Home » Eclipse Projects » JFace » Why the label provider isn't triggered as soon as the refresh method is called?
Why the label provider isn't triggered as soon as the refresh method is called? [message #642415] Wed, 01 December 2010 04:14 Go to next message
Hi All,
I have a treeviewer representing my domain models.
After I add a new element to the parent, the parent label should be refreshed based on our logic. So I call viewer.refresh() at the end of my adding element action. What is strange is that the content provider is called immediately, but the label provider isn't triggered after 20-30 seconds later, then the parent's label is refreshed. This strange thing will happen only once. After that, the parent label will be refreshed as soon as I create any new sub element.
My question is that why the label provider isn't triggered like the content provider? Does any body meet such situation before?
Any suggestions are all welcome.
Li
[Updated on: Wed, 01 December 2010 04:17] by Moderator
Re: Why the label provider isn't triggered as soon as the refresh method is called? [message #642417 is a reply to message #642415] Wed, 01 December 2010 04:24 Go to previous messageGo to next message
Why do you call refresh a much better method is to use TreeViewer#add().
When you call refresh you simply recreate the whole content of the
viewer which is killing performance.
Tom
Am 01.12.10 10:14, schrieb Li Junhong:
> Hi All,
> my adding element action. What strange is that the content provider is
> will happen once. After that, the parent label will be refreshed as soon
> Li
Re: Why the label provider isn't triggered as soon as the refresh method is called? [message #642418 is a reply to message #642415] Wed, 01 December 2010 04:25 Go to previous message
On 12/1/2010 10:14, Li Junhong wrote:
> Hi All,
> seconds later,
I hope this is a typo. You don't meant *seconds*, but milli seconds,
don't you?
Not such extreme delays. The delay of the label provider is expected,
though: The viewer has to ensure that further class invariants are hold,
e.g. the previous selection is attempted to be restored.
HTH & Greetings from Bremen,
Daniel Krügler
Previous Topic:Resizing dialog question
Next Topic:Help! an issue after removed the filter
Current Time: Sat Jul 26 01:51:48 EDT 2025
Powered by FUDForum. Page generated in 0.03749 seconds
