Home » Language IDEs » Java Development Tools (JDT) » Why JDT does not see my plugins classes?
Why JDT does not see my plugins classes? [message #643073] Fri, 03 December 2010 17:16 Go to next message
Originally posted by: agranov.allmail.net
We have three plugins - studio,support and parser
Studio requires both support and parser (they listed as required in
studio manifest)
If you import all 3 projects into the workspace – everything builds fine
Now export support project to support.jar plugin and/or parser project
to parser.jar plugin
Drop these plugins into eclipse/plugins and remove projects support and
parser from workspace
Studio project will not build now – java compiler does not see classes
from support.jar and/or parser.jar dropped into eclipse/plugins (though
the packages are exported!)
It does not complain – required plugins not found as they are found –
eclipse compiler simply does not see the classes…
But studio uses eclipse API and this API is provided by plugins located
in eclipse/plugins
Why classes only from our plugins are not visible by eclipse java compiler?
I have compared manifests from eclipse API plugins and e.g. our
manifests - the only difference is that in their manifests all classes
are signed:
Example:
og$4.class
SHA1-Digest: jZ6KY96EDYqBrWkVN3exQlyuC+0=
That’s it? That’s the reason?
Thank you very much,
Gennnady
Re: Why JDT does not see my plugins classes? [message #643102 is a reply to message #643073] Sat, 04 December 2010 06:22 Go to previous messageGo to next message
> studio manifest)
A P2 issue I think. Did you try dropping these plugins into
eclipse/dropins instead? Or did you try the 'Install into host' option
in the Plugin export wizard?
> in eclipse/plugins
> are signed:
> Example:
> og$4.class
> Gennnady
Re: Why JDT does not see my plugins classes? [message #643418 is a reply to message #643102] Mon, 06 December 2010 14:07 Go to previous messageGo to next message
Hi, Deepak!
I tried both options suggested by you and unfortunately they did not
help eclipse java compiler to see classes from plugins.
Thanks for trying to help!
Gennady
>> studio manifest)
>> in eclipse/plugins
>> compiler?
>> are signed:
>> Example:
>> og$4.class
>> Gennnady
Re: Why JDT does not see my plugins classes? [message #643419 is a reply to message #643102] Mon, 06 December 2010 14:08 Go to previous messageGo to next message
Hi, Deepak!
Gennady
>> studio manifest)
>> in eclipse/plugins
>> compiler?
>> are signed:
>> Example:
>> og$4.class
>> Gennnady
Re: Why JDT does not see my plugins classes? [message #643431 is a reply to message #643073] Mon, 06 December 2010 15:08 Go to previous message
As Deepak mentioned, you can no longer simply put plugins in the
eclipse/plugins directory.
If you don't need these 2 plugins in your running development
environment, just your build env, you can create a target platform using
Preferences>Plug-in Development>Target Platform. Base your target
platform on your install. Then deploy the 2 plugins that you care about
using File>Export...>Deployable Plug-ins and Fragments. Go back and
edit your target platform to include the 2 plugins.
Other options include deploying the 2 plugins *into* your running
eclipse (which would make the part of the default running platform).
This option can muddy your running eclipse, though.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Previous Topic:Is it possible to have two types with the same name but different (number) of type arguments?
Next Topic:Model Persistance
Current Time: Wed Jul 23 11:24:43 EDT 2025
Powered by FUDForum. Page generated in 0.49154 seconds
