Home » Eclipse Projects » Rich Client Platform (RCP) » Sharing state between different commands
Sharing state between different commands [message #642941] Fri, 03 December 2010 07:41 Go to next message
We have the following situation where it would be nice to realize state
sharing between *different* commands.
E.g. consider a org.eclipse.ui.commands command that describes a
radio-state where we re-use the org.eclipse.ui.commands.radioState state
as nicely described in the article:
http://blog.eclipse-tips.com/2009/03/commands-part-6-toggle- radio-menu.html
The radio-state we are administrating here is some look&feel identifier
and the corresponding handler applies this look&feel - this works
without problems.
Now we have a *different* command, which is supposed perform two steps:
1) Loading data into a viewer
2) Applying the look&feel as controlled by above radio-state-handler
Step (1) is specific for the second command (handler), no question, but
ideally - to realize (2) - we would like to evaluate the state of the
first radio-state handler to do different stuff based on that state. The
problem is, that by quering
event.getParameter(RadioState.PARAMETER_ID)
we obviously get null, because we are asking the wrong event for it. Is
there a way to ask for the specific parameter value of another command
in this context?
I know that I could use an AbstractSourceProvider to share state
globally, but that would (IMO) not allow to take advantage of the
additional command parameter functionality (e.g. defining the radio
state at the org.eclipse.ui.menus implementation).
Is there some way to realize that?
Thanks & Greetings from Bremen,
Daniel Krügler
Re: Sharing state between different commands [message #642949 is a reply to message #642941] Fri, 03 December 2010 08:09 Go to previous messageGo to next message
> without problems.
> in this context?
Let me add more information: Since after (1) we want to invoke the first
radio-state handler I used the IHandlerService.executeCommand method
(with second argument null): That invokes the right command, but it's
state values are all null. How can I activate the handler such that it's
current state is transmitted as well?
> Daniel Krügler
Re: Sharing state between different commands [message #643025 is a reply to message #642941] Fri, 03 December 2010 12:08 Go to previous messageGo to next message
You need to get hold of the command (probably from ICommandService) and
then call radioStateCommand.getState() to get the current state.
- Prakash
Platform UI Team, IBM
www.eclipse-tips.com
Re: Sharing state between different commands [message #643027 is a reply to message #642949] Fri, 03 December 2010 12:10 Go to previous messageGo to next message
I guess you are calling executeCommand(String, Event). Call the
overloaded method executeCommand(ParameterisedCommand, Event)
- Prakash
Re: Sharing state between different commands [message #643233 is a reply to message #643027] Mon, 06 December 2010 03:15 Go to previous messageGo to next message
Yes, this is correct.
> Call the
Hmmh, maybe I'm misunderstanding something fundamental, but wouldn't
this imply that I need to fill the first argument with the corresponding
parameter values on my own? If so, this is not my intention: The
corresponding command get's it's parameter values from it's own state
that I don't want to manually change. What I don't understand is that
this state seems to be empty when invoked via the first executeCommand
overload.
Daniel Krügler
Re: Sharing state between different commands [message #643269 is a reply to message #643025] Mon, 06 December 2010 05:32 Go to previous message
Thanks Prakash: Yes, I finally found this solution and it is the correct
one, if I would just to implement my own logic based on this state.
What I don't understand is the following: If I want to invoke another
command from the given command with state via the IHandlerService, I
cannot do this via the
Object executeCommand(String commandId, Event event);
method, but must instead use the overload:
Object executeCommand(ParameterizedCommand command, Event event);
This looks odd to me, because the parameter is a result of an associated
state. Let's assume that the called handler has a
org.eclipse.ui.handlers.RadioState, I now must create a
ParameterizedCommand object that is filled with the state that I need to
read from the command, because otherwise the command parameter within
the called command is not set (null).
I understand that it must be empty, because no-one has set it yet
(usually the menu contribution will set it). So one might assume that
the command should not ask for the parameter but for the state instead.
This would also not work, because then it would never change its radio
state, though.
I think what I'm missing would be a function that just created a
ParameterizedCommand based on the parameter state - Does there exist
something like that?
Daniel Krügler
Previous Topic:Problem in creating new rcp project when rap is installed
Next Topic:Can I open a view in detached mode programmatically?
Current Time: Wed Jul 23 03:57:57 EDT 2025
Powered by FUDForum. Page generated in 0.31234 seconds
