EClassifier.isInstance behavior [message #642966] |
Fri, 03 December 2010 09:34  |
say that in my meta model I have 'Field' which inherits from 'TypedElement'.
Now, if I have an EClass for TypedElement, say C, and I have an instance
of Field, say f, I would expect
C.isInstance(f)
to return true, but it returns false.
By debugging, I see that it calls
protected boolean dynamicIsInstance(EObject eObject)
return isSuperTypeOf(eObject.eClass());
and then it calls
public boolean isSuperTypeOf(EClass someClass)
return someClass == this ||
someClass.getEAllSuperTypes().contains(this);
the checking is done using == i.e., object identities (also contains
uses == for comparison), and thus the check fails, although
getEAllSuperTypes actually contains an EClass for TypedElement...
is it the desired semantics?
of course I can implement manually my intended behavior, but I was
curios about this...
thanks in advance
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
Re: EClassifier.isInstance behavior [message #643006 is a reply to message #642966] |
Fri, 03 December 2010 10:51  |
Lorenzo,
Comments below.
Lorenzo Bettini wrote:
> Hi
> 'TypedElement'.
> instance of Field, say f, I would expect
> C.isInstance(f)
> and then it calls
No, at best it contains a copy that may or may not be structurally "the
same".
Definitely. This is exactly what Java does as well. You can have
multiple loaded copies of "the same" java.lang.Class, but .equals will
return false and instances will not be assignment compatible.
I doubt you can implement it consistently. You'd have to define
structural equality and the testing of it would have to cover the entire
graph of objects associated with the class, i.e., the containing package
and everything reachable from it would need to be structurally equal (or
minimally everything reachable from references in the class). Can you
imagine having to perform such a massive test just to do isInstance
checking? The system will grind to a halt doing the most trivial of
things. Don't go there. Best to ensure that everything is using the
right instance of the class....
> thanks in advance
> Lorenzo
FUDForum. Page generated in 0.06139 seconds
