Home » Modeling » Epsilon » Add templates non-invasively
Add templates non-invasively [message #642485] Wed, 01 December 2010 09:36 Go to next message
I'm considering to use Epsilon EGL in my projects since it is a very promising generator tool. However, I want to package all my templates together in a dedicated plugin and later on, maybe that I have to change some stuff within these templates. I want to do it non-invasively similar to Xpand's (oAW) aspect-oriented AROUND blocks.
Is there a way (planned) to do so also with Epsilon?
Cheers
Stefan
Re: Add templates non-invasively [message #642512 is a reply to message #642485] Wed, 01 December 2010 11:04 Go to previous messageGo to next message
Hi Stefan,
Thanks for your interest. I'm afraid that there's nothing like Xpand's AROUND construct in EGL right now.
It might be possible to achieve something similar (albeit with more manual work) using user-defined operations.
Hope that helps a little...
Louis.
Re: Add templates non-invasively [message #642596 is a reply to message #642512] Wed, 01 December 2010 17:27 Go to previous messageGo to next message
Hey Louis,
thanks for the fast response!!! I will have a look on user-defined operations and maybe that I come back to that thread if I have further questions.
Thanks again!
Cheers
Stefan
Re: Add templates non-invasively [message #642641 is a reply to message #642485] Thu, 02 December 2010 02:05 Go to previous message
Hi Stefan,
You may want to have a look at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=325987 This has code that
will eventually be integrated into Epsilon EGL to allow for
aspect-oriented code generation, although in a slightly different manner
from how XPand does it. There is a paper on this new approach as well,
however unfortunately it has not yet been published. If you are
interested, send me an email and I can let you have the PDF.
Steffen
On 01/12/2010 14:36, Stefan wrote:
> Hello,
> Cheers
> Stefan
Previous Topic:[Eugenia] internal error when using "synchronize GMF gen model" more than once
Next Topic:[EuGenia] Standalone RCP application
Current Time: Fri Jul 25 11:05:34 EDT 2025
Powered by FUDForum. Page generated in 0.25133 seconds
