Home » Modeling » M2T (model-to-text transformation) » Acceleo Java Launcher
icon4.gif  Acceleo Java Launcher [message #642201] Tue, 30 November 2010 06:48 Go to next message
i use posted configuration for running my generator project via java launcher (Acceleo 3.0.1). But i always get the error message:
org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/uml2/2.0.0/UML' not found
I enhanced the method
public void registerPackages(ResourceSet resourceSet) {
super.registerPackages(resourceSet);
resourceSet.getPackageRegistry().put(org.eclipse.uml2.uml.UM LPackage.eINSTANCE.getNsURI(), org.eclipse.uml2.uml.UMLPackage.eINSTANCE);
and the method
public void registerResourceFactories(ResourceSet resourceSet) {
super.registerResourceFactories(resourceSet);
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put(UMLResource.FILE_EXTENSION, UMLResource.Factory.INSTANCE);
But i always get the same error. If i use Acceleo plugin launcher everthing works fine. What can i do to solve these issue?
Best regards
Maik
P.S.
I also tested with
Map uriMap = resourceSet.getURIConverter().getURIMap();
URI uri = URI.createURI(" file:/D:/Programs/eclipse/plugins/org.eclipse.uml2.uml_3.1.1 .v201008191505.jar ");
uriMap.put(URI.createURI(UMLResource.LIBRARIES_PATHMAP), uri.appendSegment("libraries").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.METAMODELS_PATHMAP), uri.appendSegment("metamodels").appendSegment(""));
uriMap.put(URI.createURI(UMLResource.PROFILES_PATHMAP), uri.appendSegment("profiles").appendSegment(""));
Re: Acceleo Java Launcher [message #642209 is a reply to message #642201] Tue, 30 November 2010 07:07 Go to previous messageGo to next message
Perhaps try to replace
with the following :
EPackage.Registry.INSTANCE.put("http://www.eclipse.org/uml2/2.0.0/UML", UMLPackage.eINSTANCE);
Sebastien
Re: Acceleo Java Launcher [message #642217 is a reply to message #642209] Tue, 30 November 2010 07:39 Go to previous messageGo to next message
Hi Maik,
Sebastien's answer would work, but it would be better to keep your package registrations local to the resource set instead of adding to the global EPackage registry Razz.
The problem you have is that you're trying to load an UML model created with an older version of Eclipse. The URI of the UML project's metamodel has evolved from "http://www.eclipse.org/uml2/2.0.0/UML" to ""http://www.eclipse.org/uml2/3.0.0/UML" ... and thus EMF cannot find the "2.0.0" URI when you manually register the package.
in addition to the line you've already added :
resourceSet.getPackageRegistry().put(org.eclipse.uml2.uml.UMLPackage.eINSTANCE.getNsURI(), org.eclipse.uml2.uml.UMLPackage.eINSTANCE);
Please add this one :
resourceSet.getPackageRegistry().put("http://www.eclipse.org/uml2/2.0.0/UML", org.eclipse.uml2.uml.UMLPackage.eINSTANCE);
Laurent Goubet
Obeo
Re: Acceleo Java Launcher [message #642227 is a reply to message #642209] Tue, 30 November 2010 08:22 Go to previous messageGo to next message
Hi Sebastien and Laurent,
no i got another exception:
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException: org.eclipse.emf.ecore.xmi.ClassNotFoundException: Class 'StringLiteralExp' is not found or is abstract. (file:/com/test/bin/generate.emtl 13, 856)
Do i need an additional package to register?
[Updated on: Tue, 30 November 2010 11:13] by Moderator
Re: Acceleo Java Launcher [message #642402 is a reply to message #642227] Wed, 01 December 2010 02:57 Go to previous messageGo to next message
--------------040301020509010705090607
Hi Maik,
This last one would indicate that you're missing the OCL package
registration ... but that registration should be handled by the
generated java launcher by default ... Have your removed any of the
lines from "registerPackages" when adding the registration of the UML
package? (Specifically, you need to call
super.registerPackages(resourceSet) from this method.)
Laurent Goubet
Obeo
> it works now as java application running in eclipse. Many thanks for that.
> Now i created a ant task. After running ant task i get the following
> error message
> (file:/com/test/generate.emtl 13, 856)
name="laurent_goubet.vcf"
filename="laurent_goubet.vcf"
bjoyLjENCmVuZDp2Y2FyZA0KDQo=
--------------040301020509010705090607--
Re: Acceleo Java Launcher [message #642440 is a reply to message #642402] Wed, 01 December 2010 05:59 Go to previous messageGo to next message
Hi Laurent,
thanks for your answer. But i have a strange behavior here. I think it depends on eclipse and how i finds the nesessary packages and profile.
My model is an uml file with additionally profile files. After adding the UML namespace http://www.eclipse.org/uml2/2.0.0/UML to method registerPackages i as able to run java launcher in eclipse as java application.
So i created a ant task. After starting the ant task i got the message class viewstate from my viewprofile cannot be found. So i added the viewprofile namespace to method registerPackages. After starting the ant task again i got the error message EClass cannot be found. So i added ecore namespace. After starting ant task again i got the error message StringLetralExp not found. So what can in do?
My model file has the following namespace
<xmi:XMI xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:MagicDrawProfile="http:///schemas/MagicDrawProfile/_CAA84HhZEd-ijZRcwHp7Mw/0" xmlns:ViewProfile="http:///schemas/ViewProfile/_B_3y8HhZEd-ijZRcwHp7Mw/0" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" xmlns:uml="http://www.eclipse.org/uml2/2.0.0/UML" xsi:schemaLocation="http:///schemas/MagicDrawProfile/_CAA84HhZEd-ijZRcwHp7Mw/0 UML_Standard_Profile.MagicDraw_Profile.profile.uml#_CYqG33hZ Ed-ijZRcwHp7Mw http:///schemas/ViewProfile/_B_3y8HhZEd-ijZRcwHp7Mw/0 ViewProfile.profile.uml#_CYsi9nhZEd-ijZRcwHp7Mw">
<uml:Model xmi:id="eee_1045467100313_135436_1" name="test_model" viewpoint="">
<ownedComment xmi:id="_12_5_41801a3_1265618805392_492566_98" body="Author: Team&#xA;Created: 08.02.10 09:46Uhr&#xA;Title: Test&#xA;Comment: " annotatedElement="eee_1045467100313_135436_1"/>
<packageImport xmi:id="_0primitiveTypestest_model">
<importedPackage xmi:type="uml:Model" href="pathmap://UML_LIBRARIES/UMLPrimitiveTypes.library.uml#_0"/>
</packageImport>
<packageImport xmi:id="_0javaPrimitiveTypestest_model">
<importedPackage xmi:type="uml:Model" href="pathmap://UML_LIBRARIES/JavaPrimitiveTypes.library.uml#_0"/>
</packageImport>
One of my profile file has to following namspace
<uml:Profile xmi:version="2.1" xmlns:xmi="http://schema.omg.org/spec/XMI/2.1" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" xmlns:uml="http://www.eclipse.org/uml2/2.0.0/UML" xmi:id="_12_1_1_41801a3_1180279591484_435565_108" name="ViewProfile" metamodelReference="_0metamodelReferenceViewProfile">
<eAnnotations xmi:id="_CYsi9XhZEd-ijZRcwHp7Mw" source="http://www.eclipse.org/uml2/2.0.0/UML">
<contents xmi:type="ecore:EPackage" xmi:id="_CYsi9nhZEd-ijZRcwHp7Mw" name="ViewProfile" nsURI="http:///schemas/ViewProfile/_B_3y8HhZEd-ijZRcwHp7Mw/0" nsPrefix="ViewProfile">
<eClassifiers xmi:type="ecore:EClass" xmi:id="_CYsi93hZEd-ijZRcwHp7Mw" name="ViewState">
Is that the right way to register profiles in these method?
Best regards
Maik
Re: Acceleo Java Launcher [message #642450 is a reply to message #642440] Wed, 01 December 2010 06:57 Go to previous messageGo to next message
--------------030605080701030407020604
Maik,
I must admit I don't know how to register profiles, but I do know
metamodel (your namespaces) registrations should be done through the
java launcher and its "registerPackage" method. The fact that your ant
task doesn't seem to find the Ecore metamodel even though it is
registered seems ... wrong.
In any case, "StringLiteralExp" is part of the OCL metamodel, and this
is the namespace you're missing. The Java launcher _should_ take care of
registering it properly. I don't remember the package hierarchy in which
StringLiteralExp is located, you can look at the org.eclipse.ocl plugin
and its "model/ocl.ecore" model, as it it the metamodel you're searching
for.
Laurent Goubet
Obeo
On 01/12/2010 11:59, Maik wrote:
> Hi Laurent,
> application.
> viewpoint="">
> body="Author: Team
> Title: Test
> </packageImport>
> </packageImport>
> name="ViewProfile"
> name="ViewState">
> Best regards
> Maik
--------------030605080701030407020604--
Re: Acceleo Java Launcher [message #643349 is a reply to message #642450] Mon, 06 December 2010 10:34 Go to previous message
Hi Laurent,
i solved the problem. It was a additional entry in method registerResourceFactories
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "uml", UMLResource.Factory.INSTANCE);
After adding these entry the ant task works fine....
Maik
Previous Topic:[Acceleo] How to test for empty/null reference?
Next Topic:[Xpand] Root element not found
Current Time: Fri Jul 18 23:18:53 EDT 2025
Powered by FUDForum. Page generated in 0.25892 seconds
