Home » Eclipse Projects » Rich Client Platform (RCP) » Different splash screens
Different splash screens [message #642191] Tue, 30 November 2010 05:35 Go to next message
Hi!
We are developing Eclipse RCP application that supports different licensing schemes. For each scheme it must have special splash screen.
Is it possible to customize what splash screen should be drawn from java code?
Thanks in advance,
Sergey
Re: Different splash screens [message #642196 is a reply to message #642191] Tue, 30 November 2010 05:51 Go to previous messageGo to next message
On 11/30/2010 11:35, Sergey wrote:
> Hi!
> code?
It think it is possible. Have a look at the extension point
org.eclipse.ui.splashHandlers
(I haven't used it, though).
HTH & Greetings from Bremen,
Daniel Krügler
Re: Different splash screens [message #642214 is a reply to message #642196] Tue, 30 November 2010 07:15 Go to previous messageGo to next message
Unfortunately, this wont help.
I think splashHandlers extension point allows only to decorate existing splash. This because if one manage to debug splash handler, one could notice, that splash will appear before splashHandlers class started its execution.
Re: Different splash screens [message #642221 is a reply to message #642214] Tue, 30 November 2010 07:37 Go to previous messageGo to next message
> execution.
Well, there is also the -showsplash program argument parameter, which
allows to provide a specific splash screen, though. I don't know,
whether this helps, because this value is evaluated in the early phase
of the program start. Maybe your installation can modify the value of
this parameter provided in your .ini file?
Daniel Krügler
Re: Different splash screens [message #642222 is a reply to message #642221] Tue, 30 November 2010 07:43 Go to previous message
>> execution.
I also found this report:
http://dev.eclipse.org/newslists/news.eclipse.platform.rcp/m sg28074.html
(Again: Untested)
Daniel Krügler
Previous Topic:Regarding Implementing the Eclipse HELP Functionality
Next Topic:DataTime Widget on solaries
Current Time: Sat Jul 26 06:08:40 EDT 2025
Powered by FUDForum. Page generated in 0.03915 seconds
