Home » Archived » M2M (model-to-model transformation) » [ATL] Question about Called and Unique Lazy Rules
[ATL] Question about Called and Unique Lazy Rules [message #642431] Wed, 01 December 2010 05:17 Go to next message
Hi all,
I have a question about called and lazy rules. I'm not totally clear
what the "return value" of a called or lazy rule is. Let's take the
example from the User Guide:
lazy rule getCross {
from
i: ecore!EObject
to
rel: metamodel!Relationship (
And here its invocation:
rule Example {
from
s : ecore!EObject
to
t : metamodel!Node (
name <- s.toString(),
edges <- thisModule.getCross(s) -- ***
What does the marked line mean exactly? I mean, speaking of the name of
the edges reference, I consider it to be a set, but getCross() seems to
return just one element. Is that automatically converted to a set? I
had expect something like
edges <- Set{ thisModule.getCross(s) }
Especially since the next example uses collect() to produce a set:
edges <- ecore!EClass.allInstancesFrom('yourmodel')->
collect(e | thisModule.getCross(e))
And my other question is: What's the return value of called/lazy rules
if they have multiple target pattern elements? Only the first, or an
OrderedSet containing all of them? And do lazy rules allow for multiple
target pattern elements at all?
Thanks in advance,
Tassilo
Dipl.-Inform. Tassilo Horn | Room: B015
University of Koblenz-Landau, Campus Koblenz | Phone: +49 (261) 287-2745
Institute for Software Technology | Mail: horn@uni-koblenz.de
Universitätsstr. 1, 56070 Koblenz, Germany |
Re: [ATL] Question about Called and Unique Lazy Rules [message #642433 is a reply to message #642431] Wed, 01 December 2010 05:31 Go to previous messageGo to next message
In a collection, you can bind either a single element or a list, both will work.
Lazy rules allow to build multiple elements but be careful that only the first will be returned.
If you need to catch more than one element, you should use a called rule instead of a lazy rule because in a called rule you explicitly specify the returned elements ex :
rule getCross(i: ecore!EObject) {
to
rel2 : metamodel!Relationship(
do{
-- here you specifiy the element(s) returned by the called rule
Sequence{rel,rel2};
Re: [ATL] Question about Called and Unique Lazy Rules [message #642443 is a reply to message #642433] Wed, 01 December 2010 06:13 Go to previous messageGo to next message
Sylvain EVEILLARD <s.eveillard@netfective.com> writes:
Hi Sylvain,
> will work.
Ah, nice. In the former case, is a collection created only when needed
(not already initialized)? To make the question clearer, consider that
example:
to foo : MM!Thing
do {
foo.refs <- thisModule.getSomeRefs(foo);
foo.refs <- thisModule.getOneRef(foo);
Does the second assignment insert the returned element into the refs
collection, or does a newly created collection with only the single
element replace the original value of the first assignment?
Thanks.
> to
> do{
> Sequence{rel,rel2};
Ah, that's kinda nice. But the User Guide states that inside the
imperative code section only a sequence of statements is allowed. So is
the principle that a called rule rule usually returns the value of the
first target pattern variable, unless the imperative code section's last
statement is an expression. In that case, the value of the expression
is returned.
Bye,
Tassilo
Re: [ATL] Question about Called and Unique Lazy Rules [message #642461 is a reply to message #642431] Wed, 01 December 2010 08:04 Go to previous messageGo to next message
to foo : MM!Thing
do {
No, the element is added at the end of the collection so in the end the collection refs will contain the result of the getSomeRefs followed by the result of the getOneRef.
is returned.
In a called rule you ALWAYS have to specify what the rule returns even if it's only one element (unless it changed in the last ATL version).
Re: [ATL] Question about Called and Unique Lazy Rules [message #642478 is a reply to message #642461] Wed, 01 December 2010 08:45 Go to previous messageGo to next message
Hi Sylvain,
> Quote:
>> to foo : MM!Thing
>> do {
Oh, that's great.
> Quote:
>> is returned.
At least the current user guide at
http://wiki.eclipse.org/ATL/User_Guide_-_The_ATL_Language#Ca lled_Rules
says that in called rules, both "to" and "do" are optional. But indeed
you are right, and the docs are false. I've just tested it.
Thanks a lot!
Bye,
Tassilo
Re: [ATL] Question about Called and Unique Lazy Rules [message #642537 is a reply to message #642431] Wed, 01 December 2010 12:37 Go to previous messageGo to next message
Hi Tassilo,
If you use a given called rule in an expression, then it must return a value, and this value must be returned from the do block, which is non-optional *in this specific case*.
However, called rule do not need to return values: they may be called as statements from other do blocks. Therefore, the do block is indeed optional.
Frédéric
Re: [ATL] Question about Called and Unique Lazy Rules [message #642678 is a reply to message #642537] Thu, 02 December 2010 05:06 Go to previous message
Frédéric Jouault <frederic.jouault@univ-nantes.fr> writes:
Hi Frédéric,
> optional.
Ah, that makes it clear to me.
Thanks a lot!
Tassilo
Previous Topic:[ATL] Refining Mode : Cannot create
Next Topic:[ATL] Do we have to instantiate ProfileApplication when transforming an extended model into another?
Current Time: Sat Jul 26 10:12:16 EDT 2025
Powered by FUDForum. Page generated in 0.04432 seconds
