Home » Modeling » M2T (model-to-text transformation) » Acceleo 3.x - reset generate module problem
Acceleo 3.x - reset generate module problem [message #643513] Tue, 07 December 2010 03:33 Go to next message
i have a small problem. After creating a acceleo 3.x project my generate java file (file with main method) will always be overwritten with the standard file. I have these problem after changing and saving a template.
Example:
My changed generation java file looks like:
* Copyright (c) 2008, 2010 Obeo.
* All rights reserved. This program and the accompanying materials
* are made available under the terms of the Eclipse Public License v1.0
* which accompanies this distribution, and is available at
* http://www.eclipse.org/legal/epl-v10.html
* Contributors:
* Obeo - initial API and implementation
package de.formula1.bet.game.gen.ui.files;
import java.io.File;
import java.io.IOException;
import java.util.ArrayList;
import java.util.List;
import org.eclipse.acceleo.engine.event.IAcceleoTextGenerationListe ner;
import org.eclipse.acceleo.engine.generation.strategy.IAcceleoGener ationStrategy;
import org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator;
import org.eclipse.emf.common.util.BasicMonitor;
import org.eclipse.emf.common.util.Monitor;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.EObject;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.uml2.uml.UMLPackage;
import org.eclipse.uml2.uml.resource.UMLResource;
* Entry point of the 'Generate' generation module.
* @generated
public class Generate extends AbstractAcceleoGenerator {
* The name of the module.
* @generated
public static final String MODULE_FILE_NAME = "generate";
* The name of the templates that are to be generated.
* @generated
public static final String[] TEMPLATE_NAMES = { "generateClass", };
* Allows the public constructor to be used. Note that a generator created
* this way cannot be used to launch generations before one of
* {@link #initialize(EObject, File, List)} or
* {@link #initialize(URI, File, List)} is called.
* <p>
* The main reason for this constructor is to allow clients of this
* generation to call it from another Java file, as it allows for the
* retrieval of {@link #getProperties()} and
* {@link #getGenerationListeners()}.
* </p>
* @generated
public Generate() {
// Empty implementation
* This allows clients to instantiates a generator with all required information.
* @param modelURI
* URI where the model on which this generator will be used is located.
* @param targetFolder
* This will be used as the output folder for this generation : it will be the base path
* against which all file block URLs will be resolved.
* @param arguments
* If the template which will be called requires more than one argument taken from the model,
* pass them here.
* @throws IOException
* This can be thrown in three scenarios : the module cannot be found, it cannot be loaded, or
* the model cannot be loaded.
* @generated
public Generate(URI modelURI, File targetFolder,
List<? extends Object> arguments) throws IOException {
initialize(modelURI, targetFolder, arguments);
* @param model
* We'll iterate over the content of this element to find Objects matching the first parameter
* of the template we need to call.
* @param arguments
* pass them here.
* This can be thrown in two scenarios : the module cannot be found, or it cannot be loaded.
* @generated
public Generate(EObject model, File targetFolder,
initialize(model, targetFolder, arguments);
* This can be used to launch the generation from a standalone application.
* @param args
* Arguments of the generation.
* @generated
try {
if (args.length < 2) {
System.out.println("Arguments not valid : {model, folder}.");
} else {
URI modelURI = URI.createFileURI(args[0]);
File folder = new File(args[1]);
List<String> arguments = new ArrayList<String>();
for (int i = 2; i < args.length; i++) {
arguments.add(args[i]);
Generate generator = new Generate(modelURI, folder, arguments);
generator.doGenerate(new BasicMonitor());
} catch (IOException e) {
e.printStackTrace();
* Launches the generation described by this instance.
* @param monitor
* This will be used to display progress information to the user.
* This will be thrown if any of the output files cannot be saved to disk.
* @generated
public void doGenerate(Monitor monitor) throws IOException {
* TODO if you wish to change the generation as a whole, override this.
* The default behavior should be sufficient in most cases.
super.doGenerate(monitor);
* If this generator needs to listen to text generation events, listeners can be returned from here.
* @return List of listeners that are to be notified when text is generated through this launch.
* @generated
public List<IAcceleoTextGenerationListener> getGenerationListeners() {
List<IAcceleoTextGenerationListener> listeners = super.getGenerationListeners();
// TODO if you need to listen to generation event, add listeners to the list here
return listeners;
* If you need to change the way files are generated, this is your entry point.
* <p>
* The default is {@link org.eclipse.acceleo.engine.generation.strategy.DefaultStrate gy}; it generates
* files on the fly. If you only need to preview the results, return a new
* {@link org.eclipse.acceleo.engine.generation.strategy.PreviewStrate gy}. Both of these aren't aware of
* the running Eclipse and can be used standalone.
* </p>
* <p>
* If you need the file generation to be aware of the workspace (A typical example is when you wanna
* override files that are under clear case or any other VCS that could forbid the overriding), then
* return a new {@link org.eclipse.acceleo.engine.generation.strategy.WorkspaceAwar eStrategy}.
* <b>Note</b>, however, that this <b>cannot</b> be used standalone.
* </p>
* <p>
* All three of these default strategies support merging through JMerge.
* </p>
* @return The generation strategy that is to be used for generations launched through this launcher.
* @generated
public IAcceleoGenerationStrategy getGenerationStrategy() {
return super.getGenerationStrategy();
* This will be called in order to find and load the module that will be launched through this launcher.
* We expect this name not to contain file extension, and the module to be located beside the launcher.
* @return The name of the module that is to be launched.
* @generated
public String getModuleName() {
return MODULE_FILE_NAME;
* If the module(s) called by this launcher require properties files, return their qualified path from
* here.Take note that the first added properties files will take precedence over subsequent ones if they
* contain conflicting keys.
* <p>
* Properties need to be in source folders, the path that we expect to get as a result of this call are of
* the form &lt;package>.&lt;properties file name without extension>. For example, if you have a file
* named "messages.properties" in package "org.eclipse.acceleo.sample", the path that needs be returned by
* a call to {@link #getProperties()} is "org.eclipse.acceleo.sample.messages".
* </p>
* @return The list of properties file we need to add to the generation context.
* @see java.util.ResourceBundle#getBundle(String)
* @generated
public List<String> getProperties() {
List<String> propertiesFiles = super.getProperties();
* TODO if your generation module requires access to properties files,
* add their qualified path to the list here. Properties files are
* expected to be in source folders, and the path here to be the
* qualified path as if referring to a Java class. For example, if you
* have a file named "messages.properties" in package
* "org.eclipse.acceleo.sample", the path that needs be added to this
* list is "org.eclipse.acceleo.sample.messages".
return propertiesFiles;
* This will be used to get the list of templates that are to be launched by this launcher.
* @return The list of templates to call on the module {@link #getModuleName()}.
* @generated
public String[] getTemplateNames() {
return TEMPLATE_NAMES;
* This can be used to update the resource set's package registry with all needed EPackages.
* @param resourceSet
* The resource set which registry has to be updated.
* @generated
public void registerPackages(ResourceSet resourceSet) {
super.registerPackages(resourceSet);
resourceSet.getPackageRegistry().put(org.eclipse.uml2.uml.UM LPackage.eINSTANCE.getNsURI(), org.eclipse.uml2.uml.UMLPackage.eINSTANCE);
// TODO If you need additional package registrations, do them here. The following line is an example for UML.
resourceSet.getPackageRegistry().put("http://www.eclipse.org/uml2/2.0.0/UML", UMLPackage.eINSTANCE);
* This can be used to update the resource set's resource factory registry with all needed factories.
* @generated
public void registerResourceFactories(ResourceSet resourceSet) {
super.registerResourceFactories(resourceSet);
// TODO If you need additional resource factories registrations, do them here. The following line is an example for UML.
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "uml", UMLResource.Factory.INSTANCE);
After changing a template my generation file looks like:
* Contributors:
* @generated
* @generated
* @generated
* <p>
* </p>
* @generated
public Generate() {
* @param modelURI
* @param arguments
* pass them here.
* @generated
* @param model
* @param arguments
* pass them here.
* @generated
* @param args
* @generated
try {
} else {
* @param monitor
* @generated
* @generated
return listeners;
* <p>
* </p>
* <p>
* </p>
* <p>
* </p>
* @generated
* @generated
* <p>
* </p>
* @generated
* @generated
* @generated
//resourceSet.getPackageRegistry().put(org.eclipse.uml2.uml. UMLPackage.eINSTANCE.getNsURI(), org.eclipse.uml2.uml.UMLPackage.eINSTANCE);
* @generated
//resourceSet.getResourceFactoryRegistry().getExtensionToFac toryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
What can i do?
Best regards
Maik
Re: Acceleo 3.x - reset generate module problem [message #643519 is a reply to message #643513] Tue, 07 December 2010 03:53 Go to previous messageGo to next message
Hi Malk,
I didn't read your code (I assume it works) but if you want to create a custom Java class to launch the generation and if you want to prevent Acceleo from overriding that class, just remove the "[comment @main]".
This comment has only one goal: create a basic Java class to launch the generation. If you want you can programmatically call the module of your choice with the template of your choice with the EObject of your choice.
Our basic class just launch the module and the template (from which it has been created) and then load the EMF model at the given uri (the arguments of the main method). If you want to change it, to for example integrate it in a tool or to generate code from an EObject in memory instead of a serialized EMF model, have fun.
Or you can just create a Java class with a different name Smile
Stephane Begaudeau, Obeo.
[Updated on: Tue, 07 December 2010 03:54] by Moderator
Re: Acceleo 3.x - reset generate module problem [message #643523 is a reply to message #643519] Tue, 07 December 2010 04:19 Go to previous message
Hi Stephane,
it works now. Thanks for your support.... Wink
Maik
Previous Topic:execute an accelo plugin directly in the shell
Next Topic:[Xpand] expand in a dynamic binding manner
Current Time: Fri Jul 18 17:15:35 EDT 2025
Powered by FUDForum. Page generated in 0.06186 seconds
