Re: The import org.eclipse.swt.ole cannot be resolved (again) [message #642920 is a reply to message #642907] |
Fri, 03 December 2010 10:39 |
On 2010-12-03 11:08, Stephan wrote:
> Hi Thomas
> My target platform is stored in a directory that contains a layout as exported by the Buckminster Hudson plugin when
> "Archive and publish an Eclipse Target Platform" is selected. What is the expected difference between "Profile" and
> "Directory" location types?
A "Directory" contains a p2 artifact repository with plug-ins in installed form (i.e. jars normally unpacked during
install will be in folder form, not jars).
To be honest, I've never used the "Archive and publish an Eclipse Target Platform" myself, so I don't know what the
resulting layout looks like. Perhaps Johannes Utzig (author of the Hudson plug-in) can answer that.
Thomas Hallgren
Re: The import org.eclipse.swt.ole cannot be resolved (again) [message #642939 is a reply to message #642936] |
Fri, 03 December 2010 12:40 |
Hi Stephan,
On 2010-12-03 13:33, Stephan wrote:
> Hi Thomas
> The archived target platform from the Buckminster Hudson plugin has the following contents:
> artifacts.xml
> features
> - features/org.eclipse.equinox.executable_3.4.1.R36x_v20100823 -7M7K7JF90dnJ-WLf3cf4yi
> - features/org.eclipse.equinox.executable_3.4.1.R36x_v20100823 -7M7K7JF90dnJ-WLf3cf4yi/license.html
> plugins
> - plugins/org.eclipse.equinox.p2.artifact.repository_1.1.1.R36 x_v20100901.jar
> - plugins/org.eclipse.ui.intro.universal_3.2.402.r36_v20100702
> -- plugins/org.eclipse.ui.intro.universal_3.2.402.r36_v20100702 /plugin.xml
> All features and some plugins are extracted so I assume this is the correct form for setpref targetPlatformPath, isnt't it?
Yes, it looks correct. What buckminster does when you use the targetPlatformPath preference is that it creates a target
platform definition similar to the one you have but with the type "Directory". That's the only difference I can see.
Buckminster then uses the same mechanism for importing this platform as it does when you use the importtargetplatform
command.
What kind of errors do you see?
- thomas
FUDForum. Page generated in 0.04778 seconds
