Home » Archived » M2M (model-to-model transformation) » [ATL] About internal traceability links in ATL
[ATL] About internal traceability links in ATL [message #643270] Mon, 06 December 2010 05:33 Go to next message
Hi all,
after reading "Loosely Coupled Traceability for ATL" written by Frédéric
Jouault I have a question about the internal traceability links in ATL.
That paper states that internal traceability links in ATL are links
labelled with the rule name and targetting the input and output element.
If that's true, I wonder how the resolveTemp() operation works, because
that expects the name of the output pattern variable and not the rule
name. So I guess that (at least nowadays) the internal traceability
links are triples of the form (outputPatternVarName, sourceObject,
targetObject). Is that correct?
Bye,
Tassilo
Dipl.-Inform. Tassilo Horn | Room: B015
University of Koblenz-Landau, Campus Koblenz | Phone: +49 (261) 287-2745
Institute for Software Technology | Mail: horn@uni-koblenz.de
Universitätsstr. 1, 56070 Koblenz, Germany |
Re: [ATL] About internal traceability links in ATL [message #643271 is a reply to message #643270] Mon, 06 December 2010 05:52 Go to previous messageGo to next message
I'd suggest you to have a look at the TransientLink and TransientLinkSet classes in org.eclipse.m2m.atl.engine.emfvm.lib.
Re: [ATL] About internal traceability links in ATL [message #643278 is a reply to message #643271] Mon, 06 December 2010 06:26 Go to previous message
Sylvain EVEILLARD <s.eveillard@netfective.com> writes:
Hi Sylvain,
According to
http://ftp.kaist.ac.kr/eclipse/modeling/m2m/atl/javadoc/3.2. 0/org/eclipse/m2m/atl/engine/emfvm/lib/TransientLink.html
(that's the most current API docs I could find), it's an undocumented
feature. :-)
Fun aside: I can see that indeed the rule name can be stored with a
link, and both source as well target elements are referenced in terms of
Maps, but since the Maps are from Object to Object, it's not easy to
reason about their contents...
Bye,
Tassilo
Previous Topic:[QVTO] Example of a where-clause for a mapping operation
Next Topic:[ATL] How does ATL accept instances of two related models
Current Time: Wed Jul 16 04:57:42 EDT 2025
Powered by FUDForum. Page generated in 0.09447 seconds
