| IWAB0014E error when trying to create WebService in Helios [message #642271] |
Tue, 30 November 2010 11:22  |
I'm trying to create a WebService in Helios (I've done it previously in Galileo), but the IWAB0014E exception error occurs.
Facets installed on project :
* CXF 2.x Web Services 1.0
* Dynamic Web Module 2.5
* Java 1.6
* Javascript 1.0
OS : Win7 x64
Eclipse : Helios x64
JDK : 1.6.0_20 x64
Installed CXF runtime : 2.3.0
Installed Tomcat runtime : tomcat 6.0.29 x64
I tried on an another PC, and it's works but it's not my working one.
Is there something to do to make it work ?
Thanks.
IWAB0014E Unexpected exception occurred.
0
java.lang.ArrayIndexOutOfBoundsException: 0
at org.eclipse.jst.ws.internal.consumption.ui.wsrt.WebServiceRu ntimeExtensionUtils2.getDefaultRuntimeValueFor(WebServiceRun timeExtensionUtils2.java:835)
at org.eclipse.jst.ws.internal.creation.ui.widgets.ServerWizard WidgetDefaultingCommand.execute(ServerWizardWidgetDefaulting Command.java:49)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.runCommand(CommandFragmentEngine.java:419)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.visitTop(CommandFragmentEngine.java:359)
at org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.moveForwardToNextStop(CommandFragmentEngine.jav a:254)
at org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager$6.run(SimpleCommandEngineManager.java:294)
at org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager.runForwardToNextStop(SimpleCommandEngineManag er.java:258)
at org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.runForwardToNextStop(WizardPageManager.java:91)
at org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.getNextPage(WizardPageManager.java:154)
at org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.getStartingPage(WizardPageManager.java:80)
at org.eclipse.wst.command.internal.env.ui.widgets.DynamicWizar d.getStartingPage(DynamicWizard.java:364)
at org.eclipse.jface.wizard.WizardDialog.showStartingPage(Wizar dDialog.java:1251)
at org.eclipse.jface.wizard.WizardDialog.createContents(WizardD ialog.java:608)
at org.eclipse.jface.window.Window.create(Window.java:431)
at org.eclipse.jface.dialogs.Dialog.create(Dialog.java:1089)
at org.eclipse.wst.command.internal.env.ui.widgets.popup.Dynami cPopupWizard.run(DynamicPopupWizard.java:126)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 38)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:664)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:115)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
FUDForum. Page generated in 0.03379 seconds
