Home » Eclipse Projects » Rich Client Platform (RCP) » Hide ContributionItem but be able to trigger it via accellerator
Hide ContributionItem but be able to trigger it via accellerator [message #642182] Tue, 30 November 2010 04:57 Go to next message
Hi all,
I would like to have a not visible action but I would like to trigger it via shortcut keys.
I tried to set accelerator 'CTRL + D' and it works only if action is visible.
If I set visible false on that menu contribution, then the shortcut key doesn't work anymore
Any hints?
Thanks and best regards
Raffaele
Re: Hide ContributionItem but be able to trigger it via accellerator [message #642265 is a reply to message #642182] Tue, 30 November 2010 10:58 Go to previous messageGo to next message
Raffaele Gambelli wrote:
> Any hints?
You cannot do that. i.e. shortcuts that are in a menu item only work
when the menu item is there (since that's what hooks it up for the OS
accelerator table).
That's why eclipse has commands/handlers and org.eclipse.ui.bindings.
It needed a system so that it can provide keybindings to commands that
aren't rendered as a MenuItem in the main menu somewhere.
If you're an RCP app, use commands, handlers, org.eclipse.ui.bindings,
and org.eclipse.ui.menus, since the menu item for a command is
independent of the keybinding for the command.
PW
Paul Webster
http://wiki.eclipse.org/Platform_Expression_Framework
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .platform.doc.isv/guide/workbench.htm
Re: Hide ContributionItem but be able to trigger it via accellerator [message #642283 is a reply to message #642265] Tue, 30 November 2010 11:24 Go to previous messageGo to next message
>> Any hints?
> accelerator table).
> That's why eclipse has commands/handlers and org.eclipse.ui.bindings. It
I agree with what Paul says. But if you really want that, I believe this
is doable (even though one might consider it as a hack):
1) You can realize that your program reacts on key-pressed events: E.g.
register a KeyListener on the control that has the current focus of
interest (e.g. the viewer control) and on keyReleased evaluate your
KeyEvent (you may need to do an internet search how to realize that).
If your handler is rather global instead of local, you need a global
event listener, e.g. by adding a filter to the shell display
(getDisplay().addFilter(SWT.UP, listener)), which is really a hammer
that you should care of!
2) If you found that the key-combination of interest has occurred you
programmatically invoke a command, e.g.
IHandlerService handlerService = (IHandlerService)
serviceLocator.getService(IHandlerService.class);
handlerService.executeCommand(commandId, null);
This should have the wanted effect.
HTH & Greetings from Bremen,
Daniel Krügler
Re: Hide ContributionItem but be able to trigger it via accellerator [message #642458 is a reply to message #642283] Wed, 01 December 2010 07:44 Go to previous message
:-) yes, that's how we do it in the eclipse keybinding system.
The WorkbenchKeyboard is the global filter, and is what analyzes
SWT.KeyDown events. If the cumulative KeyDown events (and collecting
them correctly is not as simple as you think) match a keybinding (like
CTRL+SHIFT+5) then it executes the command through the handler service.
PW
Paul Webster
Previous Topic:DataTime Widget on solaries
Next Topic:Extension points: How to define new identifiers?
Current Time: Sat Jul 26 08:36:02 EDT 2025
Powered by FUDForum. Page generated in 0.07467 seconds
