Home » Modeling » M2T (model-to-text transformation) » export an acceleo plugin on .jar
export an acceleo plugin on .jar [message #642900] Fri, 03 December 2010 04:45 Go to next message
I tried to export an acceleo plugin to .jar and call java -jar plugin.jar to execute it.
I get this pb although I specified the class generator as main class while exporting the plugin
java -jar org.eclipse.acceleo.module.sample
Exception in thread "main" java.lang.NoClassDefFoundError: org/eclipse/acceleo/engine/service/AbstractAcceleoGenerator
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:637)
at java.security.SecureClassLoader.defineClass(SecureClassLoade r.java:142)
at java.net.URLClassLoader.defineClass(URLClassLoader.java:277)
at java.net.URLClassLoader.access$000(URLClassLoader.java:73)
at java.net.URLClassLoader$1.run(URLClassLoader.java:212)
at java.net.URLClassLoader.findClass(URLClassLoader.java:205)
at java.lang.ClassLoader.loadClass(ClassLoader.java:323)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:294 )
at java.lang.ClassLoader.loadClass(ClassLoader.java:268)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:336 )
Caused by: java.lang.ClassNotFoundException: org.eclipse.acceleo.engine.service.AbstractAcceleoGenerator
at java.net.URLClassLoader$1.run(URLClassLoader.java:217)
... 12 more
Could not find the main class: org.eclipse.acceleo.module.sample.files.Generate. Program will exit.
any idea ?
Asma
Re: export an acceleo plugin on .jar [message #643239 is a reply to message #642900] Mon, 06 December 2010 03:40 Go to previous message
It seems that your are missing a dependency with the Acceleo runtime (org.eclipse.acceleo.engine).
Stephane Begaudeau, Obeo.
Previous Topic:[Acceleo 3.1.0M3] install site.xml
Next Topic:[check] Problem with check under Helios
Current Time: Sat Jul 26 17:58:03 EDT 2025
Powered by FUDForum. Page generated in 0.17656 seconds
