Home » Modeling » M2T (model-to-text transformation) » [Acceleo] More inheritance bugs?
[Acceleo] More inheritance bugs? [message #642377] Wed, 01 December 2010 00:44 Go to next message
Hi Larurent:
I believe I may have run into another more serious bug. Before I spend the time to enter simplified code, I'll explain briefly and you can let me know if you've seen this and/or tested this scenario.
I have what should be a common scenario. There are two modules (say A and B) that extend a common base module C. Each of the two modules A and B override the same template T in the base module C.
What appears to be a bug is that I'm actually getting A's overridden T output in B instead of B's overridden T output.
Jeff
Re: [Acceleo] More inheritance bugs? [message #642387 is a reply to message #642377] Wed, 01 December 2010 02:35 Go to previous messageGo to next message
Hi Jeff,
I tried several time but I couldn't reproduce your bug, I just have the normal result: click me
Could you explain a bit more (or take a screenshot like me) of the configuration that is creating your problem ?
Stephane Begaudeau, Obeo.
Re: [Acceleo] More inheritance bugs? [message #642497 is a reply to message #642387] Wed, 01 December 2010 10:33 Go to previous messageGo to next message
Here's a boiled down version of the code. The generated code for edit gets the same execute body as the code for delete. Delete generates correctly. A workaround would be greatly appreciated.
[module main()/]
[template public mainTop(anItem : Item)]
	[comment @main /]
	[for (aDelete : Delete | anItem.menu.items->select(oclIsKindOf(Delete)))]
		[aDelete.Delete(anItem)/]
	[/for]
	[for (anEdit : Edit | anItem.menu.items->select(oclIsKindOf(Edit)))]
		[anEdit.Edit(anItem)/]
	[/for]
[/template]
[module Edit() extends MenuItemTemplate /]
[template public menuItemExecuteBody(anItem : Item) overrides menuItemExecuteBody]
	anItem.execute1(anItem.execute1);
[/template]
[template public Edit(e : Edit, anItem : Item)]
	[file ('/src/com/xyz/menuitems/'.concat(e.name.toUpperFirst().concat('.java')), false, 'Cp1252')]
		[menuItemMain(e,anItem)/]
	[/file]
[/template]
[module Delete() extends MenuItemTemplate/]
[template public Delete(d : Delete, anItem : Item)]
	[file ('/src/com/xyz/menuitems/'.concat(d.name.toUpperFirst().concat('.java')), false, 'Cp1252')]
		[menuItemMain(d,anItem)/]
	[/file]
[/template]
    execute2(an[anItem.name.toUpperFirst()/])
[/template]
[module MenuItemTemplate()/]
[template public menuItemTemplate(m : Item, anItem : Item)]
	[menuItemMain(m, anItem)/]
[/template]
[template public menuItemMain(m : Item, anItem : Item)]
	[menuItemPackage(anItem)/]
	[menuItemImports(anItem)/]
	[menuItemClass(m, anItem)/]
[/template]
[template public menuItemClass(m : Item, anItem : Item)]
	public class [m.name.toUpperFirst()/] implements MenuItem {
		[menuItemExecuteMethod(anItem)/]
[/template]
[template public menuItemPackage(anItem : Item)]
package com.xyz.[anItem.name.toLower()/].menuitems;
[/template]
[template public menuItemImports(anItem : Item)]
import com.xyz.[anItem.name.toLower()/].[anItem.name.toUpperFirst()/];
[/template]
[template public menuItemExecuteMethod(anItem : Item)]
	public void execute(final [anItem.name.toUpperFirst()/] an[anItem.name.toUpperFirst()/]) {
		[menuItemExecuteBody()/]
[/template]
[template public menuItemExecuteBody(anItem : Item)]
	error: unimplemented (by the way Acceleo team, it would be nice if there were language support for erroring here with an abstract keyword.)
[/template]
Re: [Acceleo] More inheritance bugs? [message #642521 is a reply to message #642497] Wed, 01 December 2010 11:24 Go to previous messageGo to next message
Is this a misunderstanding of scope rules for inheritance? I am assuming that a module is akin to a class, and that when I override a template in one module, it shouldn't affect overrides in other modules.
If my assumption is wrong, please correct me.
Thanks!
Jeff
Re: [Acceleo] More inheritance bugs? [message #642623 is a reply to message #642521] Wed, 01 December 2010 22:11 Go to previous messageGo to next message
I created a small project that demonstrates the bug/problem. You can get the files here.
Once you get everything built and you execute main.mtl, note that NameA.java ends up incorrectly having the line execute body:
I
temBExecute(anItemHolderName)
instead of
ItemAExecute(anItemHolderName)
Thanks!
Jeff
Re: [Acceleo] More inheritance bugs--Disregard [message #642633 is a reply to message #642623] Thu, 02 December 2010 00:13 Go to previous message
Please disregard this problem. I think it was due to my misunderstanding of how inheritance works in Acceleo/MTL. I fixed the problem by adding the specialized Items: ItemA, ItemB to the parameter list of the problematic templates.
I think I was thinking of modules as similar to Java classes and expecting the overloading to work throughout the module automatically.
Jeff
Previous Topic:[Acceleo 3] Run transformation from java code
Next Topic:[Acceleo 3.1.0M3] install site.xml
Current Time: Tue Sep 16 06:27:30 EDT 2025
Powered by FUDForum. Page generated in 0.03572 seconds
