Home » Modeling » EMF » How to create an apply a UML2 stereo-type using EMF in a standalone app?
How to create an apply a UML2 stereo-type using EMF in a standalone app? [message #643194] Sun, 05 December 2010 18:21 Go to next message
I have written the sample code below to create an EJB stereotype an apply it to the TimeEntry class:
import java.io.File;
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.Resource.Factory;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.eclipse.emf.ecore.resource.impl.ResourceSetImpl;
import org.eclipse.emf.ecore.util.EcoreUtil;
import org.eclipse.uml2.uml.*;
import org.eclipse.uml2.uml.Class;
import org.eclipse.uml2.uml.Package;
import org.eclipse.uml2.uml.UMLPackage.Literals;
import org.eclipse.uml2.uml.resource.UMLResource;
public class SampleProfile
  private static final ResourceSet RESOURCE_SET = new ResourceSetImpl();
  public static void main( String[] args ) throws Exception
    Factory.Registry.INSTANCE.getExtensionToFactoryMap().put(
      UMLResource.FILE_EXTENSION,
      UMLResource.Factory.INSTANCE
    final Model umlMetamodel = (Model) loadPackage( UMLResource.UML_METAMODEL_URI );
    final Model sampleModel = UMLFactory.eINSTANCE.createModel();
    sampleModel.setName( "Sample Model" );
    final Profile sampleProfile = UMLFactory.eINSTANCE.createProfile();
    sampleProfile.setName( "Sample Profile" );
    final Stereotype ejbStereo = sampleProfile.createOwnedStereotype( "EJB" );
    extendMetaclass( umlMetamodel, sampleProfile, "Class", ejbStereo );
    sampleProfile.define();
    final Package samplePackage = sampleModel.createNestedPackage( "sample" );
    samplePackage.applyProfile( sampleProfile );
    final Class sampleClass = samplePackage.createOwnedClass( "TimeEntry", false );
    sampleClass.applyStereotype( ejbStereo );
    final File outputFile = new File( "sample_model.uml" );
    final URI outputUri = URI.createFileURI( outputFile.getAbsolutePath() );
    final Resource resource = RESOURCE_SET.createResource( outputUri );
    resource.getContents().add( sampleModel );
    resource.getContents().add( sampleProfile );
    resource.save( null );
  private static Package loadPackage( final String uri )
    System.out.println( "uri = " + uri );
    final Resource resource = RESOURCE_SET.getResource( URI.createURI( uri ), true );
    EcoreUtil.resolveAll( resource );
    return (org.eclipse.uml2.uml.Package) EcoreUtil.getObjectByType( resource.getContents(), Literals.PACKAGE );
  private static void extendMetaclass( final Model umlMetamodel,
                                       final Profile profile,
                                       final String name,
                                       final Stereotype stereotype )
    stereotype.createExtension( referenceMetaclass( umlMetamodel, profile, name ), true );
  private static org.eclipse.uml2.uml.Class referenceMetaclass( final Model umlMetamodel,
        final String name )
    final Class metaclass = (Class) umlMetamodel.getOwnedType( name );
    profile.createMetaclassReference( metaclass );
    return metaclass;
However running the application, I get this error message in the console:
uri = pathmap://UML_METAMODELS/UML.metamodel.uml
Exception in thread "main" org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: java.net.MalformedURLException: unknown protocol: pathmap
    at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:315)
    at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
    at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:397)
Any ideas what's probably wrong with my code and how this problem can be solved? The application is a command-line app that runs outside Eclipse.
Re: How to create an apply a UML2 stereo-type using EMF in a standalone app? [message #643196 is a reply to message #643194] Sun, 05 December 2010 18:42 Go to previous messageGo to next message
Behrang,
This is best asked on the UML2 newsgroup. I believe they have
documentation for all the pathmap URI mappings you'll need to set...
Ed
> "EJB" );
> "sample" );
> uri ), true );
> final String name,
> Model umlMetamodel,
> final
> Profile profile,
> final
> String name )
> return metaclass;
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException:
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:315)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:274)
> at
> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:397)
> Eclipse.
Re: How to create an apply a UML2 stereo-type using EMF in a standalone app? [message #643197 is a reply to message #643196] Sun, 05 December 2010 19:07 Go to previous messageGo to next message
Where's the UML2 newsgroup? Couldn't find it in the list of newsgroups.
Also, I have simplified the code to:
import java.net.URL;
import org.eclipse.emf.ecore.resource.URIConverter;
    throws Exception
    final String umlProfile = "metamodels/UML.metamodel.uml";
    final URL url = SampleProfile.class.getClassLoader().getResource( umlProfile );
    String baseUrl = url.toString();
    baseUrl = baseUrl.substring( 0, baseUrl.length() - umlProfile.length() );
    registerPathmaps( URI.createURI( baseUrl ));
    Model umlMetamodel = (Model) load( URI.createURI( UMLResource.UML_METAMODEL_URI ) );
    System.out.println( "umlMetamodel = " + umlMetamodel );
  protected static void registerPathmaps( URI baseUri )
    System.out.println( "baseUri = " + baseUri );
    URIConverter.URI_MAP.put(URI.createURI( UMLResource.LIBRARIES_PATHMAP ), baseUri.appendSegment( "libraries" ).appendSegment( "" ));
    URIConverter.URI_MAP.put(URI.createURI( UMLResource.METAMODELS_PATHMAP ), baseUri.appendSegment( "metamodels" ).appendSegment( "" ));
    URIConverter.URI_MAP.put(URI.createURI( UMLResource.PROFILES_PATHMAP ), baseUri.appendSegment( "profiles" ).appendSegment( "" ));
Now the problem is that it returns null for the UML meta model.
Behrang
Re: How to create an apply a UML2 stereo-type using EMF in a standalone app? [message #643199 is a reply to message #643197] Sun, 05 December 2010 19:16 Go to previous messageGo to next message
I guess you found it; I see your post there.
> throws Exception
> umlProfile );
> String baseUrl = url.toString(); baseUrl = baseUrl.substring(
> Cheers,
> Behrang
Re: How to create an apply a UML2 stereo-type using EMF in a standalone app? [message #643200 is a reply to message #643199] Sun, 05 December 2010 19:24 Go to previous message
Yes, I just found it. It was in the parent listing...
Thanks anyway.
Previous Topic:How to create a dynamic instances of two dependant Metamodels
Next Topic:Default Values of simpleContent
Current Time: Thu Nov 06 04:41:11 EST 2025
Powered by FUDForum. Page generated in 0.19243 seconds
