Home » Eclipse Projects » Equinox » Eclipse Buddy Loading due to problems with Hibernate (Performance Question)
Eclipse Buddy Loading due to problems with Hibernate (Performance Question) [message #642110] Mon, 29 November 2010 16:17 Go to next message
Hello everybody,
I have a performance question according to buddy class loading. Following scenario: Bundle A contains Hibernate, Bundle B contains model classes which Hibernate must see. So I use Buddy Class Loading (policy: registered) and Hibernate can load the model classes. If there is another possibility than Buddy Class Loading then please let me know!!!
So to my question: How often registered plug-ins are searched for class definitions? Only one time when a class is first instantiated or every time a model class is instantiated.
Example: Class X is a model class and an object is created in Bundle A
for (int i = 0; i < 10; ++i) {
X x = new X();
In this case is the buddy class loading only used one time or ten times??
I hope someone can help me.
[Updated on: Tue, 30 November 2010 08:26] by Moderator
Re: Eclipse Buddy Loading due to problems with Hibernate (Performance Question) [message #642245 is a reply to message #642110] Tue, 30 November 2010 09:57 Go to previous messageGo to next message
In this case Bundle A has a class loader which is the initiating class loader for class X. An initiating classloader will only be used once on the first time X is loaded. All other access to class X from classes loaded by Bundle A's class loader must not cause another class load request of class X.
Tom.
Re: Eclipse Buddy Loading due to problems with Hibernate (Performance Question) [message #642318 is a reply to message #642245] Tue, 30 November 2010 14:03 Go to previous messageGo to next message
Thomas, thanks for your reply.
Have you any source (literature, official document) for that? I've tried to find some but until know I did not have success.
Re: Eclipse Buddy Loading due to problems with Hibernate (Performance Question) [message #642322 is a reply to message #642318] Tue, 30 November 2010 14:15 Go to previous message
This is not any different than the behavior of a normal class loader in java. The VM will not allow an initiating class loader to initiate a class lookup more than once after the class has been found by the initiating class loader. When I say initiate I mean initiated by the VM while dynamically running some code from a class. If you get your hands on the ClassLoader object it can of coarse be delegated to directly, the VM cannot prevent that.
But in your case you actually have the class X compiled into your class file and the class load of X is going to be initiated by the VM while running the code in your class.
HTH
Tom.
Previous Topic:Zombie Bundles
Next Topic:p2 update testing against alternative repo
Current Time: Sat Jul 12 19:27:35 EDT 2025
Powered by FUDForum. Page generated in 0.03896 seconds
