message #643668 is a reply to message #643586] Tue, 07 December 2010 13:48 Go to previous messageGo to next message
Hi Ulf,
you'll have to tell your formatter that the whitespace between both
tokens is mandatory.
Sebastian
Am 07.12.10 16:05, schrieb Ulf:
> Hi guys,
> Module:
> ModuleBody:
> name=ID ';'?
> and this input:
> module m1:
> foo;
> end module
> module m1:
> fooend module
> best regards
Re: Vanishing whitespaces due to optional keyword [message #643679 is a reply to message #643586] Tue, 07 December 2010 15:01 Go to previous message
Hi Sebastian,
Thanks for the quick answer - I realized that the OneWhiteSpaceFormatter would solve the problem but was wondering why the serialzier omits whitespaces just for optional keywords.
Is it because the whitespace is connected to the semicolon and therefore omitted as well?
Or is there no particular reason?
Previous Topic:Dependencies of one grammar on another
Next Topic:Problems when using xtextEditor which in a MultiPageEditor
Current Time: Thu Jul 03 09:02:09 EDT 2025
Powered by FUDForum. Page generated in 0.03928 seconds
