Home » Eclipse Projects » Nebula » [CompositeTable] - Resize of column causes scrollbar to appear in Header
[CompositeTable] - Resize of column causes scrollbar to appear in Header [message #599940] Sat, 10 July 2010 22:36 Go to next message
Hi All,
I have recently started working with the awesome CompositeTable.
In linux, I am seeing the following behavior (using e.g.
CompositeTableSnippet5)
When I resize columns, there is a scrollbar that appears inside the
header row. This is happening in Linux only (*not* on Win7)
Can anyone pl let me know how this can be fixed?
Here are the *before* and *after* screenshots of this behavior
http://imgur.com/3jdGl.png
http://imgur.com/mfrUN.png
Re: [CompositeTable] - Resize of column causes scrollbar to appear in Header [message #642554 is a reply to message #599940] Wed, 01 December 2010 13:51 Go to previous messageGo to next message
Did you found anything to overcome this problem ?
I got the exact same thing on MacOS X / Cocoa.
Thank you,
Christophe
http://www.nextep-softwares.com
Re: [CompositeTable] - Resize of column causes scrollbar to appear in Header [message #642561 is a reply to message #642554] Wed, 01 December 2010 14:08 Go to previous messageGo to next message
Actually the problem is easy to fix. I checked out the composite table project from CVS.
In the file AbstractNativeHeader, you have to replace line 61 from :
headerTable = new Table(this, SWT.NULL);
to :
headerTable = new Table(this, SWT.NO_SCROLL);
And you will not see the scroll bar any more.
This would be great if someone could commit this fix. Until then, since this class has no internal dependency with compositetable you can simply copy the class in your own code, including this fix. I think this is simpler than recompiling the plugin...
Hope this helps,
Christophe
Re: [CompositeTable] - Resize of column causes scrollbar to appear in Header [message #642605 is a reply to message #642561] Wed, 01 December 2010 17:28 Go to previous messageGo to next message
Could you please file a bug and cc me on it
Tom
Am 01.12.10 20:08, schrieb Christophe Fondacci:
> project from CVS.
> to :
> Hope this helps,
> Christophe
Re: [CompositeTable] - Resize of column causes scrollbar to appear in Header [message #642732 is a reply to message #642605] Thu, 02 December 2010 09:32 Go to previous message
Done : https://bugs.eclipse.org/bugs/show_bug.cgi?id=331673
Thanks!
Previous Topic:download site not working
Next Topic:CalendarCombo fix / support
Current Time: Thu Nov 06 23:39:12 EST 2025
Powered by FUDForum. Page generated in 0.04417 seconds
