Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Using a ScrolledComposite with Nebula Grid
Using a ScrolledComposite with Nebula Grid [message #642358] Tue, 30 November 2010 19:38 Go to next message
I have a WizardPage that needs to display table of checkboxes. I was able to create the table easily using the Nebula Grid widget. The grid will vary in size depending on what the user selects earlier in the wizard flow. This results in the possibility that grid will have more columns than the wizard has space for. I thought the way to solve this is to use a ScrolledComposite. However, no matter what I try, nothing seems to work.
Essentially, I think I need to do something like this to set up the Grid in a ScrolledComposite:
		ScrolledComposite scComposite = new ScrolledComposite( parent, SWT.H_SCROLL | SWT.V_SCROLL ) ;
		Composite childComposite = new Composite( scComposite, SWT.NONE ) ;
		childComposite.setLayout( new FillLayout() ) ;
		Grid grid = new Grid( childComposite, SWT.NONE ) ;
Then later, when I am done adding GridColumn and GridItem to the Grid, I can do this:
		childComposite.setSize( 400, 200 ) ;
		scComposite.setContent( childComposite ) ;
or I could do something like this:
               scComposite.setMinSize( 400, 200 ) ;
               scComposite.SetExpandHorizontal( true ) ;
               scComposite.setExpandVertical( true ) ;
The thing is that neither of these seem to work. No matter what I've tried, I don't get scrollbars when the grid size exceeds the wizard window.
I thought that maybe it was something with JFace/RCP, so I created a standalong SWT app that exhibits the same behavior - and the one thing all these have in common is me.
So am I doing something wrong? This seems to be how the examples in the snippets work as well as an SWT/JFace book I have. Clearly I am doing something wrong, I just don't see what it is.
One more item: I am on a Mac but the same issue is present when I run this code on windows. I am using Eclipse 3.5.2 as my target platform for the RCP app.
Thanks in advance for any pointers or suggestions.
Jon
Re: Using a ScrolledComposite with Nebula Grid [message #642379 is a reply to message #642358] Wed, 01 December 2010 01:38 Go to previous messageGo to next message
The grid will show scrollbars itself if the content the content is
overlowing the available size.
Probably you need to pass SWT.H_SCROLL and SWT.V_SCROLL.
Tom
Am 01.12.10 01:38, schrieb Jon Svede:
> seems to work.
> can do this:
> for the RCP app.
> Jon
Re: Using a ScrolledComposite with Nebula Grid [message #642517 is a reply to message #642379] Wed, 01 December 2010 11:19 Go to previous message
Thanks, Tom. I don't know why I didn't remember that. It's working now.
Jon
Previous Topic:RCP product crashes on Mac OS X 10.5.8 with JVM HotSpot 1.6.0_22 64 Bit
Next Topic:Increasing the size of a drop down of a combo
Current Time: Fri Jul 18 21:05:57 EDT 2025
Powered by FUDForum. Page generated in 0.04181 seconds
