Home » Eclipse Projects » Rich Client Platform (RCP) » p2 director: Any success/failure tests?
p2 director: Any success/failure tests? [message #642717] Thu, 02 December 2010 08:16 Go to next message
[The eclipse.p2 newsgroup seems to be completely silent.
Therefore I retry on this group.]
Our installation program is supposed to allow installation of additional
plugins to our RCP application using the p2 director as described in
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/p2_director.html
1) How can we test that the installation succeeds?
2) There exists the parameter -verifyOnly described as
"only verify that the actions can be performed. Don't actually install
or remove anything."
First, I observe that calling with this parameter changes *something*,
e.g. there are new directories in the configuration folder after that.
Second, the same question applies to this call: How can we recognice a
success?
I observe that on failure a .log file is produced in the configuration
directory, but this seems not to be documented (AFAIK). Are we really
supposed to search for such a log file as indicator?
Thanks & Greetings from Bremen,
Daniel Krügler
Re: p2 director: Any success/failure tests? [message #642808 is a reply to message #642717] Thu, 02 December 2010 13:30 Go to previous messageGo to next message
Wouldn't the director return a "failed" exit code if it fails? Although
that's more reliable to check on linux than on all platforms.
You can use the director call with your application profile and -list to
check if it was installed. ex:
eclipse/eclipse -noSplash \
-application org.eclipse.equinox.p2.director \
-repository \
file:$(pwd)/eclipse/p2/org.eclipse.equinox.p2.engine/profile Registry/SDKProfile.profile
-list
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: p2 director: Any success/failure tests? [message #642895 is a reply to message #642808] Fri, 03 December 2010 04:00 Go to previous messageGo to next message
According to our installation guys it doesn't (we have a Windows
platform). Even worse: It seems that calling the director does not
invoke synchronously: The installation cannot just delete temporary
files immediately after the invocation, because the process may still
need to access the files. This makes it hard to integrate the director
into our installation process.
> -repository \
> -list
The description of -list only says:
"lists all IU's found in the given repositories in a property like
format. IUs can optionally be listed. Each entry in the list is in the
form <id> [ '/' <version> ]."
This does not sound as if this would be useful for a validation. In
fact, I don't want that the installer is required to know all IU's that
were installed (this is only interesting for an after-the-fact
analysis), but I want to get feedback, whether the installation has
succeeded or not. Details of failures are relevant after this (and one
could try to search for the most recently written log file), but the
lack of a general OK/ERROR feedback from the director is very bad in a
multi-step installation that needs to ensure that each step (among which
the director call is only one) has succeeded or not.
Daniel Krügler
Re: p2 director: Any success/failure tests? [message #643308 is a reply to message #642895] Mon, 06 December 2010 08:03 Go to previous messageGo to next message
that's probably because by default, eclipse.exe calls javaw.exe. That's
not what you want (maybe call it with -vm c:\whatever\bin\java.exe
instead of javaw.exe).
If you were to run java.exe -jar
eclipse\plugins\org.eclipse.equinox.launcher_1.2.0.v20101119 .jar
-application org.eclipse.equinox.p2.director <rest of command>
and it doesn't return non-0 on fail, open a bug against RT Equinox
Framework (or there might be a launcher component now).
PW
Paul Webster
Re: p2 director: Any success/failure tests? [message #643357 is a reply to message #643308] Mon, 06 December 2010 10:38 Go to previous message
Thanks Paul, this sounds like a brilliant idea - we will test this
approach and give feedback to the group!
- Daniel
Previous Topic:set availible software update site while creating the product
Next Topic:ToolBar update upon perspective switch
Current Time: Sat Jul 26 09:55:18 EDT 2025
Powered by FUDForum. Page generated in 0.04653 seconds
