Home » Modeling » TMF (Xtext) » [solved] Content Assist with "dynamic templates"
[solved] Content Assist with "dynamic templates" [message #642432] Wed, 01 December 2010 05:24 Go to next message
I have a simple DSL
Model: AbstractObject | InstanzObject;
AbstractObject: 'AbstractObject' name=ID
    (propertyDecls+=PropertyDecl)*
InstanzObject : 'InstanzObject' name=ID 'implements' base=[AbstractObject]
    (propertyDefs+=PropertyDefs)*
PropertyDecl: type=TYPE name=ID;
PropertyDef: name=[PropertyDecl]  ':=' value=VALUE;
to describe object models like
AbstractObject BaseObject
  int PropertyA
  string PropertyB
InstanzObject Object1 implements BaseObject
  PropertyA := 5
  PropertyB := "Hello World"
Now I want to achieve the user may type up to
and to get a template implementation like
  PropertyA := <int>
  PropertyB: = <string>
automatically by consulting the content assist. Thus the user has only to fill in the values.
Currently the content assist only gives me the '{' as an option after "BaseObject". Instead it should generate the whole block depending on the referenced AbstractObject.
Is it possible to do it? Can somebody give me a hint which completion method inside the MyDslProposalProvider I have to implement? And how to get the relevant data from the reference?
Thank you in advance,
Jonatan
[Updated on: Thu, 16 December 2010 04:31] by Moderator
Re: Content Assist with "dynamic templates" [message #642435 is a reply to message #642432] Wed, 01 December 2010 05:38 Go to previous messageGo to next message
You don't do this using the content assist but using Template Proposals: see §7.4 of the User Guide.
Re: Content Assist with "dynamic templates" [message #642666 is a reply to message #642432] Thu, 02 December 2010 04:16 Go to previous messageGo to next message
I think you will have to override completeKeyword in AbstractJavaBasedContentProposalProvider.
call super and check if the keyword is an opening brace. If so you can query the contentAssistContext for the current model element. This should give you access to the InstanzObject and now you can navigate the extended object to collect the properties and calculate the completion string.
If you want navigation through the properties (using tab) you will have to use code templates as Meinte says. However, "dynamic" templates as you need them are not supported out of the box.
Alex
Re: Content Assist with "dynamic templates" [message #642679 is a reply to message #642432] Thu, 02 December 2010 05:08 Go to previous messageGo to next message
Hi Jonathan,
Xtext supports somewhat limited placeholders in content proposals out of
the box. Please have a look at
TerminalsProposalProvider#createStringProposal and digg into
ConfigurableCompletionProposal#setSimpleLinkedMode. However, multiple
linked fields in your proposal are not supported out of the box and
you'll have to implement that on your own.
Sebastian
Am 01.12.10 11:24, schrieb jantoni@web.de:
> Hello,
> I have a simple DSL
> int PropertyA
> string PropertyB
> PropertyA := 5
> PropertyA := <int>
> Jonatan
Re: Content Assist with "dynamic templates" [message #645251 is a reply to message #642679] Thu, 16 December 2010 04:30 Go to previous messageGo to next message
Hello all,
thank you for your ideas.
I have figured out a solution. It is not the best way I guess, but the way I was able to do it quickly.
I have just enhanced the org.xtext.mydsl.ui.MyDSLProposalProvider class.
public void completeInstanzObject_base(EObject model, Assignment assignment, ContentAssistContext context, ICompletionProposalAcceptor acceptor) {
	super.completeInstanzObject_base(model, assignment, context, acceptor);
	InstanzObject instanz = (InstanzObject)context.getCurrentModel();
	AbstractObject abstract = instanz.getbase();
	EList<PropertyDecl> properties = abstract.getpropertyDefs();
	String dstr = abstract.getname() + " { [..] } - Instanz Template";
	String pstr = abstract.getname() + "\r\n";
	pstr += "{\r\n";
	for (PropertyDecl property: properties) {
		pstr += property.getname() + ":= <" + property.gettype() + ">\r\n";
	pstr += "}\r\n";
	ICompletionProposal proposal = createCompletionProposal(pstr, dstr, null, context);
	acceptor.accept(proposal);
This way the template is constructed on the fly.
Jonatan
Re: Content Assist with "dynamic templates" [message #645436 is a reply to message #645251] Fri, 17 December 2010 04:23 Go to previous message
note that this is not really a "template" but a simple completion proposal. That is, navigating through the properties using tab is not possible.
Alex
Previous Topic:Outline view problem
Next Topic:[SOLVED] Related file not rebuilt after modification
Current Time: Fri Jul 18 02:00:00 EDT 2025
Powered by FUDForum. Page generated in 0.09565 seconds
