Hide ContributionItem but be able to trigger it via accellerator [message #642182] |
Tue, 30 November 2010 04:57  |
Hi all,
I would like to have a not visible action but I would like to trigger it via shortcut keys.
I tried to set accelerator 'CTRL + D' and it works only if action is visible.
If I set visible false on that menu contribution, then the shortcut key doesn't work anymore
Any hints?
Thanks and best regards
Raffaele
Re: Hide ContributionItem but be able to trigger it via accellerator [message #642283 is a reply to message #642265] |
Tue, 30 November 2010 11:24   |
On 11/30/2010 16:58, Paul Webster wrote:
> Raffaele Gambelli wrote:
>> Any hints?
> You cannot do that. i.e. shortcuts that are in a menu item only work
> when the menu item is there (since that's what hooks it up for the OS
> accelerator table).
> That's why eclipse has commands/handlers and org.eclipse.ui.bindings. It
> needed a system so that it can provide keybindings to commands that
> aren't rendered as a MenuItem in the main menu somewhere.
> If you're an RCP app, use commands, handlers, org.eclipse.ui.bindings,
> and org.eclipse.ui.menus, since the menu item for a command is
> independent of the keybinding for the command.
I agree with what Paul says. But if you really want that, I believe this
is doable (even though one might consider it as a hack):
1) You can realize that your program reacts on key-pressed events: E.g.
register a KeyListener on the control that has the current focus of
interest (e.g. the viewer control) and on keyReleased evaluate your
KeyEvent (you may need to do an internet search how to realize that).
If your handler is rather global instead of local, you need a global
event listener, e.g. by adding a filter to the shell display
(getDisplay().addFilter(SWT.UP, listener)), which is really a hammer
that you should care of!
2) If you found that the key-combination of interest has occurred you
programmatically invoke a command, e.g.
IHandlerService handlerService = (IHandlerService)
serviceLocator.getService(IHandlerService.class);
handlerService.executeCommand(commandId, null);
This should have the wanted effect.
HTH & Greetings from Bremen,
Daniel Krügler
FUDForum. Page generated in 0.04030 seconds
