Home » Eclipse Projects » Eclipse Platform » Frequent crashes in Galileo 3.5.2 / JDK 6 Update 21(Constant Unhandled Event Loop)
Frequent crashes in Galileo 3.5.2 / JDK 6 Update 21 [message #642359] Tue, 30 November 2010 19:41 Go to next message
I get frequent crashes in Eclipse 3.5.2 / JDK 6 Update 21. The log file rapidly fills up with unhandled event loop exceptions. A typical stack trace looks like:
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.OutOfMemoryError: PermGen space)
at org.eclipse.swt.SWT.error(SWT.java:3884)
at org.eclipse.swt.SWT.error(SWT.java:3799)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:137)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3885)
in eclipse.ini I've experimenting setting the MaxPermSize higher - it was at 256M and I boosted it to 384M with no effect.
I'm running XP Pro, SP3. I have no shortage of memory on my system and I run lots of other big, complex apps such as Visual Studio and Adobe Creative Suite with no unusual behavior.
This is ruining my productivity!! Thanks in advance for any help!
Re: Frequent crashes in Galileo 3.5.2 / JDK 6 Update 21 [message #642365 is a reply to message #642359] Tue, 30 November 2010 21:24 Go to previous messageGo to next message
Can you move up to update 22 (the most recent)? I think there have been fixes in the interaction with Java and Eclipse that that make the permgen problems go away.
Re: Frequent crashes in Galileo 3.5.2 / JDK 6 Update 21 [message #642386 is a reply to message #642365] Wed, 01 December 2010 02:33 Go to previous messageGo to next message
Alternatively (or additionally) you might consider to switch to Eclipse
3.6.x. Here, the Eclipse implementation has changed their VM recognition
logic.
HTH & Greetings from Bremen,
Daniel Krügler
Re: Frequent crashes in Galileo 3.5.2 / JDK 6 Update 21 [message #642470 is a reply to message #642386] Wed, 01 December 2010 08:35 Go to previous messageGo to next message
Daniel Krügler wrote on Wed, 01 December 2010 02:33
logic.
Our entire group (about 15 engineers and designers) would have to switch if we changed versions of Eclipse or Java.
Is there any fix that doesn't involve changing versions of Eclipse or Java?
If we did change am I correct in assuming that updating Java would be the least disruptive of the 2 choices? Does it have a high likelihood of fixing the problem (Francis said he "thinks" it might fix it)?
Re: Frequent crashes in Galileo 3.5.2 / JDK 6 Update 21 [message #642472 is a reply to message #642470] Wed, 01 December 2010 08:38 Go to previous messageGo to next message
>> Eclipse 3.6.x. Here, the Eclipse implementation has changed their VM
>> recognition logic.
I don't know.
I assume so.
I'm quite sure that it will fix the problem.
Daniel Krügler
Re: Frequent crashes in Galileo 3.5.2 / JDK 6 Update 21 [message #642481 is a reply to message #642359] Wed, 01 December 2010 09:06 Go to previous messageGo to next message
> trace looks like:
> onizer.java:137)
Maybe you've come across bug #319514.
You have to re-download and re-install JRE 1.6.0_21 or switch to 1.6.0_22.
Otherwise have a look at:
http://lt-rider.blogspot.com/2010/07/oracle-jvm-6u21-and-ecl ipse.html
Mauro.
Re: Frequent crashes in Galileo 3.5.2 / JDK 6 Update 21 [message #642545 is a reply to message #642470] Wed, 01 December 2010 13:05 Go to previous messageGo to next message
>> recognition logic.
Read this: http://www.eclipse.org/forums/index.php?t=msg&th=171988& amp;start=0
Eric
Re: Frequent crashes in Galileo 3.5.2 / JDK 6 Update 21 [message #642560 is a reply to message #642545] Wed, 01 December 2010 13:07 Go to previous messageGo to next message
>>> been
>>> recognition logic.
>> Java?
Better reference: http://wiki.eclipse.org/FAQ_How_do_I_run_Eclipse%3F
Re: Frequent crashes in Galileo 3.5.2 / JDK 6 Update 21 [message #642734 is a reply to message #642560] Thu, 02 December 2010 09:37 Go to previous messageGo to next message
Eric Rizzo wrote on Wed, 01 December 2010
Better reference: [url
http://wiki.eclipse.org/FAQ_How_do_I_run_Eclipse%3F[/url]
That is about 3.32, I'm running 3.52.
In any case I volunteered myself to be my group's guinea pig for update 22 and so far it seems to be working OK so I think that will be the preferred solution. Thanks to everyone who contributed!
Re: Frequent crashes in Galileo 3.5.2 / JDK 6 Update 21 [message #642760 is a reply to message #642734] Thu, 02 December 2010 10:29 Go to previous message
On 12/2/10 9:37 AM, peter nelson wrote:
> Eric Rizzo wrote on Wed, 01 December 2010 Better reference: [url
I've updated that wiki page to eliminate the references to 3.3, as most
of the material applies to all versions.
In particular, the very first section was what I was pointing you to
( http://wiki.eclipse.org/FAQ_How_do_I_run_Eclipse%3F#Oracle.2 FSun_VM_1.6.0_21_on_Windows);
that part contains info about several options for resolving the problem
you were experiencing.
Eric
Previous Topic:[DataBinding]TreeViewer ComboBoxViewerCellEditor validation
Next Topic:SIngle running instance of Eclipse
Current Time: Sun Jul 27 09:10:08 EDT 2025
Powered by FUDForum. Page generated in 0.04318 seconds
