Home » Archived » BIRT » Can't get BIRT installed on TurnKey Linux VM(Either can't be started, or results in 404 page)
Can't get BIRT installed on TurnKey Linux VM [message #642057] Mon, 29 November 2010 12:21 Go to next message
I'm having trouble getting BIRT running and I was hoping for some help. I'm generally experienced working on and managing Linux servers, but this is the first time that I've done anything with Java, so I'm trying to get it set up the simplest way I can. I'm trying to install it onto the "Tomcat on Apache" virtual appliance from Turnkey linux:
http://www.turnkeylinux.org/tomcat-apache
According to the documentation, this includes:
tomcat5.5 5.5.25-5ubuntu1.2
JVM Version 1.6.0_22-b04
sun-java6-jdk 6-16-0ubuntu1.8.04
sun-java6-jre 6-16-0ubuntu1.8.04
ant 1.7.0-3
apache2-mpm-worker 2.2.8-1ubuntu0.11
libapache2-mod-jk 1:1.2.25-2
Ubuntu 8.04.3 LTS
I had thought that using a Turnkey virtual machine (VM) image would simplify the process, but I'm still running into problems. Let me describe the steps I've taken and the problems I've run into.
- Download and install the VM. This worked fine
- Start the VM. This works fine, and I'm able to SSH into the VM. I'm also able to see the following pages without errors:
https://10.4.20.51/admin/frameset.jsp
https://10.4.20.51/manager/html
https://10.4.20.51/host-manager/html
(Note, these addresses seem to be different than the default Tomcat addresses, which use a different port- 8080 or 8180. Could this be a problem? Is BIRT looking for something at a specific port?)
- Download BIRT and move WebViewerExample into the Tomcat path, restart Tomcat:
cd /opt/
mkdir download
cd /opt/download
wget http://carroll.aset.psu.edu/pub/eclipse/birt/downloads/drops/R-R1-2_6_1-201009171723/birt-runtime-2_6_1.zip
unzip birt-runtime-2_6_1.zip
cd birt-runtime-2_6_1
cp -a WebViewerExample /var/lib/tomcat5.5/webapps
mv /var/lib/tomcat5.5/webapps/WebViewerExample/ /var/lib/tomcat5.5/webapps/birt-viewer
- After doing this and viewing the Tomcat Web Application Manager (https://10.4.20.51/manager/html), I can see /birt-viewer listed under the Applications, but its state is Stop. If I click Start, the Message report:
FAIL - Application at context path /birt-viewer could not be started
- At this point I started searching around. Once thing I found is that when I restarted Tomcat, a bunch of errors got written to /var/log/syslog. The first was:
Nov 27 03:53:52 tomcat-apache jsvc.exec[9634]: Nov 27, 2010 3:53:52 AM org.apache.catalina.core.StandardContext listenerStart SEVERE: Exception sending context initialized event to listener instance of class org.eclipse.birt.report.listener.ViewerServletContextListener java.security.AccessControlException: access denied (java.util.PropertyPermission birt.designer read) ^Iat java.security.AccessControlContext.checkPermission(AccessControlContext.java:323) ^Iat java.security.AccessController.checkPermission(AccessController.java:546) ^Iat java.lang.SecurityManager.checkPermission(SecurityManager.java:532) ^Iat java.lang.SecurityManager.checkPropertyAccess(SecurityManager.java:1285) ^Iat java.lang.System.getProperty(System.java:650) ^Iat org.eclipse.birt.report.utility.ParameterAccessor.initParameters(ParameterAccessor.java:1459) ^Iat org.eclipse.birt.report.listener.ViewerServletContextListener.contextInitialized(ViewerServletContextListener.java:56) ^Iat org.apache.catalina.core.StandardContext.listenerStart(StandardCont
Searching for this error lead me to posts that pointed to TOMCAT5_SECURITY. Following those instructions, I found that if I disable TOMCAT5_SECURITY (by setting TOMCAT5_SECURITY=no in /etc/default/tomcat5.5) and restart Tomcat, then the error goes away and Application Manager page shows birt-viewer as running. So that's good. But if I click on the /birt-viewer link to open the page (https://10.4.20.51/birt-viewer), I get a 404. So that's bad. So my first question is, is disabling TOMCAT5_SECURITY a requirement to get BIRT running, or is it indicative of a different problem with my installation? For example, is this the result of something else that I don't have set up correctly (like bad permissions on something)? I've tried chmod'ing everything in birt-viewer to 777 but that didn't help. Also, I don't know anything about TOMCAT5_SECURITY, but the config file says not to disable it unless you know what you're doing, which I don't.
My obvious second question is, why does the Web Application Manager say that birt-viewer is running, but the application page returns a 404? Is it really running and I just can't see the page, or is it not really running?
Once I get this all figured out I'd like to write up a how-to, since this seems like it should be a nice quick way to get BIRT up and running. Thanks for any help you can provide in resolving my issues.
Re: Can't get BIRT installed on TurnKey Linux VM [message #642254 is a reply to message #642057] Tue, 30 November 2010 10:43 Go to previous messageGo to next message
Brad,
Can you open a bug for this?
Jason
> ant 1.7.0-3
> Ubuntu 8.04.3 LTS
> Tomcat:
> cd /opt/
> mkdir download
> cd /opt/download
> wget
> http://carroll.aset.psu.edu/pub/eclipse/birt/downloads/drops /R-R1-2_6_1-201009171723/birt-runtime-2_6_1.zip
> report:
> org.eclipse.birt.report.listener.ViewerServletContextListene r
> java.security.AccessControlContext.checkPermission(AccessCon trolContext.java:323)
> ^Iat
> java.security.AccessController.checkPermission(AccessControl ler.java:546) ^Iat
> java.lang.SecurityManager.checkPermission(SecurityManager.ja va:532) ^Iat
> java.lang.SecurityManager.checkPropertyAccess(SecurityManage r.java:1285)
> org.eclipse.birt.report.utility.ParameterAccessor.initParame ters(ParameterAccessor.java:1459)
> ^Iat
> org.eclipse.birt.report.listener.ViewerServletContextListene r.contextInitialized(ViewerServletContextListener.java:56)
> ^Iat org.apache.catalina.core.StandardContext.listenerStart(Stand ardCont
> running?
Re: Can't get BIRT installed on TurnKey Linux VM [message #643210 is a reply to message #642057] Sun, 05 December 2010 22:17 Go to previous messageGo to next message
I will file a bug report for this, but I wanted to do some more testing first. I tried starting from scratch using a newer VM from TurnKey (their RC version) that contains the following:
Apache Tomcat/6.0.24
JVM Version 1.6.0_20-b20
and now I can start Tomcat without the errors (without having to disable any security features) and with birt-viewer showing as running in the Application Manager page, so I'm making progress. Here's a screenshot of the page:
http://img.skitch.com/20101206-j5qc8dufbk3c22rcr8s3hirwjc.jp g
However I still can't see the birt-viewer page (I get a 404). One thing I'm thinking it might be is the port that Tomcat is using. On the TurnKey VM, they have it set up to use port 80, not 8080. So the Application Manager page is:
http://10.4.20.72/manager/html
(Note 10.4.20.72 is the IP of the VM on my box) If I try to access it via any other ports (e.g., http://10.4.20.72:8080/manager/html) I can't connect to the server, so I'm guessing that birt-viewer needs to be accessed via 80 as well. But going to this link:
http://10.4.20.72/birt-viewer
gives me the 404. Note I've also installed the commons logging library using:
cd /opt/download
wget http://www.devlib.org/apache//commons/logging/binaries/commons-logging-1.1.1-bin.zip
unzip commons-logging-1.1.1-bin.zip
cp /opt/download/commons-logging-1.1.1/commons-logging-1.1.1.jar /var/lib/tomcat6/webapps/birt-viewer/WEB-INF/lib/
/etc/init.d/tomcat6 restart
Here's what I'm seeing in the log files:
root@tomcat-apache log/apache2# tail -n1 /var/log/apache2/error.log
[Mon Dec 06 02:19:46 2010] [error] [client 192.168.2.100] File does not exist: /var/www/birt-viewer, referer: https://10.4.20.72/manager/html
root@tomcat-apache log/apache2# tail -n1 /var/log/apache2/other_vhosts_access.log
127.0.1.1:80 192.168.2.100 - - [06/Dec/2010:02:32:02 +0000] "GET /birt-viewer HTTP/1.1" 404 503 "-" "Mozilla/5.0 (Macintosh; U; Intel Mac OS X 10_6_5; en-us) AppleWebKit/533.19.4 (KHTML, like Gecko) Version/5.0.3 Safari/533.19.4"
Could it be that birt-viewer is hard-wired to run at a port other than 80? Are there any other things I could look at to figure out what's going wrong (like other logs)? Thanks for any help.
Re: Can't get BIRT installed on TurnKey Linux VM [message #643415 is a reply to message #643210] Mon, 06 December 2010 14:06 Go to previous messageGo to next message
This looks like apached ws location:
I assume the viewer does not exist in that location.
What exist in this directory
/var/www
Jason
> the page:
> using:
> cd /opt/download
> wget
> http://www.devlib.org/apache//commons/logging/binaries/commo ns-logging-1.1.1-bin.zip
> cp /opt/download/commons-logging-1.1.1/commons-logging-1.1.1.ja r
Re: Can't get BIRT installed on TurnKey Linux VM [message #643426 is a reply to message #642057] Mon, 06 December 2010 14:51 Go to previous messageGo to next message
Correct, there's just an index page there:
root@tomcat-apache ~# ls -l /var/www
total 4
-rw-r--r-- 1 root root 177 Oct 19 02:24 index.html
So why would would Tomcat be looking for things to be in /var/www instead of in /var/lib/tomcat6/webapps/ where I installed it (as per the Eclipse/BIRT instructions)?
root@tomcat-apache ~# ls -l /var/lib/tomcat6/webapps/
total 8
drwxr-xr-x 7 root root 4096 Sep 17 14:46 birt-viewer
drwxr-xr-x 6 root root 4096 Oct 19 02:26 cp
Note that if I I go to this address:
http://10.4.20.72/cp/
it will be successfully accessing the /var/lib/tomcat6/webapps/cp/ directory. But when I go to this address:
http://10.4.20.72/birt-viewer/
it tries to access the /var/www/birt-viewer/ directory (and fails).
I'm sorry I'm asking such simplistic questions- this is my first time using Tomcat and doing anything with Java (I usually just do Apache/PHP development), so I haven't yet figured out the basic mechanisms of how these applications work. If there's any other information I can provide please let me know.
Re: Can't get BIRT installed on TurnKey Linux VM [message #643437 is a reply to message #643426] Mon, 06 December 2010 15:17 Go to previous message
Brad,
Do you have access to the
httpd.conf file on the appache install?
If so can you email it to me?
jasonweathersby at windstream dot net
Jason
> total 4
> total 8
> please let me know.
Previous Topic:Problems with 2 webapps in one BEA Weblogic
Next Topic:Scripted DataSet problems
Current Time: Wed Jul 23 12:40:56 EDT 2025
Powered by FUDForum. Page generated in 1.10281 seconds
