Home » Archived » BIRT » Scripted dataset problem
Scripted dataset problem [message #641969] |
Mon, 29 November 2010 07:23  |
I have a report which uses both a JDBC Dataset and a Scripted Dataset. When I preview the report within the Report Design perspective, the report works fine. However, when I run my application and attempt to view the report using the Report Viewer, I'm receiving the error below.
[11/24/10 11:07:33:827 EST] 00000035 QueryResultSe E Cannot fetch the next data row.
Cannot move down to next row in the result set.
SQL error #1: [jcc][t4][10120][10898][3.52.95] Invalid operation: result set is closed. ERRORCODE=-4470, SQLSTATE=null
org.eclipse.birt.data.engine.core.DataException: Cannot fetch the next data row.
I've narrowed the problem down to the Scripted Dataset. If I remove it and its corresponding table, the report runs without an error. (Of course in this case, I'm also missing necessary data.) If I leave the Scripted DataSet in the report but don't bind any of its data to a table, I get errors on the console; however, the report still runs. With the Scripted Dataset and a table on the report using data from the Scripted Dataset, the report doesn't run...all I get is the error on the console shown above.
I'm using BIRT 2.3.
Any help would be greatly appreciated.
Don
Re: Scripted dataset problem [message #642028 is a reply to message #641969] |
Mon, 29 November 2010 10:31   |
Don,
Can you post the report?
Jason
> next data row.
> data row.
> I'm using BIRT 2.3.
> Don
Re: Scripted dataset problem [message #642761 is a reply to message #642728] |
Thu, 02 December 2010 10:51   |
Don,
Load the attached example and try to run it. It is similar to your
example and it worked on my install.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.17"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.3.2.r232_20090202 Build <2.3.2.v20090218-0730></property>
<property name="units">in</property>
<method
name="beforeFactory"><![CDATA[importPackage(Packages.java.util.*);
globalvarList = new java.util.ArrayList();
prgCount = 0;]]></method>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<data-sources>
<oda-data-source
extensionID="org.eclipse.birt.report.data.oda.jdbc" name="Data Source"
id="7">
<text-property name="displayName"></text-property>
<property
name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
<property name="odaURL">jdbc:classicmodels:sampledb</property>
<property name="odaUser">ClassicModels</property>
<property name="OdaConnProfileName"></property>
</oda-data-source>
<script-data-source name="Scripted" id="8"/>
</data-sources>
<data-sets>
<oda-data-set
extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet "
name="Data Set" id="9">
<list-property name="columnHints">
<structure>
<property name="columnName">ORDERNUMBER</property>
<property name="displayName">ORDERNUMBER</property>
</structure>
<structure>
<property name="columnName">PRODUCTCODE</property>
<property name="displayName">PRODUCTCODE</property>
</structure>
<structure>
<property name="columnName">QUANTITYORDERED</property>
<property name="displayName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="columnName">PRICEEACH</property>
<property name="displayName">PRICEEACH</property>
</structure>
<structure>
<property name="columnName">ORDERLINENUMBER</property>
<property name="displayName">ORDERLINENUMBER</property>
</structure>
</list-property>
<structure name="cachedMetaData">
<list-property name="resultSet">
<structure>
<property name="position">1</property>
<property name="name">ORDERNUMBER</property>
<property name="dataType">integer</property>
</structure>
<structure>
<property name="position">2</property>
<property name="name">PRODUCTCODE</property>
<property name="dataType">string</property>
</structure>
<structure>
<property name="position">3</property>
<property name="name">QUANTITYORDERED</property>
</structure>
<structure>
<property name="position">4</property>
<property name="name">PRICEEACH</property>
<property name="dataType">float</property>
</structure>
<structure>
<property name="position">5</property>
<property name="name">ORDERLINENUMBER</property>
</structure>
</list-property>
</structure>
<property name="dataSource">Data Source</property>
<structure>
<property name="nativeName">ORDERNUMBER</property>
<property name="nativeDataType">4</property>
</structure>
<structure>
<property name="nativeName">PRODUCTCODE</property>
<property name="nativeDataType">12</property>
</structure>
<structure>
<property name="nativeName">QUANTITYORDERED</property>
</structure>
<structure>
<property name="nativeName">PRICEEACH</property>
<property name="nativeDataType">8</property>
</structure>
<structure>
<property name="nativeName">ORDERLINENUMBER</property>
<property name="nativeDataType">5</property>
</structure>
</list-property>
<property name="queryText">select *
from orderdetails
where ordernumber = 10101</property>
<xml-property name="designerValues"><![CDATA[<?xml
version="1.0" encoding="UTF-8"?>
<model:DesignValues
xmlns:design="http://www.eclipse.org/datatools/connectivity/oda/design"
xmlns:model="http://www.eclipse.org/birt/report/model/adapter/odaModel">
<Version>1.0</Version>
<design:ResultSets derivedMetaData="true">
<design:resultSetDefinitions>
<design:resultSetColumns>
<design:resultColumnDefinitions>
<design:attributes>
<design:name>ORDERNUMBER</design:name>
<design:position>1</design:position>
<design:nativeDataTypeCode>4</design:nativeDataTypeCode>
<design:precision>10</design:precision>
<design:scale>0</design:scale>
<design:nullability>Nullable</design:nullability>
<design:uiHints>
<design:displayName>ORDERNUMBER</design:displayName>
</design:uiHints>
</design:attributes>
<design:usageHints>
<design:label>ORDERNUMBER</design:label>
<design:formattingHints>
<design:displaySize>11</design:displaySize>
</design:formattingHints>
</design:usageHints>
</design:resultColumnDefinitions>
<design:attributes>
<design:name>PRODUCTCODE</design:name>
<design:position>2</design:position>
<design:nativeDataTypeCode>12</design:nativeDataTypeCode>
<design:precision>15</design:precision>
<design:uiHints>
<design:displayName>PRODUCTCODE</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRODUCTCODE</design:label>
<design:displaySize>15</design:displaySize>
<design:attributes>
<design:name>QUANTITYORDERED</design:name>
<design:position>3</design:position>
<design:uiHints>
<design:displayName>QUANTITYORDERED</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>QUANTITYORDERED</design:label>
<design:attributes>
<design:name>PRICEEACH</design:name>
<design:position>4</design:position>
<design:nativeDataTypeCode>8</design:nativeDataTypeCode>
<design:uiHints>
<design:displayName>PRICEEACH</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>PRICEEACH</design:label>
<design:displaySize>22</design:displaySize>
<design:attributes>
<design:name>ORDERLINENUMBER</design:name>
<design:position>5</design:position>
<design:nativeDataTypeCode>5</design:nativeDataTypeCode>
<design:precision>5</design:precision>
<design:uiHints>
<design:displayName>ORDERLINENUMBER</design:displayName>
</design:uiHints>
<design:usageHints>
<design:label>ORDERLINENUMBER</design:label>
<design:displaySize>6</design:displaySize>
</design:resultSetColumns>
</design:resultSetDefinitions>
</design:ResultSets>
</model:DesignValues>
]]></xml-property>
</oda-data-set>
<script-data-set name="ScriptedDataSet" id="44">
<list-property name="resultSetHints">
<structure>
<property name="position">0</property>
<property name="name">ON</property>
</structure>
<structure>
<property name="name">PC</property>
</structure>
<structure>
<property name="name">QO</property>
</structure>
</list-property>
<structure>
<property name="columnName">ON</property>
</structure>
<structure>
<property name="columnName">PC</property>
</structure>
<structure>
<property name="columnName">QO</property>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<property name="dataSource">Scripted</property>
<method name="fetch"><![CDATA[if(prgCount <
globalvarList.size())
var data = globalvarList.get(prgCount);
row["ON"] = data[0];
row["PC"] =data[1];
row["QO"] = data[2];
prgCount++;
return true;
else
return false;
}]]></method>
</script-data-set>
</data-sets>
<styles>
<style name="report" id="4">
<property name="fontFamily">"Verdana"</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<property name="topMargin">0.25in</property>
<property name="leftMargin">0.25in</property>
<property name="bottomMargin">0.25in</property>
<property name="rightMargin">0.25in</property>
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<table id="10">
<property name="width">100%</property>
<property name="dataSet">Data Set</property>
<list-property name="boundDataColumns">
<structure>
<expression
name="expression">dataSetRow["ORDERNUMBER"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["PRODUCTCODE"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["QUANTITYORDERED"]</expression >
</structure>
<structure>
<expression
name="expression">dataSetRow["PRICEEACH"]</expression>
</structure>
<structure>
<expression
name="expression">dataSetRow["ORDERLINENUMBER"]</expression >
</structure>
</list-property>
<column id="39"/>
<column id="40"/>
<column id="41"/>
<column id="42"/>
<column id="43"/>
<header>
<row id="11">
<cell id="12">
<label id="13">
<text-property
name="text">ORDERNUMBER</text-property>
</label>
</cell>
<cell id="14">
<label id="15">
<text-property
name="text">PRODUCTCODE</text-property>
</label>
</cell>
<cell id="16">
<label id="17">
<text-property
name="text">QUANTITYORDERED</text-property>
</label>
</cell>
<cell id="18">
<label id="19">
<text-property
name="text">PRICEEACH</text-property>
</label>
</cell>
<cell id="20">
<label id="21">
<text-property
name="text">ORDERLINENUMBER</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="22">
<method name="onCreate"><![CDATA[var data={};
data[0] = this.getRowData().getColumnValue("ORDERNUMBER");
data[1] = this.getRowData().getColumnValue("PRODUCTCODE");
data[2] = this.getRowData().getColumnValue("QUANTITYORDERED");
globalvarList.add(data);]]></method>
<cell id="23">
<data id="24">
<property
name="resultSetColumn">ORDERNUMBER</property>
</data>
</cell>
<cell id="25">
<data id="26">
<property
name="resultSetColumn">PRODUCTCODE</property>
</data>
</cell>
<cell id="27">
<data id="28">
<property
name="resultSetColumn">QUANTITYORDERED</property>
</data>
</cell>
<cell id="29">
<data id="30">
<property
name="resultSetColumn">PRICEEACH</property>
</data>
</cell>
<cell id="31">
<data id="32">
<property
name="resultSetColumn">ORDERLINENUMBER</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="33">
<cell id="34"/>
<cell id="35"/>
<cell id="36"/>
<cell id="37"/>
<cell id="38"/>
</row>
</footer>
</table>
<table id="45">
<property name="dataSet">ScriptedDataSet</property>
<structure>
<property name="displayName">ON</property>
<expression
name="expression">dataSetRow["ON"]</expression>
</structure>
<structure>
<property name="displayName">PC</property>
<expression
name="expression">dataSetRow["PC"]</expression>
</structure>
<structure>
<property name="displayName">QO</property>
<expression
name="expression">dataSetRow["QO"]</expression>
</structure>
</list-property>
<column id="64"/>
<column id="65"/>
<column id="66"/>
<header>
<row id="46">
<cell id="47">
<label id="48">
<text-property name="text">ON</text-property>
</label>
</cell>
<cell id="49">
<label id="50">
<text-property name="text">PC</text-property>
</label>
</cell>
<cell id="51">
<label id="52">
<text-property name="text">QO</text-property>
</label>
</cell>
</row>
</header>
<detail>
<row id="53">
<cell id="54">
<data id="55">
<property name="resultSetColumn">ON</property>
</data>
</cell>
<cell id="56">
<data id="57">
<property name="resultSetColumn">PC</property>
</data>
</cell>
<cell id="58">
<data id="59">
<property name="resultSetColumn">QO</property>
</data>
</cell>
</row>
</detail>
<footer>
<row id="60">
<cell id="61"/>
<cell id="62"/>
<cell id="63"/>
</row>
</footer>
</table>
</body>
</report>
On 12/2/2010 9:23 AM, Don wrote:
> Jason,
> I moved the code from the onCreate of the table to the onCreate of the
> table row. Unfortunately, I received the same errors.
> I also added the code to print to a text file on my c drive. This was
> populated when I ran the report so it is creating the table which is
> bound to the database-related dataset. Apparently it's failing when
> attempting to create either the scripted dataset or the table to which
> its bound.
> Does this error occur in the BIRT 2.6 viewer?
> It appears that our only alternative at this point (at least for this
> particular report) is to instantiate the engine in our app, run it, and
> embed the output in our jsp page. Would you agree?
> Here's the xml for the changes I made.
> id="1">
> <method name="beforeFactory"><![CDATA[importPackage(Packages.java.util.*);
> <data-sources>
> <oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc"
> name="MPMSDB" id="7">
> <property name="odaDriverClass">com.ibm.db2.jcc.DB2Driver</property >
> <property name="odaURL">jdbc:db2://pddevgwdsnd2k01:50000/DSN</property>
> <property name="odaUser">mpmspgm</property>
> <encrypted-property name="odaPassword"
> encryptionID="base64">bXBtczAx</encrypted-property>
> <property name="odaJndiName">jdbc/MPMS</property>
> </oda-data-source>
> <script-data-source name="scriptedDataSource" id="31"/>
> </data-sources>
> <data-sets>
> <oda-data-set
> name="db2DataSet" id="8">
> <structure>
> <property name="columnName">PRG_ID</property>
> <property name="displayName">PRG_ID</property>
> </structure>
> <structure>
> <property name="columnName">PRG_STS_CD</property>
> <property name="displayName">PRG_STS_CD</property>
> </structure>
> <structure>
> <property name="columnName">PRG_TYPE_CD</property>
> <property name="displayName">PRG_TYPE_CD</property>
> </structure>
> </list-property>
> <structure>
> <property name="name">PRG_ID</property>
> </structure>
> <structure>
> <property name="name">PRG_STS_CD</property>
> </structure>
> <structure>
> <property name="name">PRG_TYPE_CD</property>
> </structure>
> </list-property>
> </structure>
> <property name="dataSource">MPMSDB</property>
> <structure>
> <property name="nativeName">PRG_ID</property>
> </structure>
> <structure>
> <property name="nativeName">PRG_STS_CD</property>
> </structure>
> <structure>
> <property name="nativeName">PRG_TYPE_CD</property>
> </structure>
> </list-property>
> <property name="queryText">select prg_id, prg_sts_cd, prg_type_cd
> from mpmsprod.t001program
> where prg_id > 300
> order by prg_type_cd, prg_id</property>
> </oda-data-set>
> <script-data-set name="scriptedDataSet" id="32">
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> <property name="name">programCount</property>
> </structure>
> </list-property>
> <structure>
> <property name="displayName">Program ID</property>
> </structure>
> <structure>
> <property name="displayName">Program Type</property>
> </structure>
> <structure>
> <property name="displayName">Program Status</property>
> </structure>
> <structure>
> <property name="columnName">programCount</property>
> <property name="displayName"># of Rows</property>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <property name="dataSource">scriptedDataSource</property>
> <method name="fetch"><![CDATA[if(prgCount < globalvarList.size())
> var prgId = data.prg_id;
> if (prgId > 400)
> { row["PRG_ID"] = data.prg_id;
> else
> row["PRG_ID"] = 2;
> row["PRG_TYPE_CD"] = data.prg_type_cd;
> row["PRG_STS_CD"] =data.prg_sts_cd;
> row["programCount"] = globalvarList.size();
> prgCount++;
> return true;
> else
> return false;
> ]]></method>
> </script-data-set>
> </data-sets>
> <styles>
> </style>
> <style name="crosstab" id="5">
> </style>
> <style name="crosstab-cell" id="6">
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> <text-property name="content"><![CDATA[<value-of>new
> </text>
> </page-footer>
> </page-setup>
> <body>
> <table id="9">
> <property name="dataSet">db2DataSet</property>
> <list-property name="visibility">
> <structure>
> <property name="format">all</property>
> <expression name="valueExpr">true</expression>
> </structure>
> </list-property>
> <structure>
> <expression name="expression">dataSetRow["PRG_ID"]</expression>
> </structure>
> <structure>
> <expression name="expression">dataSetRow["PRG_STS_CD"]</expression>
> </structure>
> <structure>
> <expression name="expression">dataSetRow["PRG_TYPE_CD"]</expression >
> </structure>
> </list-property>
> <method name="onCreate"><![CDATA[/*var data={};
> data.prg_id = this.getRowData().getColumnValue("PRG_ID");
> data.prg_type_cd = this.getRowData().getColumnValue("PRG_TYPE_CD");
> data.prg_sts_cd = this.getRowData().getColumnValue("PRG_STS_CD");
> */]]></method>
> <column id="28">
> <property name="textAlign">center</property>
> </column>
> <column id="29">
> </column>
> <column id="30">
> </column>
> <header>
> <row id="10">
> <cell id="11">
> <label id="12">
> <text-property name="text">PRG_ID from db2DataSet</text-property>
> </label>
> </cell>
> <cell id="13">
> <label id="14">
> <text-property name="text">PRG_STS_CD from db2DataSet</text-property>
> </label>
> </cell>
> <cell id="15">
> <label id="16">
> <text-property name="text">PRG_TYPE_CD from db2DataSet</text-property>
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="17">
> data.prg_id = row.PRG_ID;
> data.prg_type_cd = row.PRG_TYPE_CD;
> data.prg_sts_cd = row.PRG_STS_CD;
> importPackage( Packages.java.io );
> out = new PrintWriter( new FileWriter( "c:/birttest/events.txt", true ) );
> out.println( "oncreate event");
> out.close();
> ]]></method>
> <cell id="18">
> <data id="19">
> <property name="resultSetColumn">PRG_ID</property>
> </data>
> </cell>
> <cell id="20">
> <data id="21">
> <property name="resultSetColumn">PRG_STS_CD</property>
> </data>
> </cell>
> <cell id="22">
> <data id="23">
> <property name="resultSetColumn">PRG_TYPE_CD</property>
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="24">
> <cell id="25"/>
> <cell id="26"/>
> <cell id="27"/>
> </row>
> </footer>
> </table>
> <table id="33">
> <property name="dataSet">scriptedDataSet</property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> <expression name="expression">dataSetRow["programCount"]</expression >
> </structure>
> </list-property>
> <column id="52">
> </column>
> <column id="53">
> </column>
> <column id="54">
> </column>
> <column id="58">
> </column>
> <header>
> <row id="34">
> <cell id="35">
> <label id="36">
> <text-property name="text">Program ID</text-property>
> </label>
> </cell>
> <cell id="37">
> <label id="38">
> <text-property name="text">Program Type</text-property>
> </label>
> </cell>
> <cell id="39">
> <label id="40">
> <text-property name="text">Program Status</text-property>
> </label>
> </cell>
> <cell id="55">
> <label id="59">
> <text-property name="text"># of Rows</text-property>
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="41">
> <cell id="42">
> <data id="43">
> </data>
> </cell>
> <cell id="44">
> <data id="45">
> </data>
> </cell>
> <cell id="46">
> <data id="47">
> </data>
> </cell>
> <cell id="56">
> <data id="60">
> <property name="resultSetColumn">programCount</property>
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="48">
> <cell id="49"/>
> <cell id="50"/>
> <cell id="51"/>
> <cell id="57"/>
> </row>
> </footer>
> </table>
> </body>
> </report>
Re: Scripted dataset problem [message #643303 is a reply to message #641969] |
Mon, 06 December 2010 08:11   |
Jason,
I tried what you suggested...I went back to my version of the report and changed the Javascript structure to data[0], data[1], etc instead of data[name1], data[name2], etc. When I ran, I received the same results, i.e., it failed.
I then tried the following.
1. I changed the datasource to the sampledb.
2. I changed the querytext to retrieve data from the order table as in the following:
select ordernumber as prg_id, status as prg_sts_cd, status as prg_type_cd
from orders
order by ordernumber
When I ran this, it worked. So, it does appear the there's something going on with the viewer's ability to handle the combination of DB2 tables and scripted datasets.
Any more thoughts?
Again, many thanks for taking the time to consider this.
-Don
Here's the XML for the report.
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.17" id="1">
<property name="createdBy">Eclipse BIRT Designer Version 2.3.2.r232_20090202 Build <2.3.2.v20090218-0730></property>
<data-sources>
<oda-data-source extensionID="org.eclipse.birt.report.data.oda.jdbc" name="MPMSDB" id="7">
<property name="odaDriverClass">org.eclipse.birt.report.data.oda.sampledb.Driver </property>
</oda-data-source>
</data-sources>
<data-sets>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="db2DataSet" id="8">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<property name="queryText">select ordernumber as prg_id, status as prg_sts_cd, status as prg_type_cd
from orders
order by ordernumber</property>
</oda-data-set>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
if (prgId > 400)
// row["PRG_ID"] = data.prg_id;
row["PRG_ID"] = data[0];
else
// row["PRG_ID"] = 2;
row["PRG_ID"] = 2;
// row["PRG_TYPE_CD"] = data.prg_type_cd;
// row["PRG_STS_CD"] =data.prg_sts_cd;
// row["programCount"] = globalvarList.size();
row["PRG_TYPE_CD"] = data[1];
row["PRG_STS_CD"] =data[2];
prgCount++;
return true;
else
return false;
]]></method>
</script-data-set>
</data-sets>
<styles>
</style>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
<text-property name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</page-setup>
<body>
<table id="9">
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
*/]]></method>
<column id="28">
</column>
<column id="29">
</column>
<column id="30">
</column>
<header>
<row id="10">
<cell id="11">
<label id="12">
</label>
</cell>
<cell id="13">
<label id="14">
</label>
</cell>
<cell id="15">
<label id="16">
</label>
</cell>
</row>
</header>
<detail>
<row id="17">
//data.prg_id = row.PRG_ID;
//data.prg_type_cd = row.PRG_TYPE_CD;
//data.prg_sts_cd = row.PRG_STS_CD;
data[0] = this.getRowData().getColumnValue("PRG_ID");
data[1] = this.getRowData().getColumnValue("PRG_TYPE_CD");
data[2] = this.getRowData().getColumnValue("PRG_STS_CD");
out.close();
]]></method>
<cell id="18">
<data id="19">
</data>
</cell>
<cell id="20">
<data id="21">
</data>
</cell>
<cell id="22">
<data id="23">
</data>
</cell>
</row>
</detail>
<footer>
<row id="24">
<cell id="25"/>
<cell id="26"/>
<cell id="27"/>
</row>
</footer>
</table>
<table id="33">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<column id="52">
</column>
<column id="53">
</column>
<column id="54">
</column>
<column id="58">
</column>
<header>
<row id="34">
<cell id="35">
<label id="36">
</label>
</cell>
<cell id="37">
<label id="38">
</label>
</cell>
<cell id="39">
<label id="40">
</label>
</cell>
<cell id="55">
<label id="59">
</label>
</cell>
</row>
</header>
<detail>
<row id="41">
<cell id="42">
<data id="43">
</data>
</cell>
<cell id="44">
<data id="45">
</data>
</cell>
<cell id="46">
<data id="47">
</data>
</cell>
<cell id="56">
<data id="60">
</data>
</cell>
</row>
</detail>
<footer>
<row id="48">
<cell id="49"/>
<cell id="50"/>
<cell id="51"/>
<cell id="57"/>
</row>
</footer>
</table>
</body>
</report>
Re: Scripted dataset problem [message #643408 is a reply to message #643303] |
Mon, 06 December 2010 13:53   |
This seems odd. Are any of the values coming back as null?
Jason
On 12/6/2010 8:11 AM, Don wrote:
> Jason,
> i.e., it failed.
> the following:
> from orders
> Any more thoughts?
> -Don
> id="1">
> <data-sources>
> <property
> </property>
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> from orders
> </oda-data-set>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> if (prgId > 400)
> { // row["PRG_ID"] = data.prg_id;
> else
> row["PRG_ID"] = 2;
> prgCount++;
> return true;
> else
> return false;
> ]]></method>
> </script-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <table id="9">
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> */]]></method>
> <column id="28">
> </column>
> <column id="29">
> </column>
> <column id="30">
> </column>
> <header>
> <row id="10">
> <cell id="11">
> <label id="12">
> </label>
> </cell>
> <cell id="13">
> <label id="14">
> </label>
> </cell>
> <cell id="15">
> <label id="16">
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="17">
> out.close();
> ]]></method>
> <cell id="18">
> <data id="19">
> </data>
> </cell>
> <cell id="20">
> <data id="21">
> </data>
> </cell>
> <cell id="22">
> <data id="23">
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="24">
> <cell id="25"/>
> <cell id="26"/>
> <cell id="27"/>
> </row>
> </footer>
> </table>
> <table id="33">
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <column id="52">
> </column>
> <column id="53">
> </column>
> <column id="54">
> </column>
> <column id="58">
> </column>
> <header>
> <row id="34">
> <cell id="35">
> <label id="36">
> </label>
> </cell>
> <cell id="37">
> <label id="38">
> </label>
> </cell>
> <cell id="39">
> <label id="40">
> </label>
> </cell>
> <cell id="55">
> <label id="59">
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="41">
> <cell id="42">
> <data id="43">
> </data>
> </cell>
> <cell id="44">
> <data id="45">
> </data>
> </cell>
> <cell id="46">
> <data id="47">
> </data>
> </cell>
> <cell id="56">
> <data id="60">
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="48">
> <cell id="49"/>
> <cell id="50"/>
> <cell id="51"/>
> <cell id="57"/>
> </row>
> </footer>
> </table>
> </body>
> </report>
Re: Scripted dataset problem [message #643950 is a reply to message #641969] |
Wed, 08 December 2010 14:23   |
Jason,
I've changed the report's query to return only one row and still have the same error as seen immediately below.
Below that is the XML for the report.
[12/8/10 14:08:37:012 EST] 0000002c FFDCJanitor I com.ibm.ws.ffdc.impl.FFDCJanitor doCleanupIfNeeded FFDCJANITOR_DELETED_FILES
[12/8/10 14:08:37:200 EST] 0000002c DMAdapter I com.ibm.ws.ffdc.impl.DMAdapter getAnalysisEngine FFDC1009I: Analysis Engine using data base: C:\Program Files\IBM\SDP\runtimes\base_v7\profiles\was70profile2\proper ties\logbr\ffdc\adv\ffdcdb.xml
[12/8/10 14:08:37:262 EST] 0000002c FfdcProvider I com.ibm.ws.ffdc.impl.FfdcProvider logIncident FFDC1003I: FFDC Incident emitted on C:\Program Files\IBM\SDP\runtimes\base_v7\profiles\was70profile2\logs\f fdc\server1_34363436_10.12.08_14.08.37.012508218332435959114 4.txt com.ibm.ws.rsadapter.jdbc.WSJdbcResultSet.next 2624
[12/8/10 14:08:37:356 EST] 0000002c odaconsumer E org.eclipse.birt.data.engine.odaconsumer.ResultSet fetch Cannot fetch the next data row.
org.eclipse.birt.report.data.oda.jdbc.JDBCException: Cannot move down to next row in the result set.
com.ibm.db2.jcc.a.SqlException: [jcc][t4][10120][10898][3.52.95] Invalid operation: result set is closed. ERRORCODE=-4470, SQLSTATE=null
at org.eclipse.birt.report.data.oda.jdbc.ResultSet.next(ResultS et.java:182)
at org.eclipse.datatools.connectivity.oda.consumer.helper.OdaRe sultSet.next(OdaResultSet.java:177)
at org.eclipse.birt.data.engine.odaconsumer.ResultSet.fetch(Res ultSet.java:139)
at org.eclipse.birt.data.engine.executor.cache.OdiAdapter.fetch (OdiAdapter.java:145)
at org.eclipse.birt.data.engine.executor.cache.RowResultSet.nex t(RowResultSet.java:102)
at org.eclipse.birt.data.engine.executor.transform.SimpleResult Set.next(SimpleResultSet.java:356)
at org.eclipse.birt.data.engine.impl.ResultIterator.hasNextRow( ResultIterator.java:480)
at org.eclipse.birt.data.engine.impl.ResultIterator.next(Result Iterator.java:419)
at org.eclipse.birt.data.engine.impl.ResultIterator.close(Resul tIterator.java:884)
at org.eclipse.birt.report.engine.data.dte.QueryResultSet.close (QueryResultSet.java:272)
etc...
Here is the report:
<data-sources>
<encrypted-property name="odaPassword" encryptionID="base64">bXBtczAx</encrypted-property>
</oda-data-source>
</data-sources>
<data-sets>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
where prg_id = 232
/* select ordernumber as prg_id, status as prg_sts_cd, status as prg_type_cd
from orders
order by ordernumber */</property>
</oda-data-set>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
if (prgId > 400)
else
row["PRG_ID"] = 2;
prgCount++;
return true;
else
return false;
]]></method>
</script-data-set>
</data-sets>
<styles>
</style>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
</text>
</page-footer>
</page-setup>
<body>
<table id="9">
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
*/]]></method>
<column id="28">
</column>
<column id="29">
</column>
<column id="30">
</column>
<header>
<row id="10">
<cell id="11">
<label id="12">
</label>
</cell>
<cell id="13">
<label id="14">
</label>
</cell>
<cell id="15">
<label id="16">
</label>
</cell>
</row>
</header>
<detail>
<row id="17">
out.close();
]]></method>
<cell id="18">
<data id="19">
</data>
</cell>
<cell id="20">
<data id="21">
</data>
</cell>
<cell id="22">
<data id="23">
</data>
</cell>
</row>
</detail>
<footer>
<row id="24">
<cell id="25"/>
<cell id="26"/>
<cell id="27"/>
</row>
</footer>
</table>
<table id="33">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<column id="52">
</column>
<column id="53">
</column>
<column id="54">
</column>
<column id="58">
</column>
<header>
<row id="34">
<cell id="35">
<label id="36">
</label>
</cell>
<cell id="37">
<label id="38">
</label>
</cell>
<cell id="39">
<label id="40">
</label>
</cell>
<cell id="55">
<label id="59">
</label>
</cell>
</row>
</header>
<detail>
<row id="41">
<cell id="42">
<data id="43">
</data>
</cell>
<cell id="44">
<data id="45">
</data>
</cell>
<cell id="46">
<data id="47">
</data>
</cell>
<cell id="56">
<data id="60">
</data>
</cell>
</row>
</detail>
<footer>
<row id="48">
<cell id="49"/>
<cell id="50"/>
<cell id="51"/>
<cell id="57"/>
</row>
</footer>
</table>
</body>
</report>
Re: Scripted dataset problem [message #643961 is a reply to message #643950] |
Wed, 08 December 2010 15:10   |
Don,
I am not certain why this is happening but
can you create another dataset that selects one row that is different
from the first and then put a table tied to this dataset after the
scripted dataset table? I want to see why BIRT is closing the connection.
Jason
On 12/8/2010 2:23 PM, Don wrote:
> Jason,
> the next data row.
> et.java:182)
> ultSet.java:139)
> Iterator.java:419)
> tIterator.java:884)
> etc...
> Here is the report:
> id="1">
> <data-sources>
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> where prg_id = 232
> prg_type_cd
> from orders
> </oda-data-set>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> if (prgId > 400)
> else
> row["PRG_ID"] = 2;
> prgCount++;
> return true;
> else
> return false;
> ]]></method>
> </script-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <table id="9">
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> */]]></method>
> <column id="28">
> </column>
> <column id="29">
> </column>
> <column id="30">
> </column>
> <header>
> <row id="10">
> <cell id="11">
> <label id="12">
> </label>
> </cell>
> <cell id="13">
> <label id="14">
> </label>
> </cell>
> <cell id="15">
> <label id="16">
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="17">
> out.close();
> ]]></method>
> <cell id="18">
> <data id="19">
> </data>
> </cell>
> <cell id="20">
> <data id="21">
> </data>
> </cell>
> <cell id="22">
> <data id="23">
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="24">
> <cell id="25"/>
> <cell id="26"/>
> <cell id="27"/>
> </row>
> </footer>
> </table>
> <table id="33">
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <column id="52">
> </column>
> <column id="53">
> </column>
> <column id="54">
> </column>
> <column id="58">
> </column>
> <header>
> <row id="34">
> <cell id="35">
> <label id="36">
> </label>
> </cell>
> <cell id="37">
> <label id="38">
> </label>
> </cell>
> <cell id="39">
> <label id="40">
> </label>
> </cell>
> <cell id="55">
> <label id="59">
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="41">
> <cell id="42">
> <data id="43">
> </data>
> </cell>
> <cell id="44">
> <data id="45">
> </data>
> </cell>
> <cell id="46">
> <data id="47">
> </data>
> </cell>
> <cell id="56">
> <data id="60">
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="48">
> <cell id="49"/>
> <cell id="50"/>
> <cell id="51"/>
> <cell id="57"/>
> </row>
> </footer>
> </table>
> </body>
> </report>
Re: Scripted dataset problem [message #644082 is a reply to message #641969] |
Thu, 09 December 2010 07:02   |
Jason,
I've created a new dataset which is selecting another row and I've added a table to the report following the table using the scripted dataset. The results were the same. I've included below, first part of the error and then the XML for the report.
ERROR
[12/9/10 6:46:20:679 EST] 00000023 odaconsumer E org.eclipse.birt.data.engine.odaconsumer.ResultSet fetch Cannot fetch the next data row.
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.cl oseQuery(QueryItemExecutor.java:46)
at org.eclipse.birt.report.engine.executor.TableItemExecutor.cl ose(TableItemExecutor.java:107)
at org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportItemExecutor.close(WrappedReportItemExecutor.java:39)
at org.eclipse.birt.report.engine.internal.executor.emitter.Rep ortItemEmitterExecutor.close(ReportItemEmitterExecutor.java: 40)
at org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplicateItemExecutor.close(SuppressDuplicateItemExecutor.j ava:35)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:83)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:90)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:101)
at org.eclipse.birt.report.engine.presentation.ReportDocumentBu ilder.build(ReportDocumentBuilder.java:211)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTas k.java:237)
at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask. java:90)
XML FOR REPORT
<data-sources>
</oda-data-source>
</data-sources>
<data-sets>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
where prg_id = 232
from orders
</oda-data-set>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
if (prgId > 400)
else
row["PRG_ID"] = 2;
prgCount++;
return true;
else
return false;
]]></method>
</script-data-set>
<oda-data-set extensionID="org.eclipse.birt.report.data.oda.jdbc.JdbcSelectDataSet " name="db2DataSet1" id="61">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
where prg_id = 316
from orders
</oda-data-set>
</data-sets>
<styles>
</style>
</style>
</style>
</styles>
<page-setup>
<page-footer>
<text id="3">
</text>
</page-footer>
</page-setup>
<body>
<table id="9">
<structure>
</structure>
</list-property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
*/]]></method>
<column id="28">
</column>
<column id="29">
</column>
<column id="30">
</column>
<header>
<row id="10">
<cell id="11">
<label id="12">
</label>
</cell>
<cell id="13">
<label id="14">
</label>
</cell>
<cell id="15">
<label id="16">
</label>
</cell>
</row>
</header>
<detail>
<row id="17">
out.close();
]]></method>
<cell id="18">
<data id="19">
</data>
</cell>
<cell id="20">
<data id="21">
</data>
</cell>
<cell id="22">
<data id="23">
</data>
</cell>
</row>
</detail>
<footer>
<row id="24">
<cell id="25"/>
<cell id="26"/>
<cell id="27"/>
</row>
</footer>
</table>
<table id="33">
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<column id="52">
</column>
<column id="53">
</column>
<column id="54">
</column>
<column id="58">
</column>
<header>
<row id="34">
<cell id="35">
<label id="36">
</label>
</cell>
<cell id="37">
<label id="38">
</label>
</cell>
<cell id="39">
<label id="40">
</label>
</cell>
<cell id="55">
<label id="59">
</label>
</cell>
</row>
</header>
<detail>
<row id="41">
<cell id="42">
<data id="43">
</data>
</cell>
<cell id="44">
<data id="45">
</data>
</cell>
<cell id="46">
<data id="47">
</data>
</cell>
<cell id="56">
<data id="60">
</data>
</cell>
</row>
</detail>
<footer>
<row id="48">
<cell id="49"/>
<cell id="50"/>
<cell id="51"/>
<cell id="57"/>
</row>
</footer>
</table>
<table id="62">
<property name="dataSet">db2DataSet1</property>
<structure>
</structure>
<structure>
</structure>
<structure>
</structure>
</list-property>
<column id="81">
<property name="width">2.375in</property>
</column>
<column id="82"/>
<column id="83"/>
<header>
<row id="63">
<cell id="64">
<label id="65">
<text-property name="text">PRG_ID_from_2nd_DB2_dataset</text-property>
</label>
</cell>
<cell id="66">
<label id="67">
<text-property name="text">PRG_STS_CD_from_2nd_DB2_dataset</text-property >
</label>
</cell>
<cell id="68">
<label id="69">
<text-property name="text">PRG_TYPE_CD_from_2nd_DB2_dataset</text-property >
</label>
</cell>
</row>
</header>
<detail>
<row id="70">
<cell id="71">
<data id="72">
</data>
</cell>
<cell id="73">
<data id="74">
</data>
</cell>
<cell id="75">
<data id="76">
</data>
</cell>
</row>
</detail>
<footer>
<row id="77">
<cell id="78"/>
<cell id="79"/>
<cell id="80"/>
</row>
</footer>
</table>
</body>
</report>
Re: Scripted dataset problem [message #644177 is a reply to message #644082] |
Thu, 09 December 2010 12:50   |
Don,
Is there any chance you could log a bug for this?
Jason
On 12/9/2010 7:03 AM, Don wrote:
> Jason,
> ERROR
> the next data row.
> et.java:182)
> ultSet.java:139)
> Iterator.java:419)
> tIterator.java:884)
> XML FOR REPORT
> id="1">
> <data-sources>
> </oda-data-source>
> </data-sources>
> <data-sets>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> where prg_id = 232
> prg_type_cd
> from orders
> </oda-data-set>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> if (prgId > 400)
> else
> row["PRG_ID"] = 2;
> prgCount++;
> return true;
> else
> return false;
> ]]></method>
> </script-data-set>
> <oda-data-set
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> where prg_id = 316
> prg_type_cd
> from orders
> </oda-data-set>
> </data-sets>
> <styles>
> </style>
> </style>
> </style>
> </styles>
> <page-setup>
> <page-footer>
> <text id="3">
> </text>
> </page-footer>
> </page-setup>
> <body>
> <table id="9">
> <structure>
> </structure>
> </list-property>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> */]]></method>
> <column id="28">
> </column>
> <column id="29">
> </column>
> <column id="30">
> </column>
> <header>
> <row id="10">
> <cell id="11">
> <label id="12">
> </label>
> </cell>
> <cell id="13">
> <label id="14">
> </label>
> </cell>
> <cell id="15">
> <label id="16">
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="17">
> out.close();
> ]]></method>
> <cell id="18">
> <data id="19">
> </data>
> </cell>
> <cell id="20">
> <data id="21">
> </data>
> </cell>
> <cell id="22">
> <data id="23">
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="24">
> <cell id="25"/>
> <cell id="26"/>
> <cell id="27"/>
> </row>
> </footer>
> </table>
> <table id="33">
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <column id="52">
> </column>
> <column id="53">
> </column>
> <column id="54">
> </column>
> <column id="58">
> </column>
> <header>
> <row id="34">
> <cell id="35">
> <label id="36">
> </label>
> </cell>
> <cell id="37">
> <label id="38">
> </label>
> </cell>
> <cell id="39">
> <label id="40">
> </label>
> </cell>
> <cell id="55">
> <label id="59">
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="41">
> <cell id="42">
> <data id="43">
> </data>
> </cell>
> <cell id="44">
> <data id="45">
> </data>
> </cell>
> <cell id="46">
> <data id="47">
> </data>
> </cell>
> <cell id="56">
> <data id="60">
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="48">
> <cell id="49"/>
> <cell id="50"/>
> <cell id="51"/>
> <cell id="57"/>
> </row>
> </footer>
> </table>
> <table id="62">
> <structure>
> </structure>
> <structure>
> </structure>
> <structure>
> </structure>
> </list-property>
> <column id="81">
> </column>
> <column id="82"/>
> <column id="83"/>
> <header>
> <row id="63">
> <cell id="64">
> <label id="65">
> </label>
> </cell>
> <cell id="66">
> <label id="67">
> </label>
> </cell>
> <cell id="68">
> <label id="69">
> <text-property
> </label>
> </cell>
> </row>
> </header>
> <detail>
> <row id="70">
> <cell id="71">
> <data id="72">
> </data>
> </cell>
> <cell id="73">
> <data id="74">
> </data>
> </cell>
> <cell id="75">
> <data id="76">
> </data>
> </cell>
> </row>
> </detail>
> <footer>
> <row id="77">
> <cell id="78"/>
> <cell id="79"/>
> <cell id="80"/>
> </row>
> </footer>
> </table>
> </body>
> </report>
Current Time: Tue Jul 22 22:15:07 EDT 2025
Powered by FUDForum. Page generated in 0.09842 seconds
