Home » Eclipse Projects » EclipseLink » JPQL statement: wrong generated SQL code?
JPQL statement: wrong generated SQL code? [message #643405] |
Mon, 06 December 2010 13:50  |
I have the following tables:
CREATE TABLE Rosters
id INTEGER NOT NULL,
club_abbr VARCHAR(10) NOT NULL,
ordinal_nbr SMALLINT,
PRIMARY KEY (id)
CREATE TABLE Games
scheduled_tipoff DATETIME NOT NULL,
PRIMARY KEY (id)
CREATE TABLE Scores
game_id INTEGER NOT NULL,
is_home BOOLEAN NOT NULL,
roster_id INTEGER NOT NULL,
final_score SMALLINT DEFAULT NULL NULL,
PRIMARY KEY (game_id, is_home),
FOREIGN KEY (game_id) REFERENCES Games (id),
FOREIGN KEY (roster_id) REFERENCES Rosters (id)
Simple logic, a game has two scores, home and away, which are associated with a roster ID. The Scores table is
basically a join table between games and rosters.
I then want to add up all games per roster using the JPQL statement:
SELECT NEW tld.jpqlsum.view.StringLine(
SUM(sf.finalScore)
, SUM(sa.finalScore)
, AVG(sf.finalScore)
, AVG(sa.finalScore)
, MIN(sf.finalScore)
, MIN(sa.finalScore)
, MAX(sf.finalScore)
, MAX(sa.finalScore)
FROM Game ga
JOIN ga.scores sf
JOIN ga.scores sa
WHERE ga.id <> 57 AND sf.roster.id = 1 AND sa.roster.id <> 1
GROUP BY sf.roster.id
This should yield a cumulated view of all played games. EclipseLink (HSQLDB) generates:
SELECT
SUM(t0.final_score),
AVG(t0.final_score),
MIN(t0.final_score),
MAX(t0.final_score),
MAX(t0.final_score)
FROM Scores t3, Rosters t2, Games t1, Scores t0
WHERE ((((t1.id <> ?) AND (t0.roster_id = ?)) AND (t3.roster_id <> ?)) AND (((t0.game_id = t1.id) AND (t3.game_id = t1.id)) AND (t2.id = t0.roster_id)))
GROUP BY t2.id
Result set:
|SUM(sf.finalScore)|SUM(sa.finalScore)|AVG(sf.finalScore)|AVG(sa.finalScore)|MIN(sf.finalScore)|MIN(sa.finalScore)|MAX(sf.finalScore)|MAX(sa.finalScore)|
| 856| 856| 71.0| 71.0| 50| 50| 89| 89|
As you can see, the columns for scores for and against (sf and sa in the JPQL) have exactly the same values, but that
shouldn't be the case. The generated code appears to be wrong, because it always uses t0, which can't work. So the code
generator must be buggy. Can anyone confirm this?
Another bug that seems to be present is with the AVG function: 856 points / 12 games = 71.333333333333333... not 71.0.
Cast missing?
Hibernate (HSQLDB and HSQLDialect) generates:
select
sum(scores1_.final_score) as col_0_0_,
sum(scores2_.final_score) as col_1_0_,
avg(cast(scores1_.final_score as double)) as col_2_0_,
avg(cast(scores2_.final_score as double)) as col_3_0_,
min(scores1_.final_score) as col_4_0_,
min(scores2_.final_score) as col_5_0_,
max(scores1_.final_score) as col_6_0_,
max(scores2_.final_score) as col_7_0_
from
Games game0_
inner join
Scores scores1_
on game0_.id=scores1_.game_id
inner join
Scores scores2_
on game0_.id=scores2_.game_id
where
game0_.id<>57
and scores1_.roster_id=1
and scores2_.roster_id<>1
group by
scores1_.roster_id
Hibernate (MySQL and MySQLDialect) generates almost the same code:
select
avg(scores1_.final_score) as col_2_0_,
avg(scores2_.final_score) as col_3_0_,
from
Games game0_
inner join
Scores scores1_
inner join
Scores scores2_
where
game0_.id<>57
group by
scores1_.roster_id
As you can see, Hibernate generates alternating scores1 and scores2 in the select clause.
Note, that HSQLDB and Hibernate also produce a wrong output (not shown), which isn't relevant here though. Only
Hibernate on MySQL produces the correct output:
| 856| 881| 71.3333| 73.4167| 50| 43| 89| 101|
I also replaced the t0 with t3 at the appropriate places in the EclipseLink generated SQL and it also produces the
above.
Looks like a bug to me with more than one join onto the same entity/table more than once. Another bug is the AVG
function trancating the fractional part.
Here's an SSCCE (JavaSE, HSQLDB, Ant):
http://www.kawoolutions.com/media/jpqlsum-el-hsqldb-broken.z ip
Just type "ant run" from a shell. Also see the db dir for a visual DB design and ISO/ANSI SQL scripts.
Can anyone confirm this? I'll file a bug report then...
Karsten
[Updated on: Mon, 06 December 2010 13:55] by Moderator
Current Time: Sat Jul 26 23:13:42 EDT 2025
Powered by FUDForum. Page generated in 0.05729 seconds
